[PATCH 6/6] rtems-docs: Edit commands to build first app
Tue Mar 16 15:17:05 UTC 2021
$ cd rtems-docs
$ grep -r "Creating a Patch" --exclude-dir=build
eng/vc-users.rts:Creating a Patch
On Tue, Mar 16, 2021 at 2:28 AM Ida Delphine <idadelm at gmail.com> wrote:
> Regarding the patch to add instructions on how to set up a  patch message in which file should I create this patch or make changes?
> On Mon, Mar 15, 2021 at 8:57 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Ida,
>> On Mon, Mar 15, 2021 at 1:50 PM Gedare Bloom <gedare at rtems.org> wrote:
>> > Hi Ida,
>> > did you send the same set of patches twice, or are there changes
>> > between the two sets?
>> Since I'm not quite sure what to look at here, please do me a favor
>> and send a new patchset with a -v2 indicator [1], and also set the
>> patch message to specify rtems-docs. git format patch supports to set
>> the prefix with:
>>      git format-patch HEAD^ --subject-prefix="PATCH rtems-docs"
>> You can also create an alias to make this simpler [2]. In fact, if you
>> can send a patch to add instructions how to set up patch message with
>> the repo name to the text at [1] that would be another nice
>> contribution :)
>> [1] https://docs.rtems.org/branches/master/eng/vc-users.html#creating-a-patch
>> [2] https://lists.rtems.org/pipermail/devel/2020-April/059308.html
>> Thank you,
>> Gedare
>> > On Sun, Mar 14, 2021 at 8:26 PM Ida Delphine <idadelm at gmail.com> wrote:
>> > >  user/start/app.rst | 104 ++++++++++++++++++++++-----------------------
>> > >  1 file changed, 52 insertions(+), 52 deletions(-)
>> > > diff --git a/user/start/app.rst b/user/start/app.rst
>> > > index 8900f78..c343551 100644
>> > > --- a/user/start/app.rst
>> > > +++ b/user/start/app.rst
>> > > @@ -8,7 +8,7 @@ Build Your Application
>> > >  You tested a BSP in the previous section.  We built the ``erc32`` BSP
>> > > -and it is installed under :file:`$HOME/quick-start/rtems/5`.
>> > > +and it is installed under :file:`$HOME/quick-start/rtems/6`.
>> > >  We will now create a simple Hello World application with a Git
>> > >  repository and using the `Waf <https://waf.io>`_ build system.
>> > > @@ -107,7 +107,7 @@ and copy the Waf script:
>> > >      from __future__ import print_function
>> > > -    rtems_version = "5"
>> > > +    rtems_version = "6"
>> > >      try:
>> > >          import rtems_waf.rtems as rtems
>> > > @@ -142,52 +142,52 @@ Configure the application using Waf's ``configure`` command:
>> > >  .. code-block:: none
>> > > -    ./waf configure --rtems=$HOME/quick-start/rtems/5 --rtems-bsp=sparc/erc32
>> > > +    ./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32 --rtems-version=6
>> > >  The output will be something close to:
>> > > -     Setting top to                           : $BASE/app/hello
>> > > -     Setting out to                           : $BASE/app/hello/build
>> > > -     RTEMS Version                            : 5
>> > > -     Architectures                            : sparc-rtems5
>> > > -     Board Support Package (BSP)              : sparc-rtems5-erc32
>> > > -     Show commands                            : no
>> > > -     Long commands                            : no
>> > > -     Checking for program 'sparc-rtems5-gcc'  : $BASE/rtems/5/bin/sparc-rtems5-gcc
>> > > -     Checking for program 'sparc-rtems5-g++'  : $BASE/rtems/5/bin/sparc-rtems5-g++
>> > > -     Checking for program 'sparc-rtems5-ld'   : $BASE/rtems/5/bin/sparc-rtems5-ld
>> > > -     Checking for program 'sparc-rtems5-ar'   : $BASE/rtems/5/bin/sparc-rtems5-ar
>> > > -     Checking for program 'sparc-rtems5-nm'   : $BASE/rtems/5/bin/sparc-rtems5-nm
>> > > -     Checking for program 'sparc-rtems5-objdump' : $BASE/rtems/5/bin/sparc-rtems5-objdump
>> > > -     Checking for program 'sparc-rtems5-objcopy' : $BASE/rtems/5/bin/sparc-rtems5-objcopy
>> > > -     Checking for program 'sparc-rtems5-readelf' : $BASE/rtems/5/bin/sparc-rtems5-readelf
>> > > -     Checking for program 'sparc-rtems5-strip'   : $BASE/rtems/5/bin/sparc-rtems5-strip
>> > > -     Checking for program 'sparc-rtems5-ranlib'  : $BASE/rtems/5/bin/sparc-rtems5-ranlib
>> > > -     Checking for program 'rtems-ld'             : $BASE/rtems/5/bin/rtems-ld
>> > > -     Checking for program 'rtems-tld'            : $BASE/rtems/5/bin/rtems-tld
>> > > -     Checking for program 'rtems-syms'           : $BASE/rtems/5/bin/rtems-syms
>> > > -     Checking for program 'rtems-bin2c'          : $BASE/rtems/5/bin/rtems-bin2c
>> > > -     Checking for program 'tar'                  : /usr/bin/tar
>> > > -     Checking for program 'gcc, cc'              : $BASE/rtems/5/bin/sparc-rtems5-gcc
>> > > -     Checking for program 'ar'                   : $BASE/rtems/5/bin/sparc-rtems5-ar
>> > > -     Checking for program 'g++, c++'             : $BASE/rtems/5/bin/sparc-rtems5-g++
>> > > -     Checking for program 'gas, gcc'             : $BASE/rtems/5/bin/sparc-rtems5-gcc
>> > > -     Checking for c flags '-MMD'                 : yes
>> > > -     Checking for cxx flags '-MMD'               : yes
>> > > -     Compiler version (sparc-rtems5-gcc)         : 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
>> > > -     Checking for a valid RTEMS BSP installation : yes
>> > > -     Checking for RTEMS_DEBUG                    : no
>> > > -     Checking for RTEMS_MULTIPROCESSING          : no
>> > > -     Checking for RTEMS_NEWLIB                   : yes
>> > > -     Checking for RTEMS_POSIX_API                : yes
>> > > -     Checking for RTEMS_SMP                      : no
>> > > -     Checking for RTEMS_NETWORKING               : no
>> > > -     'configure' finished successfully (0.686s)
>> > > +    Setting top to                           : $BASE/app/hello
>> > > +    Setting out to                           : $BASE/app/hello/build
>> > > +    RTEMS Version                            : 6
>> > > +    Architectures                            : sparc-rtems6
>> > > +    Board Support Package (BSP)              : sparc-rtems6-erc32
>> > > +    Show commands                            : no
>> > > +    Long commands                            : no
>> > > +    Checking for program 'sparc-rtems6-gcc'  : $BASE/rtems/6/bin/sparc-rtems6-gcc
>> > > +    Checking for program 'sparc-rtems6-g++'  : $BASE/rtems/6/bin/sparc-rtems6-g++
>> > > +    Checking for program 'sparc-rtems6-ld'   : $BASE/rtems/6/bin/sparc-rtems6-ld
>> > > +    Checking for program 'sparc-rtems6-ar'   : $BASE/rtems/6/bin/sparc-rtems6-ar
>> > > +    Checking for program 'sparc-rtems6-nm'   : $BASE/rtems/6/bin/sparc-rtems6-nm
>> > > +    Checking for program 'sparc-rtems6-objdump' : $BASE/rtems/6/bin/sparc-rtems6-objdump
>> > > +    Checking for program 'sparc-rtems6-objcopy' : $BASE/rtems/6/bin/sparc-rtems6-objcopy
>> > > +    Checking for program 'sparc-rtems6-readelf' : $BASE/rtems/6/bin/sparc-rtems6-readelf
>> > > +    Checking for program 'sparc-rtems6-strip'   : $BASE/rtems/6/bin/sparc-rtems6-strip
>> > > +    Checking for program 'sparc-rtems6-ranlib'  : $BASE/rtems/6/bin/sparc-rtems6-ranlib
>> > > +    Checking for program 'rtems-ld'             : $BASE/rtems/6/bin/rtems-ld
>> > > +    Checking for program 'rtems-tld'            : $BASE/rtems/6/bin/rtems-tld
>> > > +    Checking for program 'rtems-syms'           : $BASE/rtems/6/bin/rtems-syms
>> > > +    Checking for program 'rtems-bin2c'          : $BASE/rtems/6/bin/rtems-bin2c
>> > > +    Checking for program 'tar'                  : /usr/bin/tar
>> > > +    Checking for program 'gcc, cc'              : $BASE/rtems/6/bin/sparc-rtems6-gcc
>> > > +    Checking for program 'ar'                   : $BASE/rtems/6/bin/sparc-rtems6-ar
>> > > +    Checking for program 'g++, c++'             : $BASE/rtems/6/bin/sparc-rtems6-g++
>> > > +    Checking for program 'gas, gcc'             : $BASE/rtems/6/bin/sparc-rtems6-gcc
>> > > +    Checking for c flags '-MMD'                 : yes
>> > > +    Checking for cxx flags '-MMD'               : yes
>> > > +    Compiler version (sparc-rtems6-gcc)         : 10.2.1 20210309 (RTEMS 6, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
>> > > +    Checking for a valid RTEMS BSP installation : yes
>> > > +    Checking for RTEMS_DEBUG                    : no
>> > > +    Checking for RTEMS_MULTIPROCESSING          : no
>> > > +    Checking for RTEMS_NEWLIB                   : yes
>> > > +    Checking for RTEMS_POSIX_API                : no
>> > > +    Checking for RTEMS_SMP                      : no
>> > > +    Checking for RTEMS_NETWORKING               : no
>> > > +    'configure' finished successfully (1.142s)
>> > >  Build the application:
>> > > @@ -199,24 +199,24 @@ The output will be something close to:
>> > > -    Waf: Entering directory `$BASE/app/hello/build/sparc-rtems5-erc32'
>> > > +    Waf: Entering directory `$BASE/app/hello/build/sparc-rtems6-erc32'
>> > >      [1/3] Compiling init.c
>> > >      [2/3] Compiling hello.c
>> > > -    [3/3] Linking build/sparc-rtems5-erc32/hello.exe
>> > > -    Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems5-erc32'
>> > > -    'build-sparc-rtems5-erc32' finished successfully (0.183s)
>> > > +    [3/3] Linking build/sparc-rtems6-erc32/hello.exe
>> > > +    Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems6-erc32'
>> > > +    'build-sparc-rtems6-erc32' finished successfully (0.183s)
>> > >  Run the executable:
>> > > -    $HOME/quick-start/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
>> > > +    $HOME/quick-start/rtems/6/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems6-erc32/hello.exe
>> > > -    RTEMS Testing - Run, 5.1.0
>> > > +    RTEMS Testing - Run, 6
>> > >       Command Line: $BASE/rtems/5/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems5-erc32/hello.exe
>> > >       Host: FreeBSD hihi 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
>> > >       Python: 3.7.6 (default, Jan 30 2020, 01:18:54) [Clang 6.0.1 (tags/RELEASE_601/final 335540)]
>> > > @@ -232,10 +232,10 @@ The output will be something close to:
>> > >      Hello World
>> > >      *** FATAL ***
>> > > -    fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
>> > > +    fatal source: 6 (RTEMS_FATAL_SOURCE_EXIT)
>> > >      fatal code: 0 (0x00000000)
>> > > -    RTEMS version: 5.1.0
>> > > -    RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib fbaa096)
>> > > +    RTEMS version: 6
>> > > +    RTEMS tools: 7.5.0 20191114 (RTEMS 6, RSB 6, Newlib fbaa096)
>> > >      executing thread ID: 0x08a010001
>> > >      executing thread name: UI1
>> > >      cpu 0 in error mode (tt = 0x101)
>> > > 2.25.1
>> > > _______________________________________________
>> > > devel mailing list
>> > > devel at rtems.org
>> > > http://lists.rtems.org/mailman/listinfo/devel
