Fwd: [rtems-bsp-builder] 2023-07-31 17:37:34: Profile(s): everything
Joel Sherrill joel.sherrill at gmail.com
Tue Aug 1 13:55:27 UTC 2023
I think this started before the fix was pushed but since there is no hash
in this report, it is impossible to be sure.
Since it already has to know about the rtems source tree, could it include
a hash? How hard is that to implement?
--joel
---------- Forwarded message ---------
From: OAR Tester for CentOS 7 <rtems-tester at oarcorp.com>
Date: Tue, Aug 1, 2023 at 5:24 AM
Subject: [rtems-bsp-builder] 2023-07-31 17:37:34: Profile(s): everything
To: <build at rtems.org>
RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
Host: #1 SMP Tue Jun 20 11:48:01 UTC 2023
command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
         --rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
         /rtems-cron-6/build --prefix=/home/tester/rtems-\
         cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
         builder.log --warnings-report=warnings.log --mail --use-gitconfig\
         --profiles=everything
Total Time            : 6:57:10.027015 for 1298 completed job(s)
Average BSP Build Time: 0:00:19.283533
Builds
 debug
 no-posix
 posix
 posix-debug
 posix-profiling
 profiling
 smp
 smp-debug
Failures Report
   1 debug arm/beagleboardorig build:
      configure: /home/tester/rtems-cron-6/rtems/waf configure\
      --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardorig-\
      debug.ini
     error: home/tester/bsps/arm/beagle/include/bsp/am335x_dcan.h:42:10:
            fatal error: dev/can/can.h: No such file or directory
     error: home/tester/bsps/arm/beagle/dcan/am335x-dcan.c:37:10: fatal
   2 no-posix arm/beagleboardorig build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardorig-no-\
      posix.ini
   3 posix arm/beagleboardorig build:
      posix.ini
   4 posix-debug arm/beagleboardorig build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardorig-posix-\
      debug.ini
   5 posix-profiling arm/beagleboardorig build:
      profiling.ini
   6 profiling arm/beagleboardorig build:
      profiling.ini
   7 debug arm/beagleboardxm build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardxm-\
      debug.ini
   8 no-posix arm/beagleboardxm build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardxm-no-\
      posix.ini
   9 posix arm/beagleboardxm build:
      posix.ini
  10 posix-debug arm/beagleboardxm build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardxm-posix-\
      debug.ini
  11 posix-profiling arm/beagleboardxm build:
      profiling.ini
  12 profiling arm/beagleboardxm build:
      profiling.ini
  13 debug arm/beagleboneblack build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboneblack-\
      debug.ini
  14 no-posix arm/beagleboneblack build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboneblack-no-\
      posix.ini
  15 posix arm/beagleboneblack build:
      posix.ini
  16 posix-debug arm/beagleboneblack build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beagleboneblack-posix-\
      debug.ini
  17 posix-profiling arm/beagleboneblack build:
      profiling.ini
  18 profiling arm/beagleboneblack build:
      profiling.ini
  19 debug arm/beaglebonewhite build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beaglebonewhite-\
      debug.ini
  20 no-posix arm/beaglebonewhite build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beaglebonewhite-no-\
      posix.ini
  21 posix arm/beaglebonewhite build:
      posix.ini
  22 posix-debug arm/beaglebonewhite build:
      /rtems-cron-6/rtems --rtems-config=config-arm-beaglebonewhite-posix-\
      debug.ini
  23 posix-profiling arm/beaglebonewhite build:
      profiling.ini
  24 profiling arm/beaglebonewhite build:
      profiling.ini
Warnings Report
 | By Architecture (total : 10173)                                     |
 | common : 13 warning(s)                                              |
 |   Shared :  738 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  144 |                |                 |
 | arm : 57 warning(s)                                                 |
 |   Shared :  192 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  208 |                |                 |
 | bfin : 32 warning(s)                                                |
 |   Shared :  138 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  234 | CPU Kit :   90 |                |                 |
 | i386 : 31 warning(s)                                                |
 |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   36 |                |                 |
 | lm32 : 14 warning(s)                                                |
 |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   72 |                |                 |
 | m68k : 33 warning(s)                                                |
 |   Shared :  936 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  330 |                |                 |
 | microblaze : 0 warning(s)                                           |
 | mips : 8 warning(s)                                                 |
 |   LibCPU :    0 | CPU Kit :   24 |                |                 |
 | moxie : 2 warning(s)                                                |
 |   Shared :   12 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   18 |                |                 |
 | nios2 : 0 warning(s)                                                |
 | or1k : 1 warning(s)                                                 |
 |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | powerpc : 46 warning(s)                                             |
 |   Shared :  260 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   12 | CPU Kit :   72 |                |                 |
 | sh : 162 warning(s)                                                 |
 |   Shared :   84 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   84 |                |                 |
 | sparc : 4 warning(s)                                                |
 |   LibCPU :    0 | CPU Kit :    0 |                |                 |
 | sparc64 : 2 warning(s)                                              |
 |   Shared :   36 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | v850 : 1 warning(s)                                                 |
 |   Shared :   72 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | x86_64 : 1 warning(s)                                               |
 |   LibCPU :    0 | CPU Kit :    6 |                |                 |
 | By BSP (total : 10173)                                              |
 | common : 291 warning(s)                                             |
 |   Shared : 1584 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   96 | CPU Kit :  792 |                |                 |
 | arm/altcycv_devkit : 7 warning(s)                                   |
 | arm/atsamv : 6 warning(s)                                           |
 | arm/csb336 : 0 warning(s)                                           |
 | arm/csb337 : 0 warning(s)                                           |
 | arm/csb637 : 0 warning(s)                                           |
 | arm/gumstix : 0 warning(s)                                          |
 | arm/imx7 : 2 warning(s)                                             |
 |   LibCPU :    0 | CPU Kit :   32 |                |                 |
 | arm/imxrt1052 : 1 warning(s)                                        |
 | arm/kit637_v6 : 0 warning(s)                                        |
 | arm/lm3s3749 : 0 warning(s)                                         |
 | arm/lm3s6965 : 0 warning(s)                                         |
 | arm/lm3s6965_qemu : 0 warning(s)                                    |
 | arm/lm4f120 : 0 warning(s)                                          |
 | arm/lpc1768_mbed : 0 warning(s)                                     |
 | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
 | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
 | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
 | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
 | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
 | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
 | arm/lpc2362 : 0 warning(s)                                          |
 | arm/lpc23xx_tli800 : 0 warning(s)                                   |
 | arm/lpc24xx_ea : 0 warning(s)                                       |
 | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
 | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
 | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
 | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
 | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
 | arm/lpc32xx_mzx : 0 warning(s)                                      |
 | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
 | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
 | arm/lpc32xx_phycore : 0 warning(s)                                  |
 | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
 | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
 | arm/nucleo-h743zi : 0 warning(s)                                    |
 | arm/raspberrypi : 0 warning(s)                                      |
 | arm/raspberrypi2 : 0 warning(s)                                     |
 | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
 | arm/smdk2410 : 0 warning(s)                                         |
 | arm/stm32f105rc : 0 warning(s)                                      |
 | arm/stm32f4 : 2 warning(s)                                          |
 | arm/stm32h7 : 2 warning(s)                                          |
 | arm/stm32h747i-disco : 1 warning(s)                                 |
 | arm/stm32h747i-disco-m4 : 0 warning(s)                              |
 | arm/stm32h757i-eval : 1 warning(s)                                  |
 | arm/stm32h757i-eval-m4 : 0 warning(s)                               |
 | arm/stm32h7b3i-dk : 2 warning(s)                                    |
 | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
 | bfin/TLL6527M : 11 warning(s)                                       |
 |   Shared :   42 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  138 | CPU Kit :   30 |                |                 |
 | bfin/bf537Stamp : 0 warning(s)                                      |
 | bfin/eZKit533 : 0 warning(s)                                        |
 | i386/pc386 : 0 warning(s)                                           |
 | i386/pc486 : 0 warning(s)                                           |
 | i386/pc586 : 0 warning(s)                                           |
 | i386/pc586-sse : 0 warning(s)                                       |
 | i386/pc686 : 0 warning(s)                                           |
 | i386/pcp4 : 0 warning(s)                                            |
 | lm32/lm32_evr : 0 warning(s)                                        |
 | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
 | lm32/milkymist : 12 warning(s)                                      |
 |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | m68k/COBRA5475 : 0 warning(s)                                       |
 | m68k/av5282 : 0 warning(s)                                          |
 | m68k/csb360 : 0 warning(s)                                          |
 | m68k/gen68340 : 0 warning(s)                                        |
 | m68k/gen68360 : 2 warning(s)                                        |
 |   Shared :   18 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   12 |                |                 |
 | m68k/gen68360_040 : 0 warning(s)                                    |
 | m68k/m5484FireEngine : 3 warning(s)                                 |
 |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | m68k/mcf5206elite : 1 warning(s)                                    |
 |   Shared :   78 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | m68k/mcf52235 : 3 warning(s)                                        |
 | m68k/mcf5225x : 3 warning(s)                                        |
 | m68k/mcf5235 : 1 warning(s)                                         |
 | m68k/mcf5329 : 3 warning(s)                                         |
 | m68k/mrm332 : 0 warning(s)                                          |
 | m68k/mvme147 : 0 warning(s)                                         |
 | m68k/mvme147s : 0 warning(s)                                        |
 | m68k/mvme162 : 0 warning(s)                                         |
 | m68k/mvme162lx : 0 warning(s)                                       |
 | m68k/mvme167 : 0 warning(s)                                         |
 | m68k/pgh360 : 0 warning(s)                                          |
 | m68k/uC5282 : 6 warning(s)                                          |
 | microblaze/kcu105 : 0 warning(s)                                    |
 | microblaze/kcu105_qemu : 0 warning(s)                               |
 | mips/hurricane : 1 warning(s)                                       |
 | mips/malta : 6 warning(s)                                           |
 | mips/rbtx4938 : 1 warning(s)                                        |
 | moxie/moxiesim : 2 warning(s)                                       |
 | nios2/nios2_iss : 0 warning(s)                                      |
 | or1k/generic_or1k : 1 warning(s)                                    |
 | powerpc/beatnik : 2 warning(s)                                      |
 |   LibCPU :   12 | CPU Kit :    0 |                |                 |
 | powerpc/icecube : 0 warning(s)                                      |
 | powerpc/mvme3100 : 1 warning(s)                                     |
 | powerpc/mvme5500 : 2 warning(s)                                     |
 | powerpc/pm520_cr825 : 0 warning(s)                                  |
 | powerpc/pm520_ze30 : 0 warning(s)                                   |
 | powerpc/psim : 1 warning(s)                                         |
 | powerpc/qemuppc : 1 warning(s)                                      |
 | powerpc/qoriq_e500 : 0 warning(s)                                   |
 | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
 | powerpc/qoriq_e6500_64 : 16 warning(s)                              |
 |   Shared :  104 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | powerpc/ss555 : 2 warning(s)                                        |
 | powerpc/t32mppc : 4 warning(s)                                      |
 |   LibCPU :    0 | CPU Kit :   48 |                |                 |
 | powerpc/virtex4 : 0 warning(s)                                      |
 | powerpc/virtex5 : 0 warning(s)                                      |
 | sh/gensh1 : 1 warning(s)                                            |
 | sh/gensh2 : 1 warning(s)                                            |
 | sh/gensh4 : 1 warning(s)                                            |
 | sh/simsh1 : 0 warning(s)                                            |
 | sh/simsh2 : 0 warning(s)                                            |
 | sh/simsh2e : 0 warning(s)                                           |
 | sh/simsh4 : 0 warning(s)                                            |
 | sparc/at697f : 0 warning(s)                                         |
 | sparc/gr712rc : 1 warning(s)                                        |
 | sparc/gr740 : 0 warning(s)                                          |
 | sparc/leon2 : 0 warning(s)                                          |
 | sparc/leon3 : 0 warning(s)                                          |
 | sparc/ut699 : 0 warning(s)                                          |
 | sparc/ut700 : 0 warning(s)                                          |
 | sparc64/niagara : 0 warning(s)                                      |
 | sparc64/usiii : 1 warning(s)                                        |
 | v850/v850e1sim : 0 warning(s)                                       |
 | v850/v850e2sim : 0 warning(s)                                       |
 | v850/v850e2v3sim : 0 warning(s)                                     |
 | v850/v850esim : 0 warning(s)                                        |
 | v850/v850essim : 0 warning(s)                                       |
 | v850/v850sim : 0 warning(s)                                         |
 | x86_64/amd64 : 1 warning(s)                                         |
 | By Build (total : 10173)                                            |
 | common : 392 warning(s)                                             |
 |   Shared : 1549 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  205 | CPU Kit :  881 |                |                 |
 | debug : 15 warning(s)                                               |
 |   Shared :  301 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   41 | CPU Kit :  163 |                |                 |
 | no-posix : 0 warning(s)                                             |
 | posix-debug : 0 warning(s)                                          |
 | posix-profiling : 0 warning(s)                                      |
 | smp : 0 warning(s)                                                  |
 | smp-debug : 0 warning(s)                                            |
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230801/477d81fd/attachment-0001.htm>
