[PATCH] build: Add PROGRAM_PREFIX option
Fri Aug 4 05:16:55 UTC 2023
On 04.08.23 00:27, Chris Johns wrote:
> On 2/8/2023 6:49 pm, Chris Johns wrote:
>   > I am concerned about the compatibility to the ecosystem we have. Have you built
>> all the tests in the testsuite with this value set to something that is not
>> RTEMS default? I think a few things will break because of hard coding in them.
> I have asked for test results and I have not seen any yet the patch has been
> merged? The change was not approved my me and is still not approved.
Sorry I thought it was fine after answering your questions. Yes, I have
tested this with the rtems7 tools. It was possible to build with the
rtems7 tools before, however, the PROGRAM_PREFIX approach is better,
since it allows also the build using vendor tools. We had some fixes for
this recently:
https://lists.rtems.org/pipermail/devel/2023-May/075321.html
This is something the user need.
I have problems to send test reports by e-mail:
Passed:        617
Failed:          2
User Input:      6
Expected Fail:   2
Indeterminate:   0
Benchmark:       3
Timeout:         0
Test too long:   0
Invalid:         0
Wrong Version:   0
Wrong Build:     0
Wrong Tools:     0
Wrong Header:    0
Total:         630
Failures:
  dl11.exe
  psxkey07.exe
User Input:
  dl10.exe
  monitor.exe
  termios.exe
  top.exe
  capture.exe
  fileio.exe
Expected Fail:
  dl06.exe
  psxfenv01.exe
Benchmark:
  dhrystone.exe
  whetstone.exe
  linpack.exe
Average test time: 0:00:00.214642
Testing time     : 0:02:15.224347
Traceback (most recent call last):
   File "/opt/rtems/6/bin/rtems-test", line 42, in <module>
     tester.rt.test.run(sys.argv)
   File "/opt/rtems/6/share/rtems/tester/rt/test.py", line 544, in run
     mail.send(to_addr, subject, os.linesep.join(body))
   File "/opt/rtems/6/share/rtems/rtemstoolkit/mailer.py", line 215, in send
     s.sendmail(from_addr, [to_addr], msg)
   File "/usr/lib64/python3.6/smtplib.py", line 866, in sendmail
     (code, resp) = self.mail(from_addr, esmtp_opts)
   File "/usr/lib64/python3.6/smtplib.py", line 539, in mail
     self.putcmd("mail", "FROM:%s%s" % (quoteaddr(sender), optionlist))
   File "/usr/lib64/python3.6/smtplib.py", line 153, in quoteaddr
     if addrstring.strip().startswith('<'):
AttributeError: 'NoneType' object has no attribute 'strip'
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
