[PATCH] bsps/raspberrypi/console: Fix default console device
Niteesh G. S. niteesh.gs at gmail.com
Thu May 20 04:51:37 UTC 2021
ping.
On Tue, May 11, 2021 at 1:09 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> Hello Gedare,
> On Mon, May 10, 2021 at 8:57 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, May 6, 2021 at 8:49 AM Niteesh G. S. <niteesh.gs at gmail.com>
>> wrote:
>> > Hi Alan,
>> > On Thu, May 6, 2021 at 6:12 PM Alan Cudmore <alan.cudmore at gmail.com>
>> wrote:
>> >> Hi Niteesh,
>> >> I was hoping to try this out as soon as I get some time. No later than
>> weekend. So if nobody else is able to check it out, I will be able to
>> provide some feedback soon.
>> >> I should be able to bring up the console on a RPi Zero W and RPi3,
>> correct?
>> > the consoles should work on Zero W and Pi3 by default. They only fail
>> to work when  CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> > this option is used. This is because when that option is used it calls
>> console_initialize which checks if any boot options were present if none
>> were
>> > given it defaults to pl011 which is the secondary UART in Zero w and
>> Pi3 so we get no output. This patch defaults to the primary UART instead of
>> > pl011 depending on the board.
>> > Also, this patch should be applied on RTEMS 5 since we started
>> supporting Pi3 and Zero w from RTEMS 5.
>> You'll need to provide a separate patch with a ticket to close on 5
>> for a backport. Wait until you get the approval for the master branch
>> though.
> OK. I'll create a ticket and request for a backport once this is pushed on
> to the current master
> Thanks,
> Niteesh.
>> > Thanks,
>> > Niteesh.
>> >> Thanks,
>> >> Alan
>> >> From: Niteesh G. S.
>> >> Sent: Thursday, May 6, 2021 4:29 AM
>> >> To: Joel Sherrill; Christian Mauderer
>> >> Cc: rtems-devel at rtems.org
>> >> Subject: Re: [PATCH] bsps/raspberrypi/console: Fix default console
>> device
>> >> ping.
>> >> On Sat, May 1, 2021 at 9:47 PM Niteesh G. S. <niteesh.gs at gmail.com>
>> wrote:
>> >> On Sat, May 1, 2021 at 8:31 PM Joel Sherrill <joel at rtems.org> wrote:
>> >> On Sat, May 1, 2021, 8:53 AM Niteesh G. S. <niteesh.gs at gmail.com>
>> wrote:
>> >> Just to provide more context,
>> >> When the CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER option is used
>> >> and no --console option is provided, the console driver defaults to
>> PL011.
>> >> In raspberry pi 3 and other models whose primary UART is not PL011, we
>> get no output.
>> >> This patch fixes that by linking the primary UART to the console
>> device.
>> >> Thanks,
>> >> Niteesh
>> >> On Sat, May 1, 2021 at 7:05 PM G S Niteesh Babu <niteesh.gs at gmail.com>
>> wrote:
>> >> When no console argument is given, the driver defaults to pl011
>> >> this results in no output in case of Rpi3 whose primary uart is
>> >> miniuart.
>> >> This patch fixes that by defaulting to the primary uart when no
>> >> console option is provided.
>> >> Does the default need to vary by model?
>> >> Yes, the primary UART is different across models.
>> >> Rpi's have two UARTs PL011 and miniuart, on models which have Bluetooth
>> >> the PL011 is used to talk to the Bluetooth and miniuart acts as the
>> primary UART.
>> >> Now we can change this by adding miniuart-bt to config.txt but the
>> miniuart is
>> >> based on the VPU core and requires to add another option which sets
>> the core to
>> >> a fixed freq.
>> >>  bsps/arm/raspberrypi/console/console-config.c | 12 +++++++++---
>> >>  1 file changed, 9 insertions(+), 3 deletions(-)
>> >> diff --git a/bsps/arm/raspberrypi/console/console-config.c
>> b/bsps/arm/raspberrypi/console/console-config.c
>> >> index 6b8eb80aa4..bd3a8d34c2 100644
>> >> --- a/bsps/arm/raspberrypi/console/console-config.c
>> >> +++ b/bsps/arm/raspberrypi/console/console-config.c
>> >> @@ -165,10 +165,16 @@ static void console_select( void )
>> >>    }else {
>> >> -     * If no command line option was given, default to PL011.
>> >> +     * If no console option was given we default to the primary uarts.
>> >> +     * The initialization of the uart's and BSP_output_char is
>> already done
>> >> +     * in the uart_probe function called before this. So now we can
>> safely
>> >> +     * compare BSP_output_char.
>> >> -    BSP_output_char = output_char_pl011;
>> >> -    link(PL011, CONSOLE_DEVICE_NAME);
>> >> +    if (BSP_output_char == output_char_pl011) {
>> >> +      link(PL011, CONSOLE_DEVICE_NAME);
>> >> +    }else {
>> >> +      link(MINIUART, CONSOLE_DEVICE_NAME);
>> >> 2.17.1
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210520/9a03baca/attachment.html>
