[PATCH] libdebugger: Restrict ARM architecture support
Fri Aug 4 05:07:31 UTC 2023
On 04.08.23 00:43, Chris Johns wrote:
> On 3/8/2023 10:17 pm, Sebastian Huber wrote:
>> Build the arm libdebugger support only for supported ARM architectures.
> What ARM archs are not supported?
At least ARMv7-M and everything with Thumb 1.
>> This fixes assembler errors at -O0.
> How does it fix the assembler errors?
The unsupported assembly instructions are not issued by the compiler so
that the assembler is happy. This issue is open since 2020:
https://lists.rtems.org/pipermail/devel/2020-March/058432.html
Since the gcov code coverage is generated using -O0, this is now a
bigger issue.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
