[PATCH] build: Optionally use a VERSION file
Wed Aug 2 04:01:54 UTC 2023
On 1/8/2023 5:11 pm, Sebastian Huber wrote:
> Define the RTEMS version in the wscript.  Optionally use a VERSION file
> to change the default values of the wscript.
Thanks, this is welcome. I will update the release scripts when merged.
> Allow the command line
> option --rtems-version to override __RTEMS_MAJOR__.  Remove support for
> command line configurable options.
I do not understand this last bit. It says allow --rtems-version and then the
command line configuration options are removed? And my reading of the change the
command line support has been removed?
> Rename internal define RTEMS_VERSION_VC_KEY to
> RTEMS_VERSION_CONTROL_KEY.
OK.
Thanks
>  cpukit/sapi/src/version.c       |   8 +--
>  spec/build/cpukit/cpuopts.yml   |   6 --
>  spec/build/cpukit/optvermaj.yml |  13 ----
>  spec/build/cpukit/optvermin.yml |  13 ----
>  spec/build/cpukit/optverrev.yml |  13 ----
>  wscript                         | 108 +++++++++++++++-----------------
>  6 files changed, 55 insertions(+), 106 deletions(-)
>  delete mode 100644 spec/build/cpukit/optvermaj.yml
>  delete mode 100644 spec/build/cpukit/optvermin.yml
>  delete mode 100644 spec/build/cpukit/optverrev.yml
> diff --git a/cpukit/sapi/src/version.c b/cpukit/sapi/src/version.c
> index ea07683876..7197ddd153 100644
> --- a/cpukit/sapi/src/version.c
> +++ b/cpukit/sapi/src/version.c
> @@ -54,8 +54,8 @@
>  const char *rtems_version( void )
> -#ifdef RTEMS_VERSION_VC_KEY
> -  return RTEMS_VERSION "." RTEMS_VERSION_VC_KEY;
> +#ifdef RTEMS_VERSION_CONTROL_KEY
> +  return RTEMS_VERSION "." RTEMS_VERSION_CONTROL_KEY;
>  #else
>    return RTEMS_VERSION;
>  #endif
> @@ -78,8 +78,8 @@ int rtems_version_revision( void )
>  const char *rtems_version_control_key( void )
> -  return RTEMS_VERSION_VC_KEY;
> +  return RTEMS_VERSION_CONTROL_KEY;
>  #else
>    return "";
>  #endif
> diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
> index 49dfc26e4b..f1b30eec55 100644
> --- a/spec/build/cpukit/cpuopts.yml
> +++ b/spec/build/cpukit/cpuopts.yml
> @@ -7,12 +7,6 @@ guard: _RTEMS_SCORE_CPUOPTS_H
>  include-headers: []
>  install-path: ${BSP_INCLUDEDIR}/rtems/score
>  links:
> -- role: build-dependency
> -  uid: optvermaj
> -  uid: optvermin
> -  uid: optverrev
>    uid: optgcc
> diff --git a/spec/build/cpukit/optvermaj.yml b/spec/build/cpukit/optvermaj.yml
> deleted file mode 100644
> index e194930b47..0000000000
> --- a/spec/build/cpukit/optvermaj.yml
> +++ /dev/null
> @@ -1,13 +0,0 @@
> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> -actions:
> -- get-string-command-line: '6'
> -- env-assign: null
> -build-type: option
> -copyrights:
> -- Copyright (C) 2020 embedded brains GmbH & Co. KG
> -default: []
> -description: ''
> -enabled-by: true
> -links: []
> -name: __RTEMS_MAJOR__
> -type: build
> diff --git a/spec/build/cpukit/optvermin.yml b/spec/build/cpukit/optvermin.yml
> index 8a58959394..0000000000
> --- a/spec/build/cpukit/optvermin.yml
> +++ /dev/null
> @@ -1,13 +0,0 @@
> -actions:
> -- set-value: '0'
> -- env-assign: null
> -build-type: option
> -copyrights:
> -default: []
> -description: ''
> -enabled-by: true
> -links: []
> -name: __RTEMS_MINOR__
> -type: build
> diff --git a/spec/build/cpukit/optverrev.yml b/spec/build/cpukit/optverrev.yml
> index 618c936e86..0000000000
> --- a/spec/build/cpukit/optverrev.yml
> +++ /dev/null
> @@ -1,13 +0,0 @@
> -actions:
> -- set-value: '0'
> -- env-assign: null
> -build-type: option
> -copyrights:
> -default: []
> -description: ''
> -enabled-by: true
> -links: []
> -name: __RTEMS_REVISION__
> -type: build
> diff --git a/wscript b/wscript
> index 862000513d..13c1d1d4d9 100755
> --- a/wscript
> +++ b/wscript
> @@ -43,7 +43,13 @@ except:
>  from waflib.TaskGen import after, before_method, feature
>  is_windows_host = os.name == "nt" or sys.platform in ["msys", "cygwin"]
> -default_prefix = "/opt/rtems/6"
> +version = {
> +    "__RTEMS_MAJOR__": "6",
> +    "__RTEMS_MINOR__": "0",
> +    "__RTEMS_REVISION__": "0",
> +    "RTEMS_VERSION_CONTROL_KEY": "git"
> +default_prefix = "/opt/rtems/" + version["__RTEMS_MAJOR__"]
>  compilers = ["gcc", "clang"]
>  items = {}
>  bsps = {}
> @@ -62,22 +68,28 @@ class VersionControlKeyHeader:
>      @staticmethod
>      def write(bld, filename):
> -        if VersionControlKeyHeader._content is None:
> -            from waflib.Build import Context
> -            from waflib.Errors import WafError
> +        content = VersionControlKeyHeader._content
> +        if content is None:
>              content = """/*
>   * Automatically generated. Do not edit.
>  #if !defined(_RTEMS_VERSION_VC_KEY_H_)
>  #define _RTEMS_VERSION_VC_KEY_H_
> -            try:
> -                rev = bld.cmd_and_log("git rev-parse HEAD",
> -                                      quiet=Context.STDOUT).strip()
> -                content += """#define RTEMS_VERSION_VC_KEY "{}"
> -""".format(rev)
> -            except WafError:
> +            key = bld.env.RTEMS_VERSION_CONTROL_KEY
> +            if key == "git":
> +                from waflib.Build import Context
> +                from waflib.Errors import WafError
> +                try:
> +                    key = bld.cmd_and_log("git rev-parse HEAD",
> +                                          quiet=Context.STDOUT).strip()
> +                except WafError:
> +                    key = ""
> +            if key:
> +                content += """#define RTEMS_VERSION_CONTROL_KEY "{}"
> +""".format(key)
> +            else:
>                  content += """/* No version control key found; release? */
>              content += """#endif
> @@ -87,9 +99,9 @@ class VersionControlKeyHeader:
>          f.parent.mkdir()
>          try:
>              if content != f.read():
> -                f.write(VersionControlKeyHeader._content)
> +                f.write(content)
>          except:
> +            f.write(content)
>  class EnvWrapper(object):
> @@ -992,15 +1004,6 @@ class OptionItem(Item):
>              value = self.default_value(conf.env.ENABLE)
>          return value
> -    def _get_string_command_line(self, conf, cic, value, arg):
> -        name = self.data["name"]
> -        try:
> -            value = conf.rtems_options[name]
> -            del conf.rtems_options[name]
> -        except KeyError:
> -            value = arg[0]
> -        return value
>      def _script(self, conf, cic, value, arg):
>          exec(arg)
>          return value
> @@ -1081,7 +1084,6 @@ class OptionItem(Item):
>              "get-env": self._get_env,
>              "get-integer": self._get_integer,
>              "get-string": self._get_string,
> -            "get-string-command-line": self._get_string_command_line,
>              "script": self._script,
>              "set-test-state": self._set_test_state,
>              "set-value": self._set_value,
> @@ -1310,15 +1312,6 @@ def options(ctx):
>          help=
>          "sets the RTEMS major version number; it is intended for RTEMS maintainers and may be used in the bspdefaults and configure commands",
> -    rg.add_option(
> -        "--rtems-option",
> -        metavar="KEY=VALUE",
> -        action="append",
> -        dest="rtems_options",
> -        default=[],
> -        help=
> -        "sets the option identified by KEY to the VALUE in the build specification; it is intended for RTEMS maintainers and may be used in the bspdefaults and configure commands",
>  def check_environment(conf):
> @@ -1345,6 +1338,27 @@ def check_environment(conf):
>              conf.msg("Environment variable set", ev, color="RED")
> +def configure_version(conf):
> +    cp = configparser.ConfigParser()
> +    version_file = "VERSION"
> +    if cp.read([version_file]):
> +        conf.msg("Configure RTEMS version from file",
> +                 version_file,
> +                 color="YELLOW")
> +        for key in version:
> +            try:
> +                value = cp.get("RTEMS_VERSION", key)
> +                version[key] = no_unicode(value)
> +            except configparser.NoOptionError:
> +                pass
> +    major = conf.options.rtems_version
> +    if major is not None:
> +        conf.msg("Set __RTEMS_MAJOR__ via command line to:",
> +                 major,
> +                 color="YELLOW")
> +        version["__RTEMS_MAJOR__"] = major
>  def load_config_files(ctx):
>      files = ctx.options.rtems_config
> @@ -1441,6 +1455,9 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
>      arch_bsp = arch + "/" + bsp_base
>      arch_family = arch + "/" + family
> +    for key, value in version.items():
> +        conf.env[key] = value
>      conf.env["ARCH"] = arch
>      conf.env["ARCH_BSP"] = arch_bsp
>      conf.env["ARCH_FAMILY"] = arch_family
> @@ -1462,7 +1479,6 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
>      conf.env["TOPGROUP"] = top_group
>      conf.env["VARIANT"] = variant
> -    prepare_rtems_options(conf)
>      cic = ConfigItemContext(cp, path_list)
>      items[conf.env.TOPGROUP].configure(conf, cic)
>      bsp_item.configure(conf, cic)
> @@ -1470,8 +1486,6 @@ def configure_variant(conf, cp, bsp_map, path_list, top_group, variant):
>      options = set([o[0].upper() for o in cp.items(variant)])
>      for o in options.difference(cic.options):
>          conf.msg("Unknown configuration option", o.upper(), color="RED")
> -    for key in conf.rtems_options:
> -        conf.msg("Unknown command line RTEMS option", key, color="RED")
>  def check_forbidden_options(ctx, opts):
> @@ -1504,28 +1518,10 @@ def get_top_group(ctx):
>      return top_group
> -def prepare_rtems_options(conf):
> -    conf.rtems_options = {}
> -    for x in conf.options.rtems_options:
> -        try:
> -            k, v = x.split("=", 1)
> -            conf.rtems_options[k] = v
> -        except:
> -            conf.fatal(
> -                "The RTEMS option '{}' is not in KEY=VALUE format".format(x))
> -    version = conf.options.rtems_version
> -    if version is not None:
> -        key = "__RTEMS_MAJOR__"
> -        if conf.rtems_options.get(key, version) != version:
> -            conf.fatal(
> -                "Conflicting RTEMS major versions specified at the command line"
> -        conf.rtems_options[key] = version
>  def configure(conf):
>      check_forbidden_options(conf, ["compiler"])
> +    configure_version(conf)
>      conf.env["SPECS"] = load_items_from_options(conf)
>      top_group = get_top_group(conf)
>      cp = load_config_files(conf)
> @@ -1573,7 +1569,6 @@ def build(bld):
>                  "compiler",
>                  "config",
> -                "options",
>                  "specs",
>                  "tools",
>                  "top_group",
> @@ -1668,8 +1663,7 @@ COMPILER = {}""".format(variant, compiler))
>  def bsplist(ctx):
>      """lists base BSP variants"""
> -        ctx,
> -        ["compiler", "config", "options", "tools", "top_group", "version"])
> +        ctx, ["compiler", "config", "tools", "top_group", "version"])
>      add_log_filter(ctx.cmd)
>      load_items_from_options(ctx)
>      white_list = get_white_list(ctx)
