#3860 - GSoC enquiries
Ida Delphine idadelm at gmail.com
Sun Apr 4 02:32:43 UTC 2021
Regarding adding a script similar to linux/checkpatch.pl the criteria
whether patches should need changes before being applied will be based on
the output from running uncrustify right?
On Sat, Apr 3, 2021 at 2:32 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Apr 2, 2021 at 6:09 PM Joel Sherrill <joel at rtems.org> wrote:
> > On Fri, Apr 2, 2021, 6:59 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Fri, Apr 2, 2021 at 4:48 PM Ida Delphine <idadelm at gmail.com> wrote:
> >> > Hello,
> >> > Please can you help explain what you mean by Adding a "check-style"
> target to the RTEMS build system?
> >> > And how I could possibly go about this?
> >> I don't know if this makes sense exactly to me.  When compiling RTEMS
> >> it could be nice to have an option to check the style rules for
> >> compliance. This would be something to integrate in the
> >> rtems.git/wscript file most likely, as part of the waf build system.
> >> However, since checking style does not generate a target file, I don't
> >> know that this really is suitable as a way to verify style rules. It
> >> may be suitable to add a standalone script in rtems-tools.git that can
> >> be run over the rtems.git that creates a report about style problems.
> >> Maybe, a way to configure it to ignore some files or to add exceptions
> >> to the style rules for certain cases then could be possible.
> > If you have a configuration that produces the code formatted as expected
> in certain directories, then if a change is made as part of normal
> development, running uncrustify will result in changes to the file needed.
> In a way the goal is to have a directory full of files that an RTEMS
> uncrustify configuration does not change.
> > If you have a script that can do that manually then we can easily add an
> automated check somewhere in the process to ensure that directories that
> adhere to the style rules continue to adhere to them.
> > One thing to keep in mind is that there there are places where
> uncrustify does not have the ability to format code the way RTEMS has
> historically done it. we want the rules to be as close as possible to the
> existing practice but we are willing to adjust practice if it allows the
> tool to produce formatted output we can trust.
> Also on the table could be modifications to uncrustify.
> > On each point where this type of issue occurs, we'll have to have a
> discussion about our Style versus what tool supports. It's likely indicates
> we're doing something that's not common in the open source world.
> > Once the delta between the output of uncrustify and the committed source
> is zero, running uncrustify should produce no changes. Anything uncrustify
> wants to change at that point would be a style violation and flagged. In a
> perfect world it would prevent you from committing.
> >> I think focus on 1 and 3 is better as a way to start, and perhaps
> >> something like the above can be the phase 2 effort.
> >> Gedare
> >> > Cheers,
> >> > Ida
> >> > On Mon, Mar 29, 2021 at 9:45 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> On Mon, Mar 29, 2021 at 1:28 PM Ida Delphine <idadelm at gmail.com>
> wrote:
> >> >> > Yes I have. But wondering how to run it with the given
> configuration I saw in this thread(
> https://lists.rtems.org/pipermail/devel/2020-October/062770.html).
> >> >> If you download/copy the configuration into a cfg file, then you can
> >> >> use the examples from
> >> >> https://github.com/uncrustify/uncrustify#running-the-program and
> >> >> attempt to run it on some files within rtems.git/cpukit/score/src
> >> >> would be my suggestion.
> >> >> > On Mon, Mar 29, 2021 at 3:37 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> >> Hi Ida,
> >> >> >> On Mon, Mar 29, 2021 at 7:36 AM Ida Delphine <idadelm at gmail.com>
> wrote:
> >> >> >> > Hello,
> >> >> >> > Please do you mind telling me how to run uncrustify with the
> given configuration with any sample file?
> >> >> >> What have you tried? Any directions followed/attempted or notes
> that
> >> >> >> you have taken would be helpful.
> >> >> >> I guess all the info that you should need is in Uncrustify's
> readme
> >> >> >> file. https://github.com/uncrustify/uncrustify
> >> >> >> Did you successfully compile uncrustify tool?
> >> >> >> > I'm a bit stuck.
> >> >> >> > Thanks,
> >> >> >> > Ida.
> >> >> >> > On Wed, Mar 17, 2021 at 10:34 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> >> >> On Wed, Mar 17, 2021 at 2:28 PM Ida Delphine <
> >> >> >> >> > Hello,
> >> >> >> >> > So I have gone through this configuration file and I think
> I'm getting it. However I'm a bit lost in the reading the messages in the
> thread. Do you mind explaining? Or we can start talking about a way forward.
> >> >> >> >> > Also can you help me with some steps on how to test this by
> myself if possible?
> >> >> >> >> It may be easier if you go "up" a level to see the full thread
> >> >> >> >> context:
> https://lists.rtems.org/pipermail/devel/2020-October/thread.html#62769
> >> >> >> >> Then you can go through the messages non-linearly. Right now,
> the
> >> >> >> >> basic idea is to follow the steps outlined in the open project
> ticket.
> >> >> >> >> I think Christian has summarized it nicely in his recent email
> [1]: "I
> >> >> >> >> think the contributions from this project that would add value
> would
> >> >> >> >> be:
> >> >> >> >> 1. Finding a tool and a configuration that can do an RTEMS
> style or an
> >> >> >> >> acceptable close one.
> >> >> >> >> 2. Adding a "check-style" target to our build system.
> >> >> >> >> 3. Maybe add some kind of script similar to Linux "
> checkpatch.pl" that
> >> >> >> >> could check whether patches would need changes _before_ they
> are
> >> >> >> >> applied.
> >> >> >> >> The proposal preparation phase should work through identifying
> the
> >> >> >> >> options and pros/cons for different tools while preparing a
> plan for
> >> >> >> >> how to integrate style checks in 2, 3 and thinking through the
> coding
> >> >> >> >> tasks for the summer.
> >> >> >> >> Getting the style checking tool's configuration to match with
> the
> >> >> >> >> RTEMS style will be some effort, and testing it out and
> submitting
> >> >> >> >> some patches based on it could be a good proposal activity
> also to
> >> >> >> >> build some confidence about the tools that will be used.
> >> >> >> >> We also have some Python style guidelines that might be worth
> >> >> >> >> addressing. Those are harder maybe, since the style
> refactoring might
> >> >> >> >> be challenging to review for correctness.
> >> >> >> >> For getting started, I would recommend that you try running
> uncrustify
> >> >> >> >> with the given configuration on some files in RTEMS, see what
> it
> >> >> >> >> results in. Play around.
> >> >> >> >> [1]
> https://lists.rtems.org/pipermail/devel/2021-March/065547.html
> >> >> >> >> -Gedare
> >> >> >> >> > Thanks,
> >> >> >> >> > Ida
> >> >> >> >> > On Mon, Mar 15, 2021 at 9:39 PM Gedare Bloom <
> >> >> >> >> >> See the related thread, and we'll have to discuss how to
> move forward.
> >> >> >> >> >> The existing approach provides an uncrustify script:
> https://lists.rtems.org/pipermail/devel/2020-October/062769.html
> >> >> >> >> >> On Sun, Mar 14, 2021 at 9:47 PM Ida Delphine <
> >> >> >> >> >> > Hello everyone,
> >> >> >> >> >> > This ticket(https://devel.rtems.org/ticket/3860) was
> proposed to me and I'm interested in it for GSoC.
> >> >> >> >> >> > The first task there is to find a code checker or
> formater that can produce results that match the RTEMS coding conventions.
> It also made mention some tools have been discussed in the past. Please I
> will love suggestions on possible tools I could use to achieve this.
> >> >> >> >> >> > Cheers,
> >> >> >> >> >> > Ida.
> >> >> >> >> >> > _______________________________________________
> >> >> >> >> >> > devel mailing list
> >> >> >> >> >> > devel at rtems.org
> >> >> >> >> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210404/2a750ae2/attachment-0001.html>
