[PATCH] build: Optionally use a VERSION file
Wed Aug 2 05:46:15 UTC 2023
On 2/8/2023 2:46 pm, Sebastian Huber wrote:
> On 02.08.23 06:01, Chris Johns wrote:
>>> Allow the command line
>>> option --rtems-version to override __RTEMS_MAJOR__.  Remove support for
>>> command line configurable options.
>> I do not understand this last bit. It says allow --rtems-version and then the
>> command line configuration options are removed? And my reading of the change the
>> command line support has been removed?
> The patch removes the --rtems-option command line support. The --rtems-version
> is needed to build for example using the RTEMS 7 tools.
Ah of course. Thanks.
