disable DCache on RTEMS SMP
Sebastian Huber
Fri Apr 19 06:45:17 UTC 2024
Hello Stéphane,
the rtems_cache_disable_data() has no real use case. It is quite
difficult to implement and it is not unusual that its implementation is
broken. I think on RTEMS 6 it should work for this BSP. However, I am
not sure if the atomic operations work, if you disable the data cache.
Without atomic operations, you will have unpredictable behaviour in SMP
configurations.
You can statically place data in a non-cacheable area with a section
attribute:
#include <bsp/linker-symbols.h>
BSP_NOCACHE_SECTION char nocache[123];
Kind regards,
Sebastian
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
