[PATCH] bsps/shared: Fix Coverity warning in MCP7940M
Christian MAUDERER christian.mauderer at embedded-brains.de
Wed Aug 2 11:45:39 UTC 2023
Hello Joel,
thanks. Is the ID processed somewhere automatically so that I should use
a special format? Otherwise I can just just add the error message from
covertity:
** CID 1539495:  Integer handling issues  (CONSTANT_EXPRESSION_RESULT)
/bsps/shared/dev/rtc/mcp7940m.c: 317 in mcp7940m_set_time()
Best regards
Christian
On 2023-08-02 13:43, Joel Sherrill wrote:
> Ok but out the Coverity Id number in the commit long message
> On Wed, Aug 2, 2023, 1:17 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Coverity warns that (buf[...] & 0x7) can't be bigger than 7. This patch
>     removes the unnecessary comparison.
>       bsps/shared/dev/rtc/mcp7940m.c | 5 ++---
>       1 file changed, 2 insertions(+), 3 deletions(-)
>     diff --git a/bsps/shared/dev/rtc/mcp7940m.c
>     b/bsps/shared/dev/rtc/mcp7940m.c
>     index 78a4f21b58..1abc5faaad 100644
>     --- a/bsps/shared/dev/rtc/mcp7940m.c
>     +++ b/bsps/shared/dev/rtc/mcp7940m.c
>     @@ -312,9 +312,8 @@ static int mcp7940m_set_time(int minor, const
>     rtems_time_of_day *time)
>         if (rv == 0) {
>     -    /* Make sure weekday is in range. Otherwise it's not relevant. */
>     -    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1 ||
>     -        RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) > 7) {
>     +    /* Make sure weekday is not 0 (out of range). Otherwise it's
>     not used. */
>     +    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1) {
>             buf[REG_RTCWKDAY] &= ~RTCWKDAY_WKDAY_MASK;
>             buf[REG_RTCWKDAY] |= RTCWKDAY_WKDAY(1);
>     2.35.3
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
embedded brains GmbH & Co. KG
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRA 117265
