[PATCH] cpukit/riscv : RISCV multitasking with non SMP
Wed Aug 9 13:28:54 UTC 2023
Hello Kevin,
the patch itself is all right, except some formatting issues. However, I
still don't understand why it is necessary. I did run the test suite on
a non-SMP system and it worked well. Interrupts should be enabled in
void _Thread_Handler( void )
   Thread_Control  *executing;
   ISR_Level        level;
   Per_CPU_Control *cpu_self;
    * Some CPUs need to tinker with the call frame or registers when the
    * thread actually begins to execute for the first time.  This is a
    * hook point where the port gets a shot at doing whatever it requires.
   _Context_Initialization_at_thread_begin();
   executing = _Thread_Executing;
    * have to put level into a register for those cpu's that use
    * inline asm here
   level = executing->Start.isr_level;
   _ISR_Set_level( level );
here through the _ISR_Set_level().
The level shall be zero. If it is non-zero, then this is an application
bug resulting in the INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
fatal error. This error happens also if you call operating system
services which block with interrupts disabled.
Do you have a self-contained test case for the RTEMS test suite which
shows the problem you want to solve?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
