Add const Keyword to some function parameters in chainimpl.h
Andreas andreas.dachsberger at gmail.com
Fri Apr 5 06:51:35 UTC 2019
Hi there,
while reviewing the doxygen documentation in this file I found some
instances where I think the function parameters should be made constant.
Bellow my suggested changes:
commit 9fc61307be4f21039b7cd4553099e29e5fd5e456 (HEAD)
Author: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Date:   Fri Apr 5 08:28:08 2019 +0200
     Added const to function parameters.
cpukit/include/rtems/score/chainimpl.h | 28 ++++++++++++++--------------
1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/cpukit/include/rtems/score/chainimpl.h
b/cpukit/include/rtems/score/chainimpl.h
index 0b9c193044..264cbe094c 100644
--- a/cpukit/include/rtems/score/chainimpl.h
+++ b/cpukit/include/rtems/score/chainimpl.h
@@ -222,7 +222,7 @@ RTEMS_INLINE_ROUTINE const Chain_Node
*_Chain_Immutable_head(
   * @return This method returns the permanent tail node of the chain.
  RTEMS_INLINE_ROUTINE Chain_Node *_Chain_Tail(
-  Chain_Control *the_chain
+  const Chain_Control *the_chain
    return &the_chain->Tail.Node;
@@ -555,7 +555,7 @@ RTEMS_INLINE_ROUTINE void _Chain_Initialize_one(
   * @param[in] the_node is the node to be extracted.
  RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected(
-  Chain_Node *the_node
+  const Chain_Node *the_node
    Chain_Node *next;
@@ -858,10 +858,10 @@ typedef bool ( *Chain_Node_order )(
   * @param[in] order The order relation.
  RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(
-  Chain_Control    *the_chain,
-  Chain_Node       *to_insert,
-  const void       *left,
-  Chain_Node_order  order
+  Chain_Control          *the_chain,
+  Chain_Node             *to_insert,
+  const void             *left,
+  const Chain_Node_order  order
    const Chain_Node *tail = _Chain_Immutable_tail( the_chain );
@@ -960,7 +960,7 @@ RTEMS_INLINE_ROUTINE void
_Chain_Iterator_registry_initialize(
  RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update(
    Chain_Iterator_registry *the_registry,
-  Chain_Node              *the_node_to_extract
+  const Chain_Node        *the_node_to_extract
    Chain_Node *iter_node;
@@ -1046,10 +1046,10 @@ RTEMS_INLINE_ROUTINE void
   *   the linear time complexity in _Chain_Iterator_registry_update().
  RTEMS_INLINE_ROUTINE void _Chain_Iterator_initialize(
-  Chain_Iterator_registry  *the_registry,
-  Chain_Iterator           *the_iterator,
-  Chain_Iterator_direction  direction
+  const Chain_Control            *the_chain,
+  Chain_Iterator_registry        *the_registry,
+  Chain_Iterator                 *the_iterator,
+  const Chain_Iterator_direction  direction
    _Chain_Initialize_node( &the_iterator->Registry_node );
@@ -1093,8 +1093,8 @@ RTEMS_INLINE_ROUTINE Chain_Node *_Chain_Iterator_next(
   * @param the_node The new iterator position.
  RTEMS_INLINE_ROUTINE void _Chain_Iterator_set_position(
    the_iterator->position = the_node;
@@ -1108,7 +1108,7 @@ RTEMS_INLINE_ROUTINE void
   * @param the_iterator The chain iterator.
  RTEMS_INLINE_ROUTINE void _Chain_Iterator_destroy(
+  const Chain_Iterator *the_iterator
    _Chain_Extract_unprotected( &the_iterator->Registry_node );
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190405/54e809be/attachment.html>
