[PATCH] build: Add PROGRAM_PREFIX option
Mon Aug 7 06:06:18 UTC 2023
On 07.08.23 00:25, Chris Johns wrote:
> On 4/8/2023 4:39 pm, Sebastian Huber wrote:
>> On 04.08.23 08:22, Chris Johns wrote:
>>> On 4/8/2023 3:16 pm, Sebastian Huber wrote:
>>>> On 04.08.23 00:27, Chris Johns wrote:
>>>>> On 2/8/2023 6:49 pm, Chris Johns wrote:
>>>>>     > I am concerned about the compatibility to the ecosystem we have. Have you
>>>>> built
>>>>>> all the tests in the testsuite with this value set to something that is not
>>>>>> RTEMS default? I think a few things will break because of hard coding in them.
>>>>> I have asked for test results and I have not seen any yet the patch has been
>>>>> merged? The change was not approved my me and is still not approved.
>>>> Sorry I thought it was fine after answering your questions.
>>> All good, I would like to finish the discusion. 🙂
>>>> Yes, I have tested this with the rtems7 tools. It was possible to build with
>>>> the rtems7 tools
>>>> before, however, the PROGRAM_PREFIX approach is better, since it allows also the
>>>> build using vendor tools. We had some fixes for this recently:
>>>> https://lists.rtems.org/pipermail/devel/2023-May/075321.html
>>>> This is something the user need.
>>> What if a user adds or uses a prefix that does not conform to the standard
>>> format? I am assuming this is possible to do this, eg Gaisler's special prefix?
>>> Possible breakage is
>>> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/rld-cc.cpp#n457  ?
>>> Do we need to document any constraints around this option?
>> There will be always problems left to fix.
> I do not see this as a problem, I see an incomplete change pushed without the
> review being completed.
Sometimes it is not 100% clear when a review is finished.
>> A basic build and the normal tests
>> work fine with non-standard tools. For the Gaisler tools, you would need:
>> PROGRAM_PREFIX = sparc-gaisler-rtems5-
>> I guess the rld-cc.cpp will also have issues with a clang build.
> Yes it would and libdl is a part of RTEMS and breaking it again is something I
> would like to avoid. I consider the change incomplete because one part says use
> PROGRAM_PREFIX to change the tools prefix however doing so may break other
> parts. There is nothing to warn the user PROGRAM_PREFIX may not work as expected.
I don't use vendor tool chains, but it seems that some users would like
to use them. They were supported by the old build system, so a lacking
support in the new build system would be a regression. But if you don't
like this change, then we can also revert the patch.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
