[PATCH] trace/wscript: Improve C++ standard selection
Fri Aug 4 06:47:24 UTC 2023
On 04.08.23 08:30, Chris Johns wrote:
>> Please understand there is a limited number people reviewing and it takes time.
>>> I am blocked on the other changes you have recently posted. Adding which hosts
>>> you have built and tested this change on would help?
>> Sorry, Joel is rushing for the RTEMS 6 release. The patch is from 19.05.23. A CI
>> system and pull requests would also help.
> Ah yes and I have raised an 7 related RSB sources fetch that need to be fix as
> well. My concern is release testing on hosts like MacOS M etc tend to find
> issues if it has not been tested.
GitHub offers runners for macOS:
https://docs.github.com/en/actions/using-github-hosted-runners/about-github-hosted-runners
I don't understand why we don't use the GitHub services for the project.
It is just a matter of adding a couple for text files to the
repositories. You can still run your own GitLab stuff in parallel. It is
not one or another. You can have both.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
