building rtems-net-legacy failed
Wed May 29 23:26:07 UTC 2024
On 30/5/2024 6:44 am, Miroslaw Dach wrote:
> Hi John and Joel,
>> It is enable/disable networking (e.g. --enable-networking when you configure
> RTEMS itself) and then do not reference the legacy repository at all.
> I built RTEMS 5 with  --enable-networking
> How to build then  rtems-net-services without referencing legacy repository?
> I did not find such an option to ignore the network stack  in  waf.
The net services is not supported on RTEMS 5. It would take time to figure out
if it is possible to support RTEMS 5. Net services contains NTP and it depends
on RTEMS kernel calls to work. The kernel support is implemented and stable on
RTEMS 6 and I am not sure the needed calls are present or working well on RTEMS 5.
