[PATCH] build: Add PROGRAM_PREFIX option
Thu Aug 10 01:13:47 UTC 2023
On 9/8/2023 7:12 pm, Sebastian Huber wrote:
> On 09.08.23 11:10, Cedric Berger wrote:
>> On 09.08.23 10:51, Sebastian Huber wrote:
>>> We could add some text to the option description:
>>> # Defines the program prefix of tools (compiler, assembler, linker).
>>> # This option may be used to build RTEMS with a vendor tool suite.
>>> # Please note that using tool suites not provided by the RTEMS Project
>>> # may not work as expected.
>> If the goal of that comment it to prevent "fielding support related
>> questions", I doubt that writing "may not work as expected" will have the
>> desired effect...
> I am open for alternative wordings.
# Defines the program prefix of tools (compiler, assembler, linker) used
# to build RTEMS. This option may be used to build RTEMS with a vendor
# tool suite. Please note, support issues related to using this option with
# vendor tool suites should be directed to the vendor of the tools.
