[PATCH] user/gsoc: GSoC Getting Started Instructions
Mon Mar 30 19:37:05 UTC 2020
On Mon, Mar 30, 2020 at 12:17 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> Where should I put the additional instructions for creating and sending patches?
All that can go in the GSoC directions, with pointers to the other
sections in the docs that support:
https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
> I will try to send a patch most probably by tomorrow evening.
> Meanwhile, can you have a look at the patch that I have sent?
> https://lists.rtems.org/pipermail/devel/2020-March/058716.html
> Thanks,
> Niteesh
> On Mon, Mar 30, 2020 at 9:40 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Sun, Mar 29, 2020 at 11:47 PM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > On 28/03/2020 19:47, Niteesh G. S. wrote:
>> > We have an Installation chapter under the User manual https://docs.rtems.org/branches/master/user/installation/index.html
>> > But it isn't detailed enough like the quick start guide. IMO it is the right place to add detailed instructions. It already has important
>> > information for a good setup like sandboxing, differences between a release and dev. version, host toolchain setup and more.
>> > Should we move all the details from quick-start chapter to the installation chapter and make the quick start guide simple enough for a
>> > student to begin with.
>> > We could add a subsection about GSoC under quick-start and ask the students to refer to the quick-start chapter.
>> > We should really try to consolidate the documentation. Having mostly the same stuff in different places is a maintenance problem. The intention of the Quick Start chapter is to get started quickly step by step on a simulator platform which is able to run the RTEMS test suite properly. You should be able to use it as a template for your desired target system. Getting started on a simulator platform should be the right thing for a GSoC student?
>> The concern is that the Quick Start includes a lot of extra material
>> that makes it not so "Quick" to use. There are also many decisions
>> that need to be made when following the quick start that makes it not
>> exactly a linear set of directions.
>> That said, I agree that consolidation is important. Niteesh, would you
>> be willing to draft a subsection in the Quick Start (maybe near the
>> beginning) that provides a set of instructions to walk-through the
>> remainder of the quick start oriented toward GSoC students, pointing
>> out the decision to make at each "decision point" -- such as, In
>> Section 2.3 use the "Git" instructions; in Section 2.6 use the "Manual
>> BSP Build", etc. These should be written as linked references to those
>> sections/subsection names.
>> Gedare
