MicroZed PHY timeout
Richard VanderWal rvanderwal at bellsouth.net
Mon Mar 18 15:56:18 UTC 2024
Hey Kinsey,
Thanks for the response. Yes, I am using the 6-freebsd-12 branch of rtems-libbsd.
This doesn’t make any sense to me, but i get the error when I build everything (rsb, rtems, libbsd) on Redhat Enterprise Linux 8. If I build everything on Ubuntu 22.04, everything works fine.
-Rick
> On Mar 13, 2024, at 10:00 AM, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> As far as I know, the Zynq LibBSD CGEM support hasn't changed much beyond the updates to support ZynqMP variants of the peripheral. Are you building LibBSD master or 6-freebsd-12?
> Kinsey
> -----Original Message-----
> From: users <users-bounces at rtems.org> On Behalf Of Richard VanderWal
> Sent: Tuesday, March 12, 2024 11:34 AM
> To: RTEMS Users <users at rtems.org>
> Subject: MicroZed PHY timeout
> Good Morning,
> We are moving our RTEMS 5.1 application on ARM 32 MicroZed hardware (BSP arm/xilinx_zynq_zedboard) to the latest RTEMS master. We have found that the cgem0 interface no longer is initialized and we’re seeing a “phy read timeout: 1” message during boot. This appears to be happening in a call to cgem_miibus_readreg called from cgem_probe.
> We’re running on actual Avnet MicroZed board not anything custom.
> Has anyone else encountered this? Any help is appreciated.
> Thanks in advance!
> Rick VanderWal
> users mailing list
> users at rtems.org
