Fwd: [rtems-bsp-builder] 2023-07-31 17:37:34: Profile(s): everything
Karel Gardas karel at functional.vision
Tue Aug 1 14:00:18 UTC 2023
   Joel,
not sure about what do you mean by "before the fix was pushed", but
certainly RTEMS HEAD does not contain the fix for this yet and fix is
already awaiting review here:
https://lists.rtems.org/pipermail/devel/2023-July/076043.html
If you ok that, I may push...
Thanks,
Karel
On 8/1/23 15:55, Joel Sherrill wrote:
> I think this started before the fix was pushed but since there is no
> hash in this report, it is impossible to be sure.
> Since it already has to know about the rtems source tree, could it
> include a hash? How hard is that to implement?
> --joel
> ---------- Forwarded message ---------
> From: *OAR Tester for CentOS 7* <rtems-tester at oarcorp.com
> <mailto:rtems-tester at oarcorp.com>>
> Date: Tue, Aug 1, 2023 at 5:24 AM
> Subject: [rtems-bsp-builder] 2023-07-31 17:37:34: Profile(s): everything
> To: <build at rtems.org <mailto:build at rtems.org>>
> RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
> Host: #1 SMP Tue Jun 20 11:48:01 UTC 2023
> command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
>           --rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
>           /rtems-cron-6/build --prefix=/home/tester/rtems-\
>           cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
>           builder.log --warnings-report=warnings.log --mail --use-gitconfig\
>           --profiles=everything
> Total Time            : 6:57:10.027015 for 1298 completed job(s)
> Average BSP Build Time: 0:00:19.283533
> Builds
>   debug
>   no-posix
>   posix
>   posix-debug
>   posix-profiling
>   profiling
>   smp
>   smp-debug
> Failures Report
>     1 debug arm/beagleboardorig build:
>        configure: /home/tester/rtems-cron-6/rtems/waf configure\
>        --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardorig-\
>        debug.ini
>       error: home/tester/bsps/arm/beagle/include/bsp/am335x_dcan.h:42:10:
>              fatal error: dev/can/can.h: No such file or directory
>       error: home/tester/bsps/arm/beagle/dcan/am335x-dcan.c:37:10: fatal
>     2 no-posix arm/beagleboardorig build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardorig-no-\
>        posix.ini
>     3 posix arm/beagleboardorig build:
>        posix.ini
>     4 posix-debug arm/beagleboardorig build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardorig-posix-\
>        debug.ini
>     5 posix-profiling arm/beagleboardorig build:
>        profiling.ini
>     6 profiling arm/beagleboardorig build:
>        profiling.ini
>     7 debug arm/beagleboardxm build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardxm-\
>        debug.ini
>     8 no-posix arm/beagleboardxm build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardxm-no-\
>        posix.ini
>     9 posix arm/beagleboardxm build:
>        posix.ini
>    10 posix-debug arm/beagleboardxm build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboardxm-posix-\
>        debug.ini
>    11 posix-profiling arm/beagleboardxm build:
>        profiling.ini
>    12 profiling arm/beagleboardxm build:
>        profiling.ini
>    13 debug arm/beagleboneblack build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboneblack-\
>        debug.ini
>    14 no-posix arm/beagleboneblack build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboneblack-no-\
>        posix.ini
>    15 posix arm/beagleboneblack build:
>        posix.ini
>    16 posix-debug arm/beagleboneblack build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beagleboneblack-posix-\
>        debug.ini
>    17 posix-profiling arm/beagleboneblack build:
>        profiling.ini
>    18 profiling arm/beagleboneblack build:
>        profiling.ini
>    19 debug arm/beaglebonewhite build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beaglebonewhite-\
>        debug.ini
>    20 no-posix arm/beaglebonewhite build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beaglebonewhite-no-\
>        posix.ini
>    21 posix arm/beaglebonewhite build:
>        posix.ini
>    22 posix-debug arm/beaglebonewhite build:
>        /rtems-cron-6/rtems --rtems-config=config-arm-beaglebonewhite-posix-\
>        debug.ini
>    23 posix-profiling arm/beaglebonewhite build:
>        profiling.ini
>    24 profiling arm/beaglebonewhite build:
>        profiling.ini
> Warnings Report
>   | By Architecture (total : 10173)                                     |
>   | common : 13 warning(s)                                              |
>   |   Shared :  738 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  144 |                |                 |
>   | arm : 57 warning(s)                                                 |
>   |   Shared :  192 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  208 |                |                 |
>   | bfin : 32 warning(s)                                                |
>   |   Shared :  138 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :  234 | CPU Kit :   90 |                |                 |
>   | i386 : 31 warning(s)                                                |
>   |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   36 |                |                 |
>   | lm32 : 14 warning(s)                                                |
>   |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   72 |                |                 |
>   | m68k : 33 warning(s)                                                |
>   |   Shared :  936 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :  330 |                |                 |
>   | microblaze : 0 warning(s)                                           |
>   | mips : 8 warning(s)                                                 |
>   |   LibCPU :    0 | CPU Kit :   24 |                |                 |
>   | moxie : 2 warning(s)                                                |
>   |   Shared :   12 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   18 |                |                 |
>   | nios2 : 0 warning(s)                                                |
>   | or1k : 1 warning(s)                                                 |
>   |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | powerpc : 46 warning(s)                                             |
>   |   Shared :  260 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :   12 | CPU Kit :   72 |                |                 |
>   | sh : 162 warning(s)                                                 |
>   |   Shared :   84 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   84 |                |                 |
>   | sparc : 4 warning(s)                                                |
>   |   LibCPU :    0 | CPU Kit :    0 |                |                 |
>   | sparc64 : 2 warning(s)                                              |
>   |   Shared :   36 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | v850 : 1 warning(s)                                                 |
>   |   Shared :   72 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | x86_64 : 1 warning(s)                                               |
>   |   LibCPU :    0 | CPU Kit :    6 |                |                 |
>   | By BSP (total : 10173)                                              |
>   | common : 291 warning(s)                                             |
>   |   Shared : 1584 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :   96 | CPU Kit :  792 |                |                 |
>   | arm/altcycv_devkit : 7 warning(s)                                   |
>   | arm/atsamv : 6 warning(s)                                           |
>   | arm/csb336 : 0 warning(s)                                           |
>   | arm/csb337 : 0 warning(s)                                           |
>   | arm/csb637 : 0 warning(s)                                           |
>   | arm/gumstix : 0 warning(s)                                          |
>   | arm/imx7 : 2 warning(s)                                             |
>   |   LibCPU :    0 | CPU Kit :   32 |                |                 |
>   | arm/imxrt1052 : 1 warning(s)                                        |
>   | arm/kit637_v6 : 0 warning(s)                                        |
>   | arm/lm3s3749 : 0 warning(s)                                         |
>   | arm/lm3s6965 : 0 warning(s)                                         |
>   | arm/lm3s6965_qemu : 0 warning(s)                                    |
>   | arm/lm4f120 : 0 warning(s)                                          |
>   | arm/lpc1768_mbed : 0 warning(s)                                     |
>   | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
>   | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
>   | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
>   | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
>   | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
>   | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
>   | arm/lpc2362 : 0 warning(s)                                          |
>   | arm/lpc23xx_tli800 : 0 warning(s)                                   |
>   | arm/lpc24xx_ea : 0 warning(s)                                       |
>   | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
>   | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
>   | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
>   | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
>   | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
>   | arm/lpc32xx_mzx : 0 warning(s)                                      |
>   | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
>   | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
>   | arm/lpc32xx_phycore : 0 warning(s)                                  |
>   | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
>   | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
>   | arm/nucleo-h743zi : 0 warning(s)                                    |
>   | arm/raspberrypi : 0 warning(s)                                      |
>   | arm/raspberrypi2 : 0 warning(s)                                     |
>   | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
>   | arm/smdk2410 : 0 warning(s)                                         |
>   | arm/stm32f105rc : 0 warning(s)                                      |
>   | arm/stm32f4 : 2 warning(s)                                          |
>   | arm/stm32h7 : 2 warning(s)                                          |
>   | arm/stm32h747i-disco : 1 warning(s)                                 |
>   | arm/stm32h747i-disco-m4 : 0 warning(s)                              |
>   | arm/stm32h757i-eval : 1 warning(s)                                  |
>   | arm/stm32h757i-eval-m4 : 0 warning(s)                               |
>   | arm/stm32h7b3i-dk : 2 warning(s)                                    |
>   | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
>   | bfin/TLL6527M : 11 warning(s)                                       |
>   |   Shared :   42 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :  138 | CPU Kit :   30 |                |                 |
>   | bfin/bf537Stamp : 0 warning(s)                                      |
>   | bfin/eZKit533 : 0 warning(s)                                        |
>   | i386/pc386 : 0 warning(s)                                           |
>   | i386/pc486 : 0 warning(s)                                           |
>   | i386/pc586 : 0 warning(s)                                           |
>   | i386/pc586-sse : 0 warning(s)                                       |
>   | i386/pc686 : 0 warning(s)                                           |
>   | i386/pcp4 : 0 warning(s)                                            |
>   | lm32/lm32_evr : 0 warning(s)                                        |
>   | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
>   | lm32/milkymist : 12 warning(s)                                      |
>   |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | m68k/COBRA5475 : 0 warning(s)                                       |
>   | m68k/av5282 : 0 warning(s)                                          |
>   | m68k/csb360 : 0 warning(s)                                          |
>   | m68k/gen68340 : 0 warning(s)                                        |
>   | m68k/gen68360 : 2 warning(s)                                        |
>   |   Shared :   18 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :    0 | CPU Kit :   12 |                |                 |
>   | m68k/gen68360_040 : 0 warning(s)                                    |
>   | m68k/m5484FireEngine : 3 warning(s)                                 |
>   |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | m68k/mcf5206elite : 1 warning(s)                                    |
>   |   Shared :   78 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | m68k/mcf52235 : 3 warning(s)                                        |
>   | m68k/mcf5225x : 3 warning(s)                                        |
>   | m68k/mcf5235 : 1 warning(s)                                         |
>   | m68k/mcf5329 : 3 warning(s)                                         |
>   | m68k/mrm332 : 0 warning(s)                                          |
>   | m68k/mvme147 : 0 warning(s)                                         |
>   | m68k/mvme147s : 0 warning(s)                                        |
>   | m68k/mvme162 : 0 warning(s)                                         |
>   | m68k/mvme162lx : 0 warning(s)                                       |
>   | m68k/mvme167 : 0 warning(s)                                         |
>   | m68k/pgh360 : 0 warning(s)                                          |
>   | m68k/uC5282 : 6 warning(s)                                          |
>   | microblaze/kcu105 : 0 warning(s)                                    |
>   | microblaze/kcu105_qemu : 0 warning(s)                               |
>   | mips/hurricane : 1 warning(s)                                       |
>   | mips/malta : 6 warning(s)                                           |
>   | mips/rbtx4938 : 1 warning(s)                                        |
>   | moxie/moxiesim : 2 warning(s)                                       |
>   | nios2/nios2_iss : 0 warning(s)                                      |
>   | or1k/generic_or1k : 1 warning(s)                                    |
>   | powerpc/beatnik : 2 warning(s)                                      |
>   |   LibCPU :   12 | CPU Kit :    0 |                |                 |
>   | powerpc/icecube : 0 warning(s)                                      |
>   | powerpc/mvme3100 : 1 warning(s)                                     |
>   | powerpc/mvme5500 : 2 warning(s)                                     |
>   | powerpc/pm520_cr825 : 0 warning(s)                                  |
>   | powerpc/pm520_ze30 : 0 warning(s)                                   |
>   | powerpc/psim : 1 warning(s)                                         |
>   | powerpc/qemuppc : 1 warning(s)                                      |
>   | powerpc/qoriq_e500 : 0 warning(s)                                   |
>   | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
>   | powerpc/qoriq_e6500_64 : 16 warning(s)                              |
>   |   Shared :  104 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   | powerpc/ss555 : 2 warning(s)                                        |
>   | powerpc/t32mppc : 4 warning(s)                                      |
>   |   LibCPU :    0 | CPU Kit :   48 |                |                 |
>   | powerpc/virtex4 : 0 warning(s)                                      |
>   | powerpc/virtex5 : 0 warning(s)                                      |
>   | sh/gensh1 : 1 warning(s)                                            |
>   | sh/gensh2 : 1 warning(s)                                            |
>   | sh/gensh4 : 1 warning(s)                                            |
>   | sh/simsh1 : 0 warning(s)                                            |
>   | sh/simsh2 : 0 warning(s)                                            |
>   | sh/simsh2e : 0 warning(s)                                           |
>   | sh/simsh4 : 0 warning(s)                                            |
>   | sparc/at697f : 0 warning(s)                                         |
>   | sparc/gr712rc : 1 warning(s)                                        |
>   | sparc/gr740 : 0 warning(s)                                          |
>   | sparc/leon2 : 0 warning(s)                                          |
>   | sparc/leon3 : 0 warning(s)                                          |
>   | sparc/ut699 : 0 warning(s)                                          |
>   | sparc/ut700 : 0 warning(s)                                          |
>   | sparc64/niagara : 0 warning(s)                                      |
>   | sparc64/usiii : 1 warning(s)                                        |
>   | v850/v850e1sim : 0 warning(s)                                       |
>   | v850/v850e2sim : 0 warning(s)                                       |
>   | v850/v850e2v3sim : 0 warning(s)                                     |
>   | v850/v850esim : 0 warning(s)                                        |
>   | v850/v850essim : 0 warning(s)                                       |
>   | v850/v850sim : 0 warning(s)                                         |
>   | x86_64/amd64 : 1 warning(s)                                         |
>   | By Build (total : 10173)                                            |
>   | common : 392 warning(s)                                             |
>   |   Shared : 1549 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :  205 | CPU Kit :  881 |                |                 |
>   | debug : 15 warning(s)                                               |
>   |   Shared :  301 |     BSP :    0 | Network :    0 |    Tests :    0 |
>   |   LibCPU :   41 | CPU Kit :  163 |                |                 |
>   | no-posix : 0 warning(s)                                             |
>   | posix : 0 warning(s)                                                |
>   | posix-debug : 0 warning(s)                                          |
>   | posix-profiling : 0 warning(s)                                      |
>   | profiling : 0 warning(s)                                            |
>   | smp : 0 warning(s)                                                  |
>   | smp-debug : 0 warning(s)                                            |
> build mailing list
> http://lists.rtems.org/mailman/listinfo/build
> <http://lists.rtems.org/mailman/listinfo/build>
> devel mailing list
> devel at rtems.org
