[PATCH] bsps/shared: Fix Coverity warning in MCP7940M
Wed Aug 2 11:43:18 UTC 2023
Ok but out the Coverity Id number in the commit long message
On Wed, Aug 2, 2023, 1:17 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Coverity warns that (buf[...] & 0x7) can't be bigger than 7. This patch
> removes the unnecessary comparison.
>  bsps/shared/dev/rtc/mcp7940m.c | 5 ++---
>  1 file changed, 2 insertions(+), 3 deletions(-)
> diff --git a/bsps/shared/dev/rtc/mcp7940m.c
> b/bsps/shared/dev/rtc/mcp7940m.c
> index 78a4f21b58..1abc5faaad 100644
> --- a/bsps/shared/dev/rtc/mcp7940m.c
> +++ b/bsps/shared/dev/rtc/mcp7940m.c
> @@ -312,9 +312,8 @@ static int mcp7940m_set_time(int minor, const
> rtems_time_of_day *time)
>    if (rv == 0) {
> -    /* Make sure weekday is in range. Otherwise it's not relevant. */
> -    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1 ||
> -        RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) > 7) {
> +    /* Make sure weekday is not 0 (out of range). Otherwise it's not
> used. */
> +    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1) {
>        buf[REG_RTCWKDAY] &= ~RTCWKDAY_WKDAY_MASK;
>        buf[REG_RTCWKDAY] |= RTCWKDAY_WKDAY(1);
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230802/f59b87ce/attachment-0001.htm>
