[PATCH] build: Add PROGRAM_PREFIX option
Thu Aug 10 05:06:47 UTC 2023
On 10.08.23 03:13, Chris Johns wrote:
> On 9/8/2023 7:12 pm, Sebastian Huber wrote:
>> On 09.08.23 11:10, Cedric Berger wrote:
>>> On 09.08.23 10:51, Sebastian Huber wrote:
>>>> We could add some text to the option description:
>>>> # Defines the program prefix of tools (compiler, assembler, linker).
>>>> # This option may be used to build RTEMS with a vendor tool suite.
>>>> # Please note that using tool suites not provided by the RTEMS Project
>>>> # may not work as expected.
>>> If the goal of that comment it to prevent "fielding support related
>>> questions", I doubt that writing "may not work as expected" will have the
>>> desired effect...
>> I am open for alternative wordings.
> # Defines the program prefix of tools (compiler, assembler, linker) used
> # to build RTEMS. This option may be used to build RTEMS with a vendor
> # tool suite. Please note, support issues related to using this option with
> # vendor tool suites should be directed to the vendor of the tools.
Sounds good, do you check it in?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
