[PATCH] trace/wscript: Improve C++ standard selection
Sun Aug 6 22:12:04 UTC 2023
On 4/8/2023 4:47 pm, Sebastian Huber wrote:
> On 04.08.23 08:30, Chris Johns wrote:
>>> Please understand there is a limited number people reviewing and it takes time.
>>>> I am blocked on the other changes you have recently posted. Adding which hosts
>>>> you have built and tested this change on would help?
>>> Sorry, Joel is rushing for the RTEMS 6 release. The patch is from 19.05.23. A CI
>>> system and pull requests would also help.
>> Ah yes and I have raised an 7 related RSB sources fetch that need to be fix as
>> well. My concern is release testing on hosts like MacOS M etc tend to find
>> issues if it has not been tested.
> GitHub offers runners for macOS:
> https://docs.github.com/en/actions/using-github-hosted-runners/about-github-hosted-runners
> I don't understand why we don't use the GitHub services for the project. It is
> just a matter of adding a couple for text files to the repositories. You can
> still run your own GitLab stuff in parallel. It is not one or another. You can
> have both.
It is not a technical issue. Who legally owns the github account? It cannot be a
single person and it cannot be a company. It could be a foundation but ours is
not functioning enough to do this.
Individuals can always set up builders and post to the builds list and that is
no different to a private build server in a company but these is not part of the
project or under its control.
