EPICS ioc with RTEMS on Raspberry Pi
Miroslaw Dach miroslaw.dach at gmail.com
Sun Oct 18 05:21:26 UTC 2026
Hi Joel,
Thank you. I have an account on gitlab.rtems.org now (mirek23) and have
opened the work item and the merge request against main:
Work item:     https://gitlab.rtems.org/rtems/rtos/rtems/-/work_items/5810
Merge request:
https://gitlab.rtems.org/rtems/rtos/rtems/-/merge_requests/1542
The commit applies unchanged to main (bsp_interrupt_dispatch() is the
same code as in 6.2) and to the 6 branch. I can open a second merge
request against 6 for the backport, or leave the cherry-pick to a
maintainer, whichever you prefer.
For the record, the board has since completed a second run of more than
17 hours with the fix, this time with an EPICS scan task running at
1 kHz on top of the USB Ethernet traffic, without any freeze.
Best regards,
Mirek
śr., 14 paź 2026 o 16:05 Joel Sherrill <joel at rtems.org> napisał(a):
> Miroslaw thanks for tracking this down.
> Do you have an account on gitlab.rtems.org?
> I think this needs a work item (formerly known as an issue) for main.
> And a merge request.
> @gedare This seems like it should be backported to 6. Thoughts?
> --joel
> On Wed, Oct 14, 2026 at 5:13 PM Miroslaw Dach <miroslaw.dach at gmail.com>
> wrote:
>> Hi Gedare,
>> The issue with RTEMS on RPi 3B+ was solved.
>> The problem was in the Raspberry Pi BSP interrupt dispatcher that makes
>> the whole system stop under interrupt load. We hit it on a Raspberry Pi 3
>> Model B+ running an EPICS 7.0.10 IOC with rtems-libbsd (USB Ethernet) on
>> RTEMS 6.2;
>> Symptom
>> With network traffic on the LAN7800 USB Ethernet the board froze after
>> 30 s to 3 min, idle after a few minutes: console dead, no task runs, an
>> externally visible "heartbeat" stops. It looked like a bus or CPU lockup
>> and we spent months on USB controller theories. Earlier reports of
>> "RTEMS hangs on Raspberry Pi with USB/network" on the lists may be the
>> same issue.
>> Root cause
>> bsp_interrupt_dispatch() in bsps/arm/raspberrypi/irq/irq.c reads
>> BCM2835_IRQ_BASIC and, when any "speed-up" bit is set, calls ffs() on
>> the UNMASKED value:
>>     pend = BCM2835_REG(BCM2835_IRQ_BASIC);
>>     if ( pend & BCM2835_IRQ_BASIC_SPEEDUP_USED_BITS ) {
>>       pend_bit = ffs(pend) - 1;
>>       vector = bcm2835_irq_speedup_table[pend_bit];
>> Bit 8 of IRQ_BASIC ("one or more bits set in pending register 1") is set
>> whenever a bank-1 interrupt without a speed-up bit is pending, for
>> example the system timer compare 3 used for the clock tick (GPU IRQ 3).
>> If such an interrupt is pending at the same time as a speed-up one, for
>> example USB (GPU IRQ 9, speed-up bit 11), the register reads 0x900.
>> ffs(0x900) - 1 = 8, bcm2835_irq_speedup_table[8] is -1, vector becomes
>> 0xffffffff, the check "vector < 255" fails, no handler is called, the
>> interrupt stays asserted and the CPU re-enters the dispatcher forever.
>> We confirmed this with a RAM trace that survives a watchdog reset: the
>> last 600 entries of every frozen run were the IRQ_BASIC read returning
>> 0x900, about 1.3 million times per second, with no handler call in
>> between. The probability per interrupt is small, so the failure rate
>> scales with the interrupt rate; with ~40000 USB interrupts/s and a 2 kHz
>> tick it took about 30 s.
>> Fix
>> Mask the value before the bit scan. With 0x900 the USB interrupt is then
>> dispatched first; the immediate re-entry sees 0x100, takes the
>> IRQ_PENDING1 path and dispatches the tick.
>> Tested on Raspberry Pi 3B+ (raspberrypi2 BSP, RTEMS 6.2 be446b02d0,
>> rtems-libbsd 6-freebsd-14, EPICS 7.0.10): 15.5 hours of continuous
>> operation with 450 million USB transfers and 1.8 billion interrupts,
>> versus a freeze within a minute before the change.
>> The patch could be found in the attachment.
>> Best Regards
>> Mirek
>> czw., 21 maj 2026 o 14:41 Miroslaw Dach <miroslaw.dach at gmail.com>
>> napisał(a):
>>> Hi Gedare,
>>> Thanks for the good news about the RPi4. Please let me know when you
>>> have some results and working RPi4 with RTEMS.
>>> Did anybody try the lwIP network stack for RTEMS?
>>> Best Regards
>>> Mirek
>>> wt., 19 maj 2026 o 15:18 Gedare Bloom <gedare at rtems.org> napisał(a):
>>>> Just a quick note that the preferred venue for community engagement is
>>>> shifting toward https://users.rtems.org
>>>> I think the RPi4 is maturing quite rapidly. We have a GSoC project
>>>> focused on it as well.
>>>> lwIP might also be an option to consider.
>>>> On Fri, May 8, 2026 at 4:00 PM Miroslaw Dach <miroslaw.dach at gmail.com>
>>>> wrote:
>>>> > Hi John,
>>>> > Many Thanks for your reply and all of the hints. It looks like that
>>>> at present there is no good solution to use RTEMS on RPi 3 b+ due to the
>>>> issue with the
>>>> > usb-Network bridge. The most promising approach would be to use the
>>>> PRi v4 or v5  since the network chip is directly connected to the system
>>>> but the BSP is not yet complete for RTEMS so maybe in the future.
>>>> > Best Regards
>>>> > Mirek
>>>> > sob., 25 kwi 2026 o 10:37 John Howard <echosoft.llc at gmail.com>
>>>> napisał(a):
>>>> >> Hi Mirek,
>>>> >> I don't know what to tell you about this issue. You know more about
>>>> the details than I do.
>>>> >> (I don't know what EPICS IOC does.)
>>>> >> I knew RTEMS didn't use FIQ, but I assumed a 32/64-bit FreeBSD for
>>>> Raspberry Pi didn't either. Why not a continuing FIQ issue on their mailing
>>>> list after all this time? I haven't used FreeBSD for RPi (too many security
>>>> holes to me). I use Debian Bullseye for my 3B+ and I am not happy with
>>>> Linux.
>>>> >> I don't expect this to occur on RPi Zero 2 W because it lacks the
>>>> Ethernet subsystem and has a newer revision of the 3B+ subsystem. (I will
>>>> deal with it later during my app testing phase.)
>>>> >> I am not the CODEOWNER at RTEMS.org for that Dynaware/Synopsis
>>>> driver.
>>>> >> I do know that Synopsis released it unlicensed AS IS but is willing
>>>> to license it under obligation for their customers.
>>>> >> I recently looked at an alternative kernel memory map document where
>>>> FIQ stacks are present for RPi 3B+ when Aarch32, but I can't find them when
>>>> Aarch64 which standardized calling conventions.
>>>> >> Sorry I couldn't be of much help to you on this issue. Dealing with
>>>> FIQ handling is as idiosyncratic as it gets on Raspberry Pi and is a
>>>> deal-breaker to me.
>>>> >> -- John
>>>> >> On Apr 22, 2026, at 10:28 PM, Miroslaw Dach <miroslaw.dach at gmail.com>
>>>> wrote:
>>>> >> Hi John,
>>>> >> Thanks for your e-mail and your suggestion.
>>>> >> Follow-up to my earlier report about the DWC OTG USB hang on RPi 3B+
>>>> >> with RTEMS 6. I've done extensive instrumentation and applied
>>>> BCM2835-
>>>> >> specific errata workarounds from the Linux dwc2 driver. Here are the
>>>> >> complete findings:
>>>> >> I added diagnostic counters (#ifdef __rtems__) to the FreeBSD dwc_otg
>>>> >> driver, printed every 1 second from the 10ms timer callback:
>>>> >> - yld:   times dwc_otg_interrupt_poll_locked() hit its 16-iteration
>>>> cap
>>>> >> - afail: times dwc_otg_host_channel_alloc() failed (no free channels)
>>>> >> - hok:   successful halt completions processed
>>>> >> - rxd:   RX data discarded (no active endpoint listening)
>>>> >> - stuck: channels with wait_halted=1 but allocated=0 (leaked
>>>> channels)
>>>> >> - filt:  filter ISR entry/exit count (to detect stuck ISR)
>>>> >> - thr:   thread handler entry/exit count
>>>> >> - gi:    last GINTSTS register value
>>>> >> Results: channel exhaustion theory DISPROVED
>>>> >> Across all tests, every counter remained perfectly healthy right up
>>>> to
>>>> >> the instant of the freeze:
>>>> >>   DWC_OTG t=17500: yld=0 afail=0 hok=180038 rxd=0 ch=8/16
>>>> >>       alloc=0 wh=0 stuck=0 filt=738178/738178 thr=7280/7280
>>>> >>       gi=0x04000031
>>>> >> - yld=0:     the 16-iteration poll loop cap was NEVER hit
>>>> >> - afail=0:   channel allocation NEVER failed
>>>> >> - stuck=0:   NO channels ever leaked (wait_halted was always cleared)
>>>> >> - filt balanced: filter ISR entered and exited the same number of
>>>> times
>>>> >> - thr balanced:  thread handler entered and exited the same number
>>>> of times
>>>> >> - gi=0x04000031: benign (host mode + TX FIFOs empty + RX FIFO
>>>> non-empty)
>>>> >> The ~1054 halt completions/second were steady with no degradation.
>>>> >> Results: total CPU freeze, not software deadlock
>>>> >> I also tried an independent RTEMS timer (rtems_timer_fire_after) as a
>>>> >> heartbeat, firing outside the USB bus lock. Both the USB timer and
>>>> the
>>>> >> independent heartbeat stopped simultaneously, confirming the entire
>>>> ARM
>>>> >> core freezes — not just the USB subsystem.
>>>> >> No RTEMS fatal error handler was triggered (I installed one via
>>>> >> CONFIGURE_INITIAL_EXTENSIONS). This means it is NOT a standard ARM
>>>> >> data abort — the CPU simply stops executing, likely due to an AHB bus
>>>> >> lockup caused by the DWC OTG controller hardware.
>>>> >> BCM2835 errata workarounds applied
>>>> >> Based on the Linux dwc2 driver (params.c, core.c) and the Ultibo
>>>> >> project documentation, I applied three workarounds:
>>>> >> 1. FIFO size cap: BCM2835 hardware reports 4096 words but only 4080
>>>> >>    exist. Cap sc_fifo_size to 4080*4 bytes to prevent FIFO overrun.
>>>> >>    (In practice, the hardware on my board reported <= 4080, so this
>>>> >>    cap was NOT triggered.)
>>>> >> 2. GAHBCFG AHB burst configuration: Broadcom redefined bits [4:1] of
>>>> >>    GAHBCFG for AXI burst control. Linux dwc2 sets ahbcfg=0x10 for
>>>> >>    BCM2835. Changed from GAHBCFG_GLBLINTRMSK (0x01) to 0x11.
>>>> >> 3. AHB idle wait after core reset: Added a loop waiting for
>>>> >>    GRSTCTL_AHBIDLE after GRSTCTL_CSFTRST, plus 250ms settling delay
>>>> >>    (Linux dwc2 uses 100+ ms).
>>>> >> Results with workarounds:
>>>> >> - Before: hangs after ~86 seconds (2 kHz tick)
>>>> >> - After:  hangs after ~175 seconds (2 kHz tick)
>>>> >> The workarounds approximately doubled the time-to-hang but did NOT
>>>> >> eliminate it. All software counters remained healthy throughout.
>>>> >> The hang is caused most probably by a combination of factors:
>>>> >> 1. The DWC OTG controller on BCM2835/BCM2837 requires sub-125µs
>>>> >>    interrupt response times for USB split transaction phases (Start
>>>> >>    Split → Complete Split through the USB hub). The RPi 3B+ Ethernet
>>>> >>    goes through a USB hub (LAN7515), making every packet a split
>>>> >>    transaction.
>>>> >> 2. The Linux kernel addresses this with a dedicated FIQ (Fast
>>>> Interrupt
>>>> >>    Request) handler (dwc_otg_fiq_fsm.c) that executes complete split
>>>> >>    transactions in FIQ context, bypassing the normal interrupt stack.
>>>> >>    Without FIQ, "certain USB devices become completely unusable."
>>>> >> 3 The FreeBSD dwc_otg driver used by RTEMS handles all split
>>>> >>    transactions in normal interrupt context. On RTEMS, the interrupt
>>>> >>    filter and thread handler run back-to-back in the interrupt server
>>>> >>    task (nexus_intr_with_filter in rtems-kernel-nexus.c), with no
>>>> >>    preemption point between them.
>>>> >> 4 When the controller's split transaction timing is violated, it
>>>> >>    enters an unrecoverable state that locks the AHB bus, freezing the
>>>> >>    entire ARM core including UART and system timers.
>>>> >> The timing correlation with tick rate confirms this: higher tick rate
>>>> >> = more frequent scheduling = more interrupt latency jitter = faster
>>>> >> timing violation.
>>>> >> A proper fix requires most probably implementing FIQ-based split
>>>> transaction handling
>>>> >> in the RTEMS BSP for BCM2835/BCM2837, similar to what Linux does in
>>>> >> dwc_otg_fiq_fsm.c. This is a significant undertaking but is essential
>>>> >> for reliable USB operation on RPi 3B+ (and RPi Zero 2 W, which uses
>>>> >> the same SoC).
>>>> >> The GAHBCFG and reset sequence workarounds should also be applied as
>>>> >> they improve stability.
>>>> >> Please give me your thoughts on that. Maybe it is easier to finalise
>>>> the BSP for RPi 4 and 5?
>>>> >> Best Regards
>>>> >> Mirek
>>>> >> śr., 22 kwi 2026 o 13:17 John Howard <echosoft.llc at gmail.com>
>>>> napisał(a):
>>>> >>> Fascinating. Thanks for that detailed report.
>>>> >>> You indicated USB enumerating continues running in the background.
>>>> >>> I am educated-guessing that a counter maximum is reached, and then
>>>> mistakenly breached. I would look for a test of that counter and correct it
>>>> from allowing greater-than comparing.
>>>> >>> Let us know how it turns out.
>>>> >>> I am developing an app for Raspberry Pi Zero 2 W (stripped-down
>>>> 3B+). I wasn't expecting any potential problem like this.
>>>> >>> -- John
>>>> >>> > On Apr 22, 2026, at 1:25 PM, Miroslaw Dach <
>>>> miroslaw.dach at gmail.com> wrote:
>>>> >>> > Hi All,
>>>> >>> > I'm running an EPICS ioc server (EPICS 7.0.10)  with RTEMS 6.2 on
>>>> a Raspberry Pi 3B+ with rtems-libbsd  (6-freebsd-14) and
>>>> >>> > encountering a reproducible system hang after several minutes of
>>>> operation.
>>>> >>> > Through systematic elimination testing I've narrowed the root
>>>> cause to the
>>>> >>> > DWC OTG USB controller driver. I'd appreciate any recommendations
>>>> on how
>>>> >>> > to address this. I can of course use the EPICS ioc server under
>>>> linux on RPi but just tried to have the RTEMS - Hard real time system which
>>>> is much more deterministic.
>>>> >>> > The boot time for the RPi with EPICS/RTEMS is around 7 sec which
>>>> is extremely fast!
>>>> >>> > Environment
>>>> >>> > - Board: Raspberry Pi 3B+ (BCM2837, boardrev a020d3)
>>>> >>> > - RTEMS: rtems-6.2 (ARM/ARMv4/raspberrypi2)
>>>> >>> > - Network stack: rtems-libbsd (RTEMS_BSD_CONFIG_BSP_CONFIG +
>>>> RTEMS_BSD_CONFIG_INIT)
>>>> >>> > - Ethernet: LAN7515 USB Ethernet (muge driver, via DWC OTG)
>>>> >>> > - Application: EPICS IOC (but hang occurs with minimal/empty IOC
>>>> as well)
>>>> >>> > - Console: UART serial (/dev/ttyS0)
>>>> >>> > Symptom
>>>> >>> > The system boots and runs normally, then the entire system
>>>> freezes —
>>>> >>> > including the UART serial console (which is not USB-dependent).
>>>> No crash
>>>> >>> > message, no stack dump — a hard hang requiring power cycle.
>>>> >>> > The time-to-hang depends on the system tick rate:
>>>> >>> > - CONFIGURE_MICROSECONDS_PER_TICK=500  (2 kHz): hangs after ~2
>>>> minutes
>>>> >>> > - CONFIGURE_MICROSECONDS_PER_TICK=10000 (100 Hz): hangs after
>>>> ~5-6 minutes
>>>> >>> > During the hang, the UART becomes completely unresponsive,
>>>> suggesting a
>>>> >>> > kernel-level deadlock or interrupt handler issue rather than an
>>>> >>> > application-level problem.
>>>> >>> > Elimination testing performed
>>>> >>> > I systematically disabled components to isolate the cause. All
>>>> tests below
>>>> >>> > used CONFIGURE_MICROSECONDS_PER_TICK=10000 (100 Hz):
>>>> >>> > 1. Disabled all EPICS database records (no record processing) ->
>>>> still hangs
>>>> >>> > 2. Disabled periodic NTP sync (no socket operations) -> still
>>>> hangs
>>>> >>> > 3. Disabled IP configuration (no ifconfig, no route, no network
>>>> traffic,
>>>> >>> >    but USB/DWC OTG still initialised via
>>>> RTEMS_BSD_CONFIG_BSP_CONFIG)
>>>> >>> >    -> still hangs (~5-6 min), USB hub enumeration continues in
>>>> background:
>>>> >>> >       ugen1.2: <vendor 0x0424 product 0x2514> at usbus1
>>>> >>> >       uhub1 on uhub0
>>>> >>> >    Console output is garbled by concurrent USB enumeration
>>>> messages,
>>>> >>> >    suggesting interrupt contention.
>>>> >>> > 4. Commented out RTEMS_BSD_CONFIG_BSP_CONFIG and the
>>>> >>> >    #include <bsp/nexus-devices.h> to prevent DWC OTG
>>>> initialisation
>>>> >>> >    -> STABLE, ran for 14+ minutes with no hang (test stopped
>>>> manually)
>>>> >>> > The libbsd software stack (loopback, sockets, telnetd) continues
>>>> to
>>>> >>> > function in test 4 — only the hardware BSP devices (DWC OTG, muge,
>>>> >>> > uhub, ukphy) are excluded.
>>>> >>> > Minimal reproduction
>>>> >>> > Build an RTEMS 6.2 application for raspberrypi2 BSP with:
>>>> >>> >   #define RTEMS_BSD_CONFIG_BSP_CONFIG
>>>> >>> >   #define RTEMS_BSD_CONFIG_INIT
>>>> >>> >   #include <machine/rtems-bsd-config.h>
>>>> >>> >   #include <bsp/nexus-devices.h>     /* in one translation unit */
>>>> >>> >   #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>>>> >>> > The application does not need to configure any network interface
>>>> or
>>>> >>> > perform any USB transfers — the DWC OTG hub polling alone triggers
>>>> >>> > the hang after ~5-6 minutes.
>>>> >>> > Commenting out RTEMS_BSD_CONFIG_BSP_CONFIG and the nexus-devices.h
>>>> >>> > include eliminates the hang.
>>>> >>> > Boot log (abbreviated, from hanging configuration)
>>>> >>> > RTEMS RPi 3B+ 1.3 (1GB) [00a020d3]
>>>> >>> > nexus0: <RTEMS Nexus device>
>>>> >>> > dwcotg0: <DWC OTG 2.0 integrated USB controller> on nexus0
>>>> >>> > usbus1 on dwcotg0
>>>> >>> > usbus1: 480Mbps High Speed USB v2.0
>>>> >>> > ugen1.1: <DWCOTG OTG Root HUB> at usbus1
>>>> >>> > uhub0 on usbus1
>>>> >>> > uhub0: <DWCOTG OTG Root HUB, class 9/0, rev 2.00/1.00, addr 1> on
>>>> usbus1
>>>> >>> > uhub0: 1 port with 1 removable, self powered
>>>> >>> > uhub1 on uhub0
>>>> >>> > uhub1: <vendor 0x0424 product 0x2514, class 9/0, rev 2.00/b.b3,
>>>> addr 2> on usbus1
>>>> >>> > uhub1: 4 ports with 3 removable, self powered
>>>> >>> > ugen1.3: <vendor 0x0424 product 0x2514> at usbus1
>>>> >>> > uhub2 on uhub1
>>>> >>> > uhub2: <vendor 0x0424 product 0x2514, class 9/0, rev 2.00/b.b3,
>>>> addr 3> on usbus1
>>>> >>> > uhub2: 3 ports with 2 removable, self powered
>>>> >>> > ugen1.4: <vendor 0x0424 product 0x7800> at usbus1
>>>> >>> > muge0: <vendor 0x0424 product 0x7800, rev 2.10/3.00, addr 4> on
>>>> usbus1
>>>> >>> > muge0: Chip ID 0x7800 rev 0002
>>>> >>> > miibus0: <MII bus> on muge0
>>>> >>> > ukphy0: <Generic IEEE 802.3u media interface> PHY 1 on miibus0
>>>> >>> > info: ue0: <USB Ethernet> on muge0
>>>> >>> > [system hangs after ~5-6 minutes, UART unresponsive]
>>>> >>> > Questions
>>>> >>> > 1. Is this a known issue with the DWC OTG driver on RPi 3B+?
>>>> >>> > 2. Are there any configuration options (hub polling interval,
>>>> interrupt
>>>> >>> >    coalescing, DMA settings) that might work around the problem?
>>>> >>> > 3. Would a newer version of rtems-libbsd contain fixes for this?
>>>> >>> > 4. Is there an alternative Ethernet driver approach for RPi 3B+
>>>> that
>>>> >>> >    avoids the DWC OTG USB path?
>>>> >>> > 5. Is there any known project which uses RPi with RTEMS?
>>>> >>> > (it looks like that the option to run RTEMS on RPi4 or RPi 5 can
>>>> not be considered since the BSP in RTEMS kernel  is not yet finalised.
>>>> >>> > The RPi4 or RPi 5 would be much better candidates vs RPi 3 B+
>>>> since they use direct connection to Ethernet instead of the USB-Ethernet)
>>>> >>> > Thank you for any guidance.
>>>> >>> > Mirek
>>>> >>> > _______________________________________________
>>>> >>> > users mailing list
>>>> >>> > users at rtems.org
>>>> >>> > http://lists.rtems.org/mailman/listinfo/users
>>>> > users mailing list
>>>> > users at rtems.org
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20261017/68101d69/attachment-0001.htm>
