[PATCH] build: Optionally use a VERSION file
Wed Aug 2 04:46:53 UTC 2023
On 02.08.23 06:01, Chris Johns wrote:
>> Allow the command line
>> option --rtems-version to override __RTEMS_MAJOR__.  Remove support for
>> command line configurable options.
> I do not understand this last bit. It says allow --rtems-version and then the
> command line configuration options are removed? And my reading of the change the
> command line support has been removed?
The patch removes the --rtems-option command line support. The
--rtems-version is needed to build for example using the RTEMS 7 tools.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
