About cache enabling in LWIP port of BBB in RTEMS
Marcos Díaz marcos.diaz at tallertechnologies.com
Thu Sep 17 19:05:05 UTC 2015
Ragu,
I would like you to confirm which revision you have, for this I printed the
following registers in the BBB:
0x44E10600 and 0x44E10604
The first will print something like:
1b94402e for BBB rev A5C (XAM3359AZCZ100) ( 1b means rev.A of the
microcontroller)
2b94402e for BBB rev C  (AM3358BZCZ100) (2b means rev B of the
microcontroller)
The second register will print something like:
20ff0383 for A5c (this means that this is AM3359)
20fd0383 for C (this means it is an AM3358).
Please let me know which are this values in your Board.
Thanks!
On Thu, Sep 17, 2015 at 11:44 AM, Marcos Díaz <
marcos.diaz at tallertechnologies.com> wrote:
> Yes, sorry about that, There are two registers we can check to see the
> different revision numbers. I will check it myself once i confirm that the
> different revisions are the problem (i'm not sure because of what Ragu
> said). Thanks!
> On Thu, Sep 17, 2015 at 11:12 AM, Joel Sherrill <joel.sherrill at oarcorp.com
> > wrote:
>> On 9/17/2015 8:43 AM, Marcos Díaz wrote:
>>> Yes, in my case the older (that doesn't work) revision is a
>>> XAM3359AZCZ100
>>> And the rev C (that works well with cache) is
>>> AM3358BZCZ100
>> Can we determine that in software?
>> On Thu, Sep 17, 2015 at 10:32 AM, Joel Sherrill <
>>> joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>     On September 17, 2015 8:26:41 AM CDT, "Marcos Díaz" <
>>> marcos.diaz at tallertechnologies.com <mailto:
>>> marcos.diaz at tallertechnologies.com>> wrote:
>>>     >Hi,
>>>     >How did you see the revision number? if you are using u-boot you can
>>>     >pause the start and write printenv and enter to see that:
>>>     >board=am335x
>>>     >board_name=A335BNLT
>>>     >board_rev=00C0
>>>     >This is in my version.
>>>     >Please tell me so I can check if is the revision, or perhaps is
>>>     >something else in u-boot initialization.
>>>     >For the question Joel asked there is a way:
>>> http://dumb-looks-free.blogspot.com.ar/2014/05/beaglebone-black-bbb-revision-serial.html
>>>     >apparently, in the eeprom thorugh i2c it is recorded. But first we
>>> must
>>>     >confirm that is a problem from the revisions, since Ragu has the
>>>     >problem in a rev C.
>>>     Does the SoC itself have a revision number we can read? It may be
>>> that newer boards have a newer CPU.
>>>      >Greetings
>>>      >On Wed, Sep 16, 2015 at 7:22 PM, Joel Sherrill
>>>      ><joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>
>>> wrote:
>>>      >On 9/16/2015 2:41 PM, ragu nath wrote:
>>>      >Hi Marcos,
>>>      >Great news! I did not  find any solution to the issue. I have a
>>> REV C
>>>      >board from element14. Is this the same board you are using?  In my
>>>      >board I saw the issue.
>>>      >Does this have anything to do with the patch you submitted [PATCH]
>>>      >Beaglebone: fix missing clobber in inline assembly.
>>>      >https://lists.rtems.org/pipermail/devel/2015-September/012531.html
>>>      >I have not yet tested with this patch.
>>>      >The freebsd driver is working with cache disabled.  If possible pls
>>>      >check if it is working with cache enabled in your board.
>>>      >If this is a board revision related issue, is there a way
>>>      >programmatically to
>>>      >know which revision the board is? That way the BSP could
>>> auto-detect
>>>      >the right
>>>      >thing to do. Otherwise, we may be looking at a BSP variant or a
>>> build
>>>      >option.
>>>      >I would rather avoid those if we can auto-detect.
>>>      >--joel
>>>      >Thanks,
>>>      >Ragunath
>>>      >On Mon, Sep 14, 2015 at 7:22 PM, Marcos Díaz
>>>      ><marcos.diaz at tallertechnologies.com <mailto:
>>>      ><mailto:marcos.diaz at tallertechnologies.com <mailto:
>>> marcos.diaz at tallertechnologies.com>>> wrote:
>>>      >    Hi Ragu,
>>>      >I wanted to know if you were able to see something else about the
>>>      >problem we had in the BBB when using LWIP and enabling cache ( the
>>>      >program freezes).
>>>      >I can tell you that here we were using BBB rev. A5C and had this
>>>      >problem, but now we could test this with a BBB Rev C, and it
>>>      >successfully works with cache enabled (using the same sdcard in
>>> both
>>>      >boards, one works and the other doesn't).
>>>      >    Greetings
>>>      >    ______________________________
>>>      >    <http://www.tallertechnologies.com>
>>>      >    Marcos Díaz
>>>      >    Software Engineer
>>>      >    San Lorenzo 47, 3rd Floor, Office 5
>>>      >    Córdoba, Argentina
>>>      >    Phone:+54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>      >    Skype:markdiaz22
>>>      >ragu
>>>      >Joel Sherrill, Ph.D.             Director of Research & Development
>>>      >joel.sherrill at OARcorp.com        On-Line Applications Research
>>>      >Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>      >Support Available                (256) 722-9985
>>>      >Marcos Díaz
>>>      >Software Engineer
>>>      >Córdoba, Argentina
>>>      >Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>>>      >Skype: markdiaz22
>>>     --joel
>>> Marcos Díaz
>>> Software Engineer
>>> Córdoba, Argentina
>>> Skype:markdiaz22
> Marcos Díaz
> Software Engineer
> Córdoba, Argentina
> Skype: markdiaz22
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150917/45e8d473/attachment-0002.html>
