[PATCH v2] eng: Add Python development guidelines
Tue Mar 17 20:50:06 UTC 2020
v2:
* Fix grammar
* Recommend pytest instead of unittest
 eng/management.rst   |   1 +
 eng/python-devel.rst | 163 +++++++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 164 insertions(+)
 create mode 100644 eng/python-devel.rst
diff --git a/eng/management.rst b/eng/management.rst
index 064559c..6eb4217 100644
--- a/eng/management.rst
+++ b/eng/management.rst
@@ -16,5 +16,6 @@ Software Development Management
     vc-users
     vc-authors
     coding
+    python-devel
     change-management
     issue-tracking
diff --git a/eng/python-devel.rst b/eng/python-devel.rst
new file mode 100644
index 0000000..a36d95e
--- /dev/null
+++ b/eng/python-devel.rst
@@ -0,0 +1,163 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. _PythonDevelGuide:
+Python Development Guidelines
+Python is the main programming language for the RTEMS Tools.  The RTEMS Tools
+run on the host computer of an RTEMS user or maintainer.  These guidelines
+cover the Python language version, the source code formatting, use of static
+analysis tools, type annotations, testing, code coverage, and documentation.
+There are exceptions for existing code and third-party code.  It is recommended
+to read the
+`PEP 8 - Style Guide for Python Code <https://www.python.org/dev/peps/pep-0008/>`_
+and the
+`Google Python Style Guide <http://google.github.io/styleguide/pyguide.html>`_.
+Python Language Versions
+Although the official end-of-life of Python 2.7 was on January 1, 2020, the
+RTEMS Project still cares about Python 2.7 compatibility for some tools.  Every
+tool provided by the RTEMS Project which an RTEMS user may use to develop
+applications with RTEMS should be Python 2.7 compatible.  Examples are the
+build system, the RTEMS Source Builder, and the RTEMS Tester.  The rationale is
+that there are still some maintained Linux distributions in the wild which ship
+only Python 2.7 by default.  An example is CentOS 7 which gets maintenance
+updates until June 2024.  Everything an RTEMS maintainer uses should be written
+in Python 3.6.
+Python Code Formatting
+Good looking code is important.  Unfortunately, what looks good is a bit
+subjective and varies from developer to developer.  Arguing about the code
+format is not productive.  Code reviews should focus on more important topics,
+for example functionality, testability, and performance.  Fortunately, for
+Python there are some good automatic code formatters available.  All new code
+specifically developed for the RTEMS Tools should be piped through the
+`yapf <https://github.com/google/yapf>`_ Python code formatter before it is
+committed or sent for review.  Use the default settings of the tool
+(`PEP 8 <https://www.python.org/dev/peps/pep-0008/>`_ coding style).
+You can disable the automatic formatting by the tool in a region starting with
+the ``#yapf: disable`` comment until the next ``# yapf: enable`` comment, for
+example
+.. code-block:: python
+    # yapf: disable
+    FOO = {
+        # ... some very large, complex data literal.
+    BAR = [
+        # ... another large data literal.
+    # yapf: enable
+For a single literal, you can disable the formatting like this:
+    BAZ = {
+        (1, 2, 3, 4),
+        (5, 6, 7, 8),
+        (9, 10, 11, 12),
+    }  # yapf: disable
+Static Analysis Tools
+Use the ``flake8`` and ``pylint`` static analysis tools for Python.  Do not
+commit your code or send it for review if the tools find some rule
+violations.  Run the tools with the default configuration.  If you have
+problems to silence the tools, then please ask for help on the :r:list:`devel`.
+Consult the tool documentation to silence false positives.
+Type Annotations
+For Python 3.6 or later code use type annotations.  All public functions of
+your modules should have `PEP 484 <https://www.python.org/dev/peps/pep-0484/>`_
+type annotations.  Check for type issues with the
+`mypy <http://mypy-lang.org/>`_ static type checker.
+Testing
+Write tests for your code with the
+`pytest <https://docs.pytest.org/en/latest/contents.html>`_ framework.  Use the
+`monkeypatch <https://docs.pytest.org/en/latest/monkeypatch.html>`_ mocking
+module.  Do not use the standard Python ``unittest`` and ``unittest.mock``
+modules.  Use ``coverage run -m pytest`` to run the tests with code coverage
+support.  If you modify existing code or contribute new code to a subproject
+which uses tests and the code coverage metric, then do not make the code
+coverage worse.
+Test Organization
+Do not use test classes to group tests.  Use separate files instead.  Avoid
+deep test directory hierarchies.  For example, place tests for
+:file:`mymodule.py` in :file:`tests/test_mymodule.py`.  For class-specific
+tests use:
+* ``mymodule.py:class First`` :math:`\rightarrow`
+  :file:`tests/test_mymodule_first.py`
+* ``mymodule.py:class Second`` :math:`\rightarrow`
+  :file:`tests/test_mymodule_second.py`
+* ``mymodule.py:class Third`` :math:`\rightarrow`
+  :file:`tests/test_mymodule_third.py`
+You can also group tests in other ways, for example:
+* :file:`mymodule.py` :math:`\rightarrow` :file:`tests/test_mymodule_input.py`
+* :file:`mymodule.py` :math:`\rightarrow` :file:`tests/test_mymodule_output.py`
+Documentation
+Document your code using the
+`PEP 257 - Docstring Conventions <https://www.python.org/dev/peps/pep-0257/>`_.
+Contrary to PEP 257, use the descriptive-style
+(``"""Fetches rows from a Bigtable."""``) instead of imperative-style
+(``"""Fetch rows from a Bigtable."""``) as recommended by
+`Comments and Docstrings - Functions and Methods <http://google.github.io/styleguide/pyguide.html#383-functions-and-methods>`_.
+Use the
+`Sphinx <https://sphinx-rtd-tutorial.readthedocs.io/en/latest/docstrings.html>`_
+format.  The
+`sphinx-autodoc-typehints <https://pypi.org/project/sphinx-autodoc-typehints/>`_
+helps to reuse the type annotations for the documentation.  Test code does not
+need docstrings in general.
+Existing Code
+Existing code in the RTEMS Tools may not follow the preceding guidelines.  The
+RTEMS Project welcomes contributions which bring existing code in line with the
+guidelines.  Firstly, run the ``yapf`` code formatter through the existing code
+of interest.  Add ``# yapf: disable`` comments to avoid reformatting in some
+areas if it makes sense.  If the existing code has no unit tests, then add unit
+tests before you modify existing code by hand.  With the new unit tests aim at
+a good code coverage especially in the areas you intend to modify.  While you
+review the code add docstrings.  Run the static analysers and fix the rule
+violations.  Please keep in mind that also trivial modifications can break
+working code.  Make sure you have some unit tests.  Add type annotations unless
+the code should be Python 2.7 compatible.  Concentrate on the public
+interfaces.
+Third-Party Code
+Try to not modify imported third-party code.  In case there are issues with
+third-party code, then at least write a bug report or otherwise contact the
+upstream project.  Reimport the third-party code after the issue is fixed in
+the upstream project.  Only temporarily modify imported third-party code until
+a solution integrated in the upstream is available.
2.16.4
