[PATCH rtems-docs] user/imx: Add i.MX6UL/ULL.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Apr 14 07:31:48 UTC 2020
On 02/04/2020 16:56, Christian Mauderer wrote:
> On 02/04/2020 16:53, Gedare Bloom wrote:
>> PS: how do you get the repo inlined to the [PATCH xxx] subject line? It's handy.
> git format patch supports to set the prefix with:
>      git format-patch HEAD^ --subject-prefix="PATCH rtems-docs"
> I haven't found a good method yet to set it automatically to the repo
> name. But With the growing number of repositories in RTEMS I try to add
> the prefixes when not comiting to the core.
I found a nicer solution with some help from Stackoverflow:
    git config --global alias.format-patch-repo '!git format-patch
--subject-prefix="PATCH $(basename $(git rev-parse --show-toplevel))"'
This adds an alias that automatically adds the folder name of the
repository. It can be used with
    git format-patch-repo HEAD^
If you only work in one directory, an alternative is to set the
format.subjectPrefix option in the repository.
Best regards
Christian
>> On Thu, Apr 2, 2020 at 8:51 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Thu, Apr 2, 2020 at 8:43 AM Christian Mauderer
>>> <christian.mauderer at embedded-brains.de> wrote:
>>>> Update #3869
>>>>  user/bsps/arm/imx.rst | 49 ++++++++++++++++++++++++++++++++++++++++++++++---
>>>>  1 file changed, 46 insertions(+), 3 deletions(-)
>>>> diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
>>>> index bc93ae3..51c3b7e 100644
>>>> --- a/user/bsps/arm/imx.rst
>>>> +++ b/user/bsps/arm/imx.rst
>>>> @@ -7,9 +7,10 @@ imx (NXP i.MX)
>>>>  This BSP offers only one variant, the `imx7`.  This variant supports the i.MX
>>>> -7Dual processor.  The basic hardware initialization is not performed by the
>>>> -BSP.  A boot loader with device tree support must be used to start the BSP,
>>>> -e.g. U-Boot.
>>>> +7Dual processor and the i.MX 6UL/ULL processor family (with slightly different
>>>> +clock settings).  The basic hardware initialization is not performed by the BSP.
>>>> +A boot loader with device tree support must be used to start the BSP, e.g.
>>>> +U-Boot or barebox.
>>>>  Build Configuration Options
>>>> @@ -40,9 +41,30 @@ The following options are available at the configure command line.
>>>>  ``IMX_CCM_UART_HZ``
>>>>     The UART clock frequency in Hz (default is 24000000).
>>>> +``IMX_CCM_ECSPI_HZ``
>>>> +   The ECSPI clock frequency in Hz (default is 67500000).
>>>>  ``IMX_CCM_AHB_HZ``
>>>>     The AHB clock frequency in Hz (default is 135000000).
>>>> +``IMX_CCM_SDHCI_HZ``
>>>> +   The SDHCI clock frequency in Hz (default is 196363000).
>>>> +Clock settings for different boards
>>>> +The default clock settings are targeted for an i.MX 7Dual evaluation board using
>>>> +U-Boot. Some other boards with different boot loaders need different settings:
>>>> + * Phytec phyCORE-i.MX 6ULL (system on module) with MCIMX6Y2CVM08AB and a
>>>> +   barebox bootloader (version ``2019.01.0-bsp-yocto-i.mx6ul-pd19.1.0``):
>>>> +   * IMX_CCM_IPG_HZ=66000000
>>>> +   * IMX_CCM_UART_HZ=80000000
>>>> +   * IMX_CCM_AHB_HZ=66000000
>>>> +   * IMX_CCM_SDHCI_HZ=198000000
>>>> +   * IMX_CCM_ECSPI_HZ=60000000
>>>>  Boot via U-Boot
>>>> @@ -65,6 +87,14 @@ The ``loadfdt`` command may be not defined in your U-Boot environment.  Just
>>>>  replace it with the appropriate commands to load the device tree at
>>>>  ``${fdt_addr}``.
>>>> +Boot via barebox
>>>> +The same command like for U-Boot can be used to generate an application image.
>>>> +In a default configuration barebox expects an fdt image called `oftree` and a
>>>> +kernel image called `zImage` in the root folder of the bootable medium (e.g. an
>>>> +SD card).
>>>>  Clock Driver
>>>> @@ -133,6 +163,18 @@ system controls:
>>>>  A value of zero for the time or count disables the interrupt coalescing in the
>>>>  corresponding direction.
>>>> +On the Phytec phyCORE-i.MX 6ULL modules the PHY needs an initialization for the
>>>> +clock. A special PHY driver handles that (``ksz8091rnb``). Add it to your libbsd
>>>> +config like that:
>>>> +.. code-block:: c
>>>> +    #define RTEMS_BSD_CONFIG_BSP_CONFIG
>>>> +    #define RTEMS_BSD_CONFIG_INIT
>>>> +    SYSINIT_DRIVER_REFERENCE(ksz8091rnb, miibus);
>>>> +    #include <machine/rtems-bsd-config.h>
>>> Is the extra space needed here?
>>>>  MMC/SDCard Driver
>>>> @@ -147,3 +189,4 @@ Caveats
>>>>  The clock and pin configuration support is quite rudimentary and mostly relies
>>>>  on the boot loader.  For a pin group configuration see
>>>>  ``imx_iomux_configure_pins()``.  There is no power management support.
>>> Many docs end without the blank line. It does cause git to complain.
>>> I'm not sure if we have any rule about it for writing docs.
>>>> 2.16.4
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
