Policy for RSB branches for 4.9, 4.10 and 4.11
Sun Feb 28 01:06:20 UTC 2016
On Feb 27, 2016 5:08 PM, "Chris Johns" <chrisj at rtems.org> wrote:
> Hi,
> Should we create branches for 4.9 and 4.10 in the RSB repo?
> Should the 4.9, 4.10 and 4.11 build set files and config scripts be
> removed from master?
As long as we keep branches for them.
FWIW I wouldn't be opposed to RSB branches for even older releases if a
user submitted them.
> I do not see the point of maintaining the branches for releases and the
> master and I can see a situation where the 4.11 build on master, ie
> currently 4.12, is wrong but noticeable so.
If RTEMS has a branch, the RSB should follow. Master should be 4.12 only.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160227/d92c5269/attachment-0002.html>
