compiling rtems-net-services fail
Heinz Junkes
junkes at fhi-berlin.mpg.de
Wed Jun 12 20:30:25 UTC 2024
ok, should be
#include <net/if.h>
Works with both stacks.
Heinz
> On 12. Jun 2024, at 22:12, Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hi,
> junkes at Zarquon RTEMS_FOR_EPICS % git clone \
> https://gitlab.rtems.org/rtems/pkg/rtems-net-services.git
> Cloning into 'rtems-net-services'...
> remote: Enumerating objects: 806, done.
> remote: Counting objects: 100% (31/31), done.
> remote: Compressing objects: 100% (26/26), done.
> remote: Total 806 (delta 16), reused 6 (delta 5), pack-reused 775 (from 1)
> Receiving objects: 100% (806/806), 1.29 MiB | 469.00 KiB/s, done.
> Resolving deltas: 100% (250/250), done.
> cd rtems-net/services
> git submodule init
> git submodule update
> ./waf configure --prefix=${RTEMS_ROOT} —rtems-bsps=xilinx_zynq_a9_qemu
> ./waf
> [101/108] Compiling testsuites/ttcpshell01/test_main.c
> [102/108] Compiling net/libbsd/net_adapter.c
> [103/108] Compiling testsuites/telnetd01/init.c
> ../../net/libbsd/net_adapter.c:48:10: fatal error: rtems/bsd/iface.h: No such file or directory
> 48 | #include <rtems/bsd/iface.h>
> compilation terminated.
> Waf: Leaving directory `/Volumes/Epics/LONG_ISLAND/RTEMS_FOR_EPICS/rtems-net-services/build/arm-rtems6-beagleboneblack'
> Build failed
> -> task in 'ntp01.exe' failed with exit status 1 (run with -v to display more information)
> -> task in 'ttcpshell01.exe' failed with exit status 1 (run with -v to display more information)
> -> task in 'telnetd01.exe' failed with exit status 1 (run with -v to display more information)
> The missing file is only defined in the legacy-stack, but not in den libbsd-stack?
> With this configuration it works:
> ./waf configure --prefix=${RTEMS_ROOT} --rtems-bsps=powerpc/beatnik
> Heinz_______________________________________________
> users mailing list
> users at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20240612/464eef10/attachment.bin>
