[PATCH] trace/wscript: Improve C++ standard selection
Fri Aug 4 06:30:00 UTC 2023
On 4/8/2023 3:02 pm, Sebastian Huber wrote:
> On 04.08.23 00:53, Chris Johns wrote:
>> On 3/8/2023 5:36 pm, Sebastian Huber wrote:
>>> Ping.
>> Which repo? Is this in the rtems-tools repo?
> Yes, the rtems-tools.
Thanks
> Please understand there is a limited number people reviewing and it takes time.
>> I am blocked on the other changes you have recently posted. Adding which hosts
>> you have built and tested this change on would help?
> Sorry, Joel is rushing for the RTEMS 6 release. The patch is from 19.05.23. A CI
> system and pull requests would also help.
Ah yes and I have raised an 7 related RSB sources fetch that need to be fix as
well. My concern is release testing on hosts like MacOS M etc tend to find
issues if it has not been tested.
