disable DCache on RTEMS SMP
Fri Jun 7 16:05:52 UTC 2024
On 22.05.24 17:53, Sebastian Huber wrote:
> On 19.04.24 08:45, Sebastian Huber wrote:
>> Hello Stéphane,
>> the rtems_cache_disable_data() has no real use case. It is quite
>> difficult to implement and it is not unusual that its implementation
>> is broken. I think on RTEMS 6 it should work for this BSP. However, I
>> am not sure if the atomic operations work, if you disable the data
>> cache. Without atomic operations, you will have unpredictable
>> behaviour in SMP configurations.
>> You can statically place data in a non-cacheable area with a section
>> attribute:
>> #include <bsp/linker-symbols.h>
>> BSP_NOCACHE_SECTION char nocache[123];
> The rtems_cache_disable_data() for the Zynq 7000 BSPs was definitely
> broken. I fixed it here:
> https://gitlab.rtems.org/rtems/rtos/rtems/-/merge_requests/44
> I would still not use this function in a real application.
Actually, there was bug in the fix, so it still didn't work. I managed
to disable the L1 and L2 caches, however, afterwards I got not that far.
On the Cortex-A cores it seems at least the L1 data cache is required to
provide support for atomic operations:
https://stackoverflow.com/questions/76207164/disabled-dcache-will-prevent-atomic-flag-from-being-set
So, I suggest to do this for the cache manager implementation:
* Make the rtems_cache_disable_data() directive a nop.
* Issue a fatal error if someone calls rtems_cache_disable_data().
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
