[PATCH] build: Add PROGRAM_PREFIX option
Fri Aug 4 06:39:48 UTC 2023
On 04.08.23 08:22, Chris Johns wrote:
> On 4/8/2023 3:16 pm, Sebastian Huber wrote:
>> On 04.08.23 00:27, Chris Johns wrote:
>>> On 2/8/2023 6:49 pm, Chris Johns wrote:
>>>    > I am concerned about the compatibility to the ecosystem we have. Have you
>>> built
>>>> all the tests in the testsuite with this value set to something that is not
>>>> RTEMS default? I think a few things will break because of hard coding in them.
>>> I have asked for test results and I have not seen any yet the patch has been
>>> merged? The change was not approved my me and is still not approved.
>> Sorry I thought it was fine after answering your questions.
> All good, I would like to finish the discusion. :)
>> Yes, I have tested this with the rtems7 tools. It was possible to build with the rtems7 tools
>> before, however, the PROGRAM_PREFIX approach is better, since it allows also the
>> build using vendor tools. We had some fixes for this recently:
>> https://lists.rtems.org/pipermail/devel/2023-May/075321.html
>> This is something the user need.
> What if a user adds or uses a prefix that does not conform to the standard
> format? I am assuming this is possible to do this, eg Gaisler's special prefix?
> Possible breakage is
> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/rld-cc.cpp#n457 ?
> Do we need to document any constraints around this option?
There will be always problems left to fix. A basic build and the normal
tests work fine with non-standard tools. For the Gaisler tools, you
would need:
PROGRAM_PREFIX = sparc-gaisler-rtems5-
I guess the rld-cc.cpp will also have issues with a clang build.
>> I have problems to send test reports by e-mail:
> Anything Amar or I can help with?
> Chris
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
