[PATCH] cpukit/riscv : RISCV multitasking with non SMP
EYSSARTIER Kevin kevin.eyssartier at thalesgroup.com
Fri Aug 18 12:37:01 UTC 2023
Classified as: {OPEN}
Hello Sebastian,
> The level shall be zero. If it is non-zero, then this is an application
> bug resulting in the INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT
> fatal error. This error happens also if you call operating system
> services which block with interrupts disabled.
That is what I observed when calling printf. Is it a normal behavior ?
In that case, indeed my patch is useless.
Regards,
Kevin EYSSARTIER, Research Engineer
Thales Research & Technology France - High Performance Computing Lab
Campus Polytechnique - 1, avenue Augustin Fresnel  - 91767 Palaiseau cedex
Phone : +33 (0)1 69 41 55 14  Internal : 341 55 14
{OPEN}
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230818/948d20a8/attachment.htm>
