[PATCH rtems v3 1/1] Add the Regulator Interface and test
Thu Aug 10 02:41:20 UTC 2023
Hi Joel,
This looks good.
A minor nit relates to pointer checks. We have:
https://docs.rtems.org/branches/master/eng/coding-conventions.html#language-and-compiler
I do not know how well enforced the pointer check for NULL in `if` is?
On 10/8/2023 1:42 am, Joel Sherrill wrote:
> Updates #4924.
> The Regulator is an application support class which is used to
> deal with the scenario where there is a bursty input source
> which needs to be metered out to a destination sink. The maximum
> size of bursts needs to be known and the delivery method must
> be configured to deliver messages at a rate that allows the
> traffic to not overflow.
>  cpukit/include/rtems/regulator.h              |  499 +++++++
>  cpukit/include/rtems/regulatorimpl.h          |  135 ++
>  cpukit/libmisc/regulator/regulator.c          |  683 +++++++++
>  spec/build/cpukit/librtemscpu.yml             |    2 +
>  spec/build/cpukit/objregulator.yml            |   18 +
>  spec/build/testsuites/libtests/grp.yml        |    2 +
>  .../build/testsuites/libtests/regulator01.yml |   21 +
>  testsuites/libtests/regulator01/regulator01.c | 1310 +++++++++++++++++
>  .../libtests/regulator01/regulator01.doc      |   67 +
>  .../libtests/regulator01/rtems_config.c       |   59 +
>  10 files changed, 2796 insertions(+)
>  create mode 100644 cpukit/include/rtems/regulator.h
>  create mode 100644 cpukit/include/rtems/regulatorimpl.h
>  create mode 100644 cpukit/libmisc/regulator/regulator.c
>  create mode 100644 spec/build/cpukit/objregulator.yml
>  create mode 100644 spec/build/testsuites/libtests/regulator01.yml
>  create mode 100644 testsuites/libtests/regulator01/regulator01.c
>  create mode 100644 testsuites/libtests/regulator01/regulator01.doc
>  create mode 100644 testsuites/libtests/regulator01/rtems_config.c
> diff --git a/cpukit/include/rtems/regulator.h b/cpukit/include/rtems/regulator.h
> new file mode 100644
> index 0000000000..362a99f6bc
> --- /dev/null
> +++ b/cpukit/include/rtems/regulator.h
> @@ -0,0 +1,499 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @defgroup RegulatorAPI Regulator API
> + * @brief Regulator APIs
> + * The Regulator provides a set of APIs to manage input sources which
> + * produces bursts of message traffic.
> + * @mainpage
> + * The regulator is designed to sit logically between two entities -- a
> + * source and a destination, where it limits the traffic sent to the
> + * destination to prevent it from being flooded with messages from the
> + * source. This can be used to accommodate bursts of input from a source
> + * and meter it out to a destination.  The maximum number of messages
> + * which can be buffered in the regulator is specified by the
> + * @a maximum_messages field in the @a rtems_regulator_attributes
> + * structure passed as an argument to @a rtems_regulator_create().
> + * The regulator library accepts an input stream of messages from a
> + * source and delivers them to a destination. The regulator assumes that the
> + * input stream from the source contains sporadic bursts of data which can
> + * exceed the acceptable rate of the destination. By limiting the message rate,
> + * the regulator prevents an overflow of messages.
> + * The regulator can be configured for the input buffering required to manage
> + * the maximum burst and for the metering rate for the output. The output rate
> + * is in messages per second. If the sender produces data too fast, the
> + * regulator will buffer the configured number of messages.
> + * A configuration capability is provided to allow for adaptation to different
> + * message streams. The regulator can also support running multiple instances,
> + * which could be used on independent message streams.
> + * The regulator provides a simple interface to the application for avoiding
> + * bursts of input from a fast source overflowing a slower destination.
> + * It is assumed that the application has a design limit on the number of
> + * messages which may be buffered. All messages accepted by the regulator,
> + * assuming no overflow on input, will eventually be output by the Delivery
> + * thread.
> + * A regulator instance is used as follows from the producer/source side:
> + * @code
> + *   while (1)
> + *     use rtems_regulator_obtain_buffer to obtain a buffer
> + *     input operation to fetch data into the buffer
> + *     rtems_regulator_send(buffer, size of message)
> + * @endcode
> + * The delivery of message buffers to the Destination and subsequent
> + * release is performed in the context of the delivery thread by either
> + * the delivery function or delivery thread. Details are below.
> + * The sequence diagram below shows the interaction between a message Source,
> + * a Regulator instance, and RTEMS, given the usage described in the above
> + * paragraphs.
> + * \startuml "Regulator Application Input Source Usage"
> + *   Source -> Regulator : rtems_regulator_obtain_buffer(regulator, buffer)
> + *   Regulator -> RTEMS : rtems_partition_get_buffer(id, buffer)
> + *   RTEMS --> Regulator : rtems_status_code
> + *   Regulator --> Source : rtems_status_code
> + *   Source -> Regulator : rtems_regulator_send(regulator, message, length)
> + *   Regulator -> RTEMS : rtems_message_queue_send(id, message, size)
> + * \enduml
> + * As illustrated in the sequence diagram, the Source usually corresponds
> + * to application software reading a system input. The Source obtains a
> + * buffer from the Regulator instance and fills it with incoming data.
> + * The application explicitly obtaining a buffer and filling it in allows
> + * for zero copy operations on the Source side.
> + * The Source then sends the buffer to the Regulator instance. The Regulator
> + * the sends the buffer via a message queue which to the Delivery thread.
> + * The Delivery thread executes periodically at a rate specified at
> + * Regulation creation. At each period, the Delivery thread attempts to
> + * receive up to a configured number of buffers and invoke the Delivery
> + * function to deliver them to the Destination.
> + * The Delivery function is provided by the application for this
> + * specific Regulator instance. Depending on the Destination, it may use
> + * a function which copies the buffer contents (e.g., write()) or which
> + * operates directly on the buffer contents (e.g. DMA from buffer). In
> + * the case of a Destination which copies the buffer contents, the buffer
> + * can be released via @a rtems_regulator_release_buffer() as soon as the
> + * function or copying completes. In the case where the delivery uses the
> + * buffer and returns, the call to @a rtems_regulator_release_buffer()
> + * will occur when the use of the buffer is complete (e.g. completion
> + * of DMA transfer).  This explicit and deliberate exposure of buffering
> + * provides the application with the ability to avoid copying the contents.
> + * After the Source has sent the message to the Regulator instance,
> + * the Source is free to process another input and the Regulator
> + * instance will ensure that the buffer is delivered to the Delivery
> + * function and Destination.
> + * The Regulator implementation uses the RTEMS Classic API Partition Manager
> + * to manage the buffer pool and the RTEMS Classic API Message Queue
> + * Manager to send the buffer to the Delivery thread.
> + * @addtogroup RegulatorAPI
> + * @file
> + * @brief This header file defines the Regulator API.
> + * Copyright (C) 2023 On-Line Applications Research Corporation (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef REGULATOR_H
> +#define REGULATOR_H
> +#include <stdlib.h>
> +#include <rtems.h>
> + * @ingroup RegulatorAPI
> + * @brief Regulator Delivery Function Type
> + * The user provides a function which is invoked to deliver a message
> + * to the output. It is invoked by the Delivery thread created as part
> + * of @a rtems_regulator_create(). The priority and stack size of the
> + * Delivery thread are specified in the regulator attribute set.
> + * It takes three parameters:
> + * @param[in] context is an untyped pointer to a user context
> + * @param[in] message points to the message
> + * @param[in] length is the message size
> + * The following is an example deliverer function. It assumes that the
> + * application has defined the my_context_t structure and it has at least
> + * the socket field. The @a message passed in originated with an
> + * application source which obtained the @a message buffer using
> + * @a rtems_regulator_obtain_buffer(), filled it in with source data,
> + * and used @a rtems_regulator_send() to hand to the regulator instance
> + * for later delivery.
> + * @code
> + *   bool my_deliverer(
> + *     void     *context,
> + *     void     *message,
> + *     size_t    length
> + *       my_context_t *my_context;
> + *       my_context = (my_context_t *)context;
> + *       write(my_context->socket, message, length);
> + *       rtems_regulator_release_buffer(message);
> + *       // return false to indicate we released the buffer
> + *       return false;
> + * @endcode
> + * The delivery function returns true to indicate that the delivery thread
> + * should release the buffer or false to indicate that it released the
> + * buffer.  If the delivery function invokes a function like @a write()
> + * to deliver the message to the destination, then the buffer can be
> + * released immediately after the call. If the delivery function does
> + * something like setting up a DMA transfer of the buffer, it cannot be
> + * released until after the DMA is complete.
> + * The following sequence diagram shows the behavior of the Delivery thread
> + * body and its interaction with the user-supplied deliverer() function.
> + * \startuml "Regulator Delivery Thread Body"
> + *   loop while (1)
> + *     "Delivery Thread" -> RTEMS : rtems_rate_monotonic_period(id, delivery_thread_period)
> + *     loop for 0 : maximum_to_dequeue_per_period
> + *       "Delivery Thread" -> RTEMS : rtems_message_queue_receive(id, message, size, wait, 0)
> + *       RTEMS --> "Delivery Thread" : rtems_status_code
> + *       group if [rtems_status_code != RTEMS_SUCCESSFUL]
> + *         RTEMS -> "Delivery Thread" : break
> + *       end
> + *       "Delivery Thread" -> Application : deliverer(context, buffer, length)
> + *       "Delivery Thread" -> RTEMS : rtems_partition_return_buffer(id, buffer)
> + *     end
> + *   end
> + * \enduml
> + * In the above sequence diagram, the key points are:
> + *   -# The Delivery Thread Body is periodically executed.
> + *   -# During each period, up to the instance configuration parameter
> + *      @a maximum_to_dequeue_per_period may be dequeued and
> + *      passed the application's delivery function for processing.
> + * Note that the application explicitly obtains buffers from the
> + * regulator instance but that the release may be done by Delivery
> + * Thread, the Delivery function, or later when the buffer contents
> + * are transferred.
> +typedef bool (*rtems_regulator_deliverer)(
> +  void     *context,
> +  void     *message,
> +  size_t    length
> + * @brief Attributes for Regulator Instance
> + * An instance of this structure must be populated by the application
> + * before creating an instance of the regulator. These settings tailor
> + * the behavior of the regulator instance.
> +typedef struct {
> +  /** Application function to invoke to output a message to the destination*/
> +  rtems_regulator_deliverer deliverer;
> +  /** Context pointer to pass to deliver function */
> +  void  *deliverer_context;
> +  /** Maximum size message to process */
> +  size_t  maximum_message_size;
> +  /** Maximum number of messages to be able to buffer */
> +  size_t  maximum_messages;
> +  /** Priority of Delivery thread */
> +  rtems_task_priority delivery_thread_priority;
> +  /** Stack size of Delivery thread */
> +  size_t delivery_thread_stack_size;
> +  /** Period (in ticks) of Delivery thread */
> +  rtems_interval delivery_thread_period;
> +  /** Maximum messages to dequeue per period */
> +  size_t  maximum_to_dequeue_per_period;
> +} rtems_regulator_attributes;
> + * @brief Statistics for Regulator Instance
> + * An instance of this structure is provided to the directive
> + * @a rtems_regulator_get_statistics and is filled in by that service.
> +typedef struct {
> +  /** Number of successfully obtained buffers. */
> +  size_t    obtained;
> +  /** Number of successfully released buffers. */
> +  size_t    released;
> +  /** Number of successfully delivered buffers. */
> +  size_t    delivered;
> +  /** Rate Monotonic Period statistics for Delivery Thread */
> +  rtems_rate_monotonic_period_statistics period_statistics;
> +} rtems_regulator_statistics;
> + * @brief Regulator Instance
> + * This is used by the application as the handle to a Regulator instance.
> +typedef void *rtems_regulator_instance;
> + * @brief Create a regulator
> + * This function creates an instance of a regulator. It uses the provided
> + * @a attributes to create the instance return in @a regulator. This instance
> + * will allocate the buffers associated with the regulator instance as well
> + * as the Delivery thread.
> + * The @a attributes structure defines the priority and stack size of
> + * the Delivery thread dedicated to this regulator instance. It also
> + * defines the period of the Delivery thread and the maximum number of
> + * messages that may be delivered per period via invocation of the
> + * delivery function.
> + * For each regulator instance, the following resources are allocated:
> + * - A memory area for the regulator control block using @a malloc().
> + * - A RTEMS Classic API Message Queue is constructed with message
> + *   buffer memory allocated using @a malloc().  Each message consists
> + *   of a pointer and a length.
> + * - A RTEMS Classic API Partition.
> + * - A RTEMS Classic API Rate Monotonic Period.
> + * @param[in] attributes specify the regulator instance attributes
> + * @param[inout] regulator will point to the regulator instance
> + * @return an RTEMS status code indicating success or failure.
> + * @note This function allocates memory for the buffers holding messages,
> + *       an Delivery thread and an RTEMS partition. When it executes, the
> + *       Delivery thread will create an RTEMS rate monotonic period.
> +rtems_status_code rtems_regulator_create(
> +  rtems_regulator_attributes  *attributes,
> +  rtems_regulator_instance   **regulator
> + * @brief Delete a regulator
> + * This function is used to delete the specified @a regulator instance.
> + * It is the responsibility of the user to ensure that any resources
> + * such as sockets or open file descriptors used by the delivery
> + * function are also deleted. It is likely safer to delete those
> + * delivery resources after deleting the regulator instance rather than
> + * before.
> + * @param[in] regulator is the instance to delete
> + * @param[in] ticks is the maximum number of ticks to wait for
> + *            the delivery thread to shutdown.
> + * @note This function deallocates the resources allocated during
> + *       @a rtems_regulator_create().
> +rtems_status_code rtems_regulator_delete(
> +  rtems_regulator_instance    *regulator,
> +  rtems_interval               ticks
> + * @brief Obtain Buffer from Regulator
> + * This function is used to obtain a buffer from the regulator's pool. The
> + * @a buffer returned is assumed to be filled in with contents and used
> + * in a subsequent call to @a rtems_regulator_send(). When the @a buffer is
> + * delivered, it is expected to be released. If the @a buffer is not
> + * successfully accepted by this function,  then it should be returned
> + * using @a rtems_regulator_release_buffer() or used to send another message.
> + * The @a buffer is of the maximum_message_size specified in the attributes
> + * passed in to @a rtems_regulator_create().
> + * @param[in] regulator is the regulator instance to operate upon
> + * @param[out] buffer will point to the allocated buffer
> + * @note This function does not perform dynamic allocation. It obtains a
> + *       buffer from the pool allocated during @a rtems_regulator_create().
> + * @note Any attempt to write outside the buffer area is undefined.
> +rtems_status_code rtems_regulator_obtain_buffer(
> +  void                      **buffer
> + * @brief Release Previously Obtained Regulator Buffer
> + * This function is used to release a buffer to the regulator's pool. It is
> + * assumed that the @a buffer returned will not be used by the application
> + * anymore. The @a buffer must have previously been allocated by
> + * @a rtems_regulator_obtain_buffer() and NOT passed to
> + * @a rtems_regulator_send().
> + * If a subsequent @a rtems_regulator_send() using this @a buffer is
> + * successful, the @a buffer will eventually be processed by the delivery
> + * thread and released.
> + * @param[out] buffer will point to the buffer to release
> + * @note This function does not perform dynamic deallocation. It releases a
> + *       buffer to the pool allocated during @a rtems_regulator_create().
> +rtems_status_code rtems_regulator_release_buffer(
> +  void                       *buffer
> + * @brief Send to regulator instance
> + * This function is used by the producer to send a @a message to the
> + * @a regulator for later delivery by the Delivery thread. The message is
> + * contained in the memory pointed to by @a message and is @a length
> + * bytes in length.
> + * It is required that the @a message buffer was obtained via
> + * @a rtems_regulator_obtain_buffer().
> + * It is assumed that the @a message buffer has been filled in with
> + * application content to deliver.
> + * If the @a rtems_regulator_send() is successful, the buffer is enqueued
> + * inside the regulator instance for subsequent delivery. After the
> + * @a message is delivered, it may be released by either delivery
> + * function or the application code depending on the implementation.
> + * The status @a RTEMS_TOO_MANY is returned if the regulator's
> + * internal queue is full. This indicates that the configured
> + * maximum number of messages was insufficient. It is the
> + * responsibility of the caller to decide whether to hold messages,
> + * drop them, or print a message that the maximum number of messages
> + * should be increased.
> + * If @a rtems_regulator_send() is unsuccessful, it is the application's
> + * responsibility to release the buffer. If it is successfully sent,
> + * then it becomes the responsibility of the delivery function to
> + * release it.
> + * @param[out] message points to the message to deliver
> + * @param[out] length is the size of the message in bytes
> +rtems_status_code rtems_regulator_send(
> +  void                      *message,
> +  size_t                     length
> + * @brief Obtain statistics for regulator instance
> + * This function is used by the application to obtain statistics
> + * information about the regulator instance.
> + * If the @a obtained and @a released fields in the returned
> + * @a statistics structure are equal, then there are no buffers
> + * outstanding from this regulator instance.
> + * @param[inout] statistics points to the statistics structure to fill in
> +rtems_status_code rtems_regulator_get_statistics(
> +  rtems_regulator_statistics *statistics
> +#endif /* REGULATOR_H */
> diff --git a/cpukit/include/rtems/regulatorimpl.h b/cpukit/include/rtems/regulatorimpl.h
> index 0000000000..ef1334c332
> --- /dev/null
> +++ b/cpukit/include/rtems/regulatorimpl.h
> @@ -0,0 +1,135 @@
> + * @defgroup RegulatorInternalAPI Regulator API Internals
> + * @brief Regulator Internal Information
> + * This concerns implementation information about the Regulator.
> + * @ingroup RegulatorInternalAPI
> + * @file
> + * @brief Regulator Library Implementation Support
> + * are met:
> +#ifndef RTEMS_REGULATORIMPL_H
> +#define RTEMS_REGULATORIMPL_H
> +#include <stdatomic.h>
> +#include <rtems/chain.h>
> + * This constant is used to indicate the regulator instance is initialized.
> +#define REGULATOR_INITIALIZED 0xDeadF00d
> + * @brief Regulator Message Instance Management Structure
> +typedef struct {
> +  /** This points to the message contents. */
> +  void   *buffer;
> +  /** This is the length of the message. */
> +  size_t  length;
> +} _Regulator_Message_t;
> + * @brief Regulator Statistics Private Structure
> + * An instance of this structure is allocated per regulator instance.
> +typedef struct {
> +  atomic_size_t    obtained;
> +  atomic_size_t    released;
> +  atomic_size_t    delivered;
> +} _Regulator_Statistics;
> + * @brief Regulator Instance Private Structure
> +typedef struct {
> +  /** Has magic value when instance is usable */
> +  uint32_t   initialized;
> +  /** Attributes for this instance -- copied from user */
> +  rtems_regulator_attributes  Attributes;
> +  /** Pointer to allocated message memory */
> +  void *message_memory;
> +  /** Pointer to allocated memory for RTEMS Message Queue for pending buffers*/
> +  void *message_queue_storage;
> +  /** RTEMS Message Queue of pending outgoing messages */
> +  rtems_id  queue_id;
> +  /** RTEMS Partition for pool of unused messages */
> +  rtems_id  messages_partition_id;
> +  /** RTEMS Task for performing output */
> +  rtems_id  delivery_thread_id;
> +  /** Id of period used by output thread */
> +  rtems_id  delivery_thread_period_id;
> +  /** Indicates Delivery thread is running */
> +  bool  delivery_thread_is_running;
> +  /** Indicates Delivery thread has been requested to exit */
> +  bool  delivery_thread_request_exit;
> +  /** Indicates Delivery thread has exited */
> +  bool  delivery_thread_has_exited;
> +  /** Internal Statistics */
> +  _Regulator_Statistics Statistics;
> +} _Regulator_Control;
> +#endif /* RTEMS_REGULATORIMPL_H */
> diff --git a/cpukit/libmisc/regulator/regulator.c b/cpukit/libmisc/regulator/regulator.c
> index 0000000000..2337fdaf77
> --- /dev/null
> +++ b/cpukit/libmisc/regulator/regulator.c
> @@ -0,0 +1,683 @@
> + * @file
> + * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
> + * are met:
> +#include <rtems.h>
> +#include <rtems/regulator.h>
> +#include <rtems/regulatorimpl.h>
> + * This method is the body for the task which delivers the output for
> + * this regulator instance at the configured rate.
> + * @param[in] arg points to the regulator instance this thread
> + *                is associated with
> +static rtems_task _Regulator_Output_task_body(
> +  rtems_task_argument arg
> +  _Regulator_Control   *the_regulator;
> +  rtems_status_code     sc;
> +  size_t                to_dequeue;
> +  _Regulator_Message_t  regulator_message;
> +  size_t                regulator_message_size;
> +  bool                  release_it;
> +   * The argument passed in cannot be NULL if the regulator_create worked.
> +  the_regulator = (_Regulator_Control *) arg;
> +  the_regulator->delivery_thread_is_running   = true;
> +   * This thread uses a rate monotonic period object instance. A rate
> +   * monotonic period object must be created by the thread using it.
> +   * It can be deleted by any thread which simplifies clean up.
> +   * The rate_monotonic_create() call can fail if the application
> +   * is incorrectly configured. This thread has no way to report the
> +   * failure. If it continues with an invalid id, then the thread will
> +   * not block on the period and spin continuously consuming CPU. The only
> +   * alternatives are to invoke rtems_fatal_error_occurred() or silently
> +   * exit the thread.
> +  sc = rtems_rate_monotonic_create(
> +    rtems_build_name('P', 'E', 'R', 'D'),
> +    &the_regulator->delivery_thread_period_id
> +  if (sc != RTEMS_SUCCESSFUL) {
> +    goto exit_delivery_thread;
> +   * Loop on the rate_monotonic_period() based on the specified period.
> +  while (1) {
> +    sc = rtems_rate_monotonic_period(
> +      the_regulator->delivery_thread_period_id,
> +      the_regulator->Attributes.delivery_thread_period
> +     _Assert_Unused_variable_equals(sc, RTEMS_SUCCESSFUL);
> +     * If the delivery thread has been requested to exit, then
> +     * quit processing messages, break out of this loop, and exit
> +     * this thread.
> +    if (the_regulator->delivery_thread_request_exit) {
> +      break;
> +     * Loop for the configured number of messages to deliver per period.
> +     * If we reach the point, there are no more messages, block for the
> +     * rest of this period. If there are messages, deliver them.
> +    for (to_dequeue = 0;
> +         to_dequeue < the_regulator->Attributes.maximum_to_dequeue_per_period;
> +         to_dequeue++) {
> +      regulator_message_size = sizeof(_Regulator_Message_t);
> +      sc = rtems_message_queue_receive(
> +        the_regulator->queue_id,
> +        &regulator_message,
> +        &regulator_message_size,
> +        RTEMS_NO_WAIT,
> +        0
> +        break;
> +      release_it = the_regulator->Attributes.deliverer(
> +        the_regulator->Attributes.deliverer_context,
> +        regulator_message.buffer,
> +        regulator_message.length
> +      the_regulator->Statistics.delivered++;
> +       * The message was successfully delivered. If the delivery function
> +       * wants the buffer returned, do it now. The delivery to the Destination
> +       * may involve handing the buffer off to something like DMA
> +       * and need to wait for it to complete before releasing the buffer.
> +       * Note that this is the underlying RTEMS service
> +       * used by @a rtems_regulator_obtain_buffer() and @a
> +       * rtems_regulator_release_buffer().
> +      if (release_it == true) {
> +        the_regulator->Statistics.released++;
> +        sc = rtems_partition_return_buffer(
> +          the_regulator->messages_partition_id,
> +   * This thread was requested to exit. Do so.
> +exit_delivery_thread:
> +  the_regulator->delivery_thread_is_running   = false;
> +  the_regulator->delivery_thread_has_exited   = true;
> +  (void) rtems_rate_monotonic_delete(the_regulator->delivery_thread_period_id);
> +  rtems_task_exit();
> + * This method frees the resources associated with a regulator instance.
> + * The resources are freed in the opposite of the order in which they are
> + * allocated. This is used on error cases in @a rtems_regulator_create() and in
> + * @a rtems_regulator_delete().
> + * @param[in] the_regulator is the instance to operate upon
> + * @param[in] ticks is the length of time to wait for the delivery thread
> + *            to exit
> + * @return This method returns true is successful and false on timeout.
> +static bool _Regulator_Free_helper(
> +  _Regulator_Control *the_regulator,
> +   * If the output thread has not started running, then we can just delete it.
> +  if (ticks == 0 || the_regulator->delivery_thread_is_running == false) {
> +    sc = rtems_task_delete(the_regulator->delivery_thread_id);
> +  } else {
> +    rtems_interval remaining = ticks;
> +    the_regulator->delivery_thread_request_exit = true;
> +    while (1) {
> +      if (the_regulator->delivery_thread_has_exited) {
> +        break;
> +      if (remaining == 0) {
> +        return false;
> +      (void) rtems_task_wake_after(1);
> +      remaining--;
> +   * The output thread deletes the rate monotonic period that it created.
> +   * The regulator's message_queue_storage is implicitly freed by this call.
> +  sc = rtems_message_queue_delete(the_regulator->queue_id);
> +  sc = rtems_partition_delete(the_regulator->messages_partition_id);
> +  if (the_regulator->message_memory) {
> +    free(the_regulator->message_memory);
> +  the_regulator->initialized = 0;
> +  free(the_regulator);
> +  return true;
> +  size_t             alloc_size;
> +   * Perform basic validation of parameters
> +  if (!attributes) {
> +    return RTEMS_INVALID_ADDRESS;
> +  if (!regulator) {
> +   * Verify attributes are OK. Some are checked by calls to object create
> +   * methods. Specifically the following are not checked:
> +   * - delivery_thread_priority by rtems_task_create()
> +   * - delivery_thread_stack_size can be any value
> +  if (attributes->deliverer == NULL) {
> +  if (attributes->maximum_messages == 0) {
> +    return RTEMS_INVALID_NUMBER;
> +  if (attributes->maximum_message_size == 0) {
> +    return RTEMS_INVALID_SIZE;
> +  if (attributes->maximum_to_dequeue_per_period == 0) {
> +  if (attributes->delivery_thread_period == 0) {
> +   * Allocate memory for regulator instance
> +  the_regulator = (_Regulator_Control *) calloc(sizeof(_Regulator_Control), 1);
> +  if (!the_regulator) {
> +    return RTEMS_NO_MEMORY;
> +   * We do NOT want the delivery_thread_id field to be initialized to 0. If the
> +   * @a rtems_task_create() fails, then the field will not be overwritten.
> +   * This results in an attempt to rtems_task_delete(0) during clean
> +   * up. The thread ID of 0 is self which results in the calling thread
> +   * accidentally deleting itself.
> +  the_regulator->delivery_thread_id = (rtems_id) -1;
> +   * Copy the attributes to an internal area for later use
> +  the_regulator->Attributes = *attributes;
> +   * Allocate memory for the messages. There is no need to zero out the
> +   * message memory because the user should fill that in.
> +  alloc_size = attributes->maximum_message_size * attributes->maximum_messages;
> +  the_regulator->message_memory = calloc(alloc_size, 1);
> +  if (!the_regulator->message_memory) {
> +    _Regulator_Free_helper(the_regulator, 0);
> +   * Associate message memory with a partition so allocations are atomic
> +  sc = rtems_partition_create(
> +    rtems_build_name('P', 'O', 'O', 'L'),
> +    the_regulator->message_memory,
> +    alloc_size,
> +    attributes->maximum_message_size,
> +    RTEMS_DEFAULT_ATTRIBUTES,
> +    &the_regulator->messages_partition_id
> +    return sc;
> +   * Create the message queue between the sender and output thread
> +  RTEMS_MESSAGE_QUEUE_BUFFER(sizeof(_Regulator_Message_t)) regulator_message_t;
> +  size_t storage_size = sizeof(regulator_message_t) * attributes->maximum_messages;
> +  the_regulator->message_queue_storage = malloc(storage_size);
> +  if (the_regulator->message_queue_storage == NULL) {
> +  rtems_message_queue_config mq_config = {
> +    .name = rtems_build_name('S', 'N', 'D', 'Q'),
> +    .maximum_pending_messages =  attributes->maximum_messages,
> +    .maximum_message_size = sizeof(_Regulator_Message_t),
> +    .storage_area = the_regulator->message_queue_storage,
> +    .storage_size = storage_size,
> +    .storage_free = free,
> +    .attributes = RTEMS_DEFAULT_ATTRIBUTES
> +  sc = rtems_message_queue_construct(
> +    &mq_config,
> +    &the_regulator->queue_id
> +    return sc;
> +   * @note A rate monotonic period object must be created by the thread
> +   *       using it. Thus that specific create operation is not included
> +   *       in this method. All other resources are allocated here.
> +   * Create the output thread Using the priority and stack size attributes
> +   * specified by the user.
> +  sc = rtems_task_create(
> +    rtems_build_name('R', 'E', 'G', 'U'),
> +    attributes->delivery_thread_priority,
> +    attributes->delivery_thread_stack_size,
> +    RTEMS_DEFAULT_MODES,
> +    &the_regulator->delivery_thread_id
> +    return sc;
> +   * Start the output thread.
> +   * @note There should be no way this call can fail. The task id is valid,
> +   *       the regulator output thread entry point is valid, and the argument
> +   *       is valid.
> +  the_regulator->delivery_thread_request_exit = false;
> +  the_regulator->delivery_thread_has_exited   = false;
> +  sc = rtems_task_start(
> +    the_regulator->delivery_thread_id,
> +    _Regulator_Output_task_body,
> +    (rtems_task_argument) the_regulator
> +   * The regulator is successfully initialized. Set the initialized field
> +   * to reflect this and return the instance pointer.
> +  the_regulator->initialized = REGULATOR_INITIALIZED;
> +  *regulator = (void *)the_regulator;
> +  return RTEMS_SUCCESSFUL;
> + * @brief Validate the regulator instance provided by the user
> + * Validate the regulator instance provided by the user
> + * @param[in] regulator is the instance provided by the user
> + * @param[inout] status will contain the RTEMS status for this check
> + * @return This method returns a @a _Regulator_Control instance pointer
> + *         which is NULL if invalid or points to the internal regulator
> + *         control structure if valid.
> +static inline _Regulator_Control *_Regulator_Get(
> +  rtems_status_code        *status
> +  _Regulator_Control *the_regulator = (_Regulator_Control *) regulator;
> +    *status = RTEMS_INVALID_ADDRESS;
> +    return NULL;
> +  if (the_regulator->initialized != REGULATOR_INITIALIZED) {
> +    *status = RTEMS_INCORRECT_STATE;
> +    return NULL;
> +  status = RTEMS_SUCCESSFUL;
> +  return the_regulator;
> +  rtems_status_code   status;
> +   * Convert external handle to internal instance pointer
> +  the_regulator = _Regulator_Get(regulator, &status);
> +  if (the_regulator == NULL) {
> +    return status;
> +   * There can be no buffers outstanding
> +  _Regulator_Statistics *stats = &the_regulator->Statistics;
> +  if (stats->obtained != stats->released ) {
> +    return RTEMS_RESOURCE_IN_USE;
> +   * Free the resources associated with this regulator instance.
> +  bool bc;
> +  bc = _Regulator_Free_helper(the_regulator, ticks);
> +  if (bc == false) {
> +    return RTEMS_TIMEOUT;
> + * Allocate a buffer for the caller using the internal partition.
> +  void                       **buffer
> +    return status;
> +   * Allocate a buffer for the user application from the buffer pool managed
> +   * by an Classic API partition.
> +  status = rtems_partition_get_buffer(
> +    buffer
> +  if (status == RTEMS_SUCCESSFUL) {
> +    the_regulator->Statistics.obtained++;
> +  return status;
> +  void                      *buffer
> +    return status;
> +   * Deallocate the buffer to the buffer pool managed by a Classic
> +   * API partition.
> +  status = rtems_partition_return_buffer(
> +    buffer
> +  return status;
> +  void                     *message,
> +  size_t                    length
> +  the_regulator = (_Regulator_Control *) regulator;
> +   * Validate the arguments and ensure the regulator was successfully
> +   * initialized.
> +  if (!message) {
> +  if (length == 0) {
> +    return status;
> +   * Place the message pointer and length into a temporary structure. This
> +   * lets the implementation internally send the message by reference and
> +   * have a zero-copy implementation.
> +  regulator_message.buffer = message;
> +  regulator_message.length = length;
> +   * Send the application message to the output thread for delivery using
> +   * a Classic API message queue.
> +  status = rtems_message_queue_send(
> +    sizeof(_Regulator_Message_t)
> +  if (status != RTEMS_SUCCESSFUL) {
> +    return status;
> +  return status;
> +   * initialized.
> +  if (!statistics) {
> +    return status;
> +   * Zero out the statistics structure in case the get period statistics
> +   * fails below.
> +  memset(statistics, 0, sizeof(rtems_regulator_statistics));
> +   * Fill in the caller's statistics structure from information
> +   * maintained by the regulator instance about buffers processed.
> +  statistics->obtained  = the_regulator->Statistics.obtained;
> +  statistics->released  = the_regulator->Statistics.released;
> +  statistics->delivered = the_regulator->Statistics.delivered;
> +   * Attempt to retrieve the delivery thread's period's statistics.
> +   * NOTE; If the Delivery Thread has not run yet, the period will not
> +   *       exist yet. We should not fail for this reason but it is why
> +   *       we zeroed out the entire structure above.
> +  (void) rtems_rate_monotonic_get_statistics(
> +    &statistics->period_statistics
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index ff4ac8e944..e7ee9cf581 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -507,6 +507,8 @@ links:
>    uid: objmpci
>  - role: build-dependency
>    uid: objpci
> +- role: build-dependency
> +  uid: objregulator
>    uid: objpsxsgnl
> diff --git a/spec/build/cpukit/objregulator.yml b/spec/build/cpukit/objregulator.yml
> index 0000000000..56d6154de9
> --- /dev/null
> +++ b/spec/build/cpukit/objregulator.yml
> @@ -0,0 +1,18 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2023 OAR Corporatoin
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/rtems
> +  source:
> +  - cpukit/include/rtems/regulator.h
> +  - cpukit/include/rtems/regulatorimpl.h
> +links: []
> +source:
> +- cpukit/libmisc/regulator/regulator.c
> +type: build
> diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
> index addcb286ad..c1a6209e99 100644
> --- a/spec/build/testsuites/libtests/grp.yml
> +++ b/spec/build/testsuites/libtests/grp.yml
> @@ -228,6 +228,8 @@ links:
>    uid: record01
>    uid: record02
> +  uid: regulator01
>    uid: rtmonuse
> diff --git a/spec/build/testsuites/libtests/regulator01.yml b/spec/build/testsuites/libtests/regulator01.yml
> index 0000000000..776d0ae34b
> --- /dev/null
> +++ b/spec/build/testsuites/libtests/regulator01.yml
> @@ -0,0 +1,21 @@
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2023 OAR Corporation
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +features: c cprogram
> +includes: []
> +ldflags:
> +- -Wl,--wrap=malloc
> +links: []
> +source:
> +- testsuites/libtests/regulator01/regulator01.c
> +- testsuites/libtests/regulator01/rtems_config.c
> +stlib: []
> +target: testsuites/libtests/regulator01.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/testsuites/libtests/regulator01/regulator01.c b/testsuites/libtests/regulator01/regulator01.c
> index 0000000000..cc5af01223
> --- /dev/null
> +++ b/testsuites/libtests/regulator01/regulator01.c
> @@ -0,0 +1,1310 @@
> + * @defgroup RegulatorTests Regulator Test Cases
> + * @brief Unit test cases for the Regulator
> + * This is a set of unit test cases for the regulator.
> + * @ingroup RegulatorTests
> + * @file
> + * @brief Test 01 for Regulator Library
> + * are met:
> +#include <stdio.h>
> +#include <string.h>
> +#include <unistd.h>
> +#include <rtems.h>
> +#include <rtems/test-info.h>
> +#include <tmacros.h>
> + * @brief Regulator Test Name
> +const char rtems_test_name[] = "Regulator 1";
> + * Prototypes for wrapped functions
> +void *__wrap_malloc(size_t size);
> +void *__real_malloc(size_t size);
> + * @brief Calloc Wrapper Trigger Count
> +static int malloc_trigger_count;
> + * @brief Calloc Wrapper Call Count
> +static int malloc_call_count;
> + * @brief Calloc Wrapper Trigger enable
> +static bool malloc_trigger_enabled;
> + * @brief Enable Calloc Wrapper Trigger
> +static void malloc_trigger_enable(
> +  int trigger_count
> +  malloc_trigger_enabled = true;
> +  malloc_trigger_count = trigger_count;
> +  malloc_call_count = 0;
> + * @brief Reset Calloc Wrapper Trigger and Count
> +static void malloc_trigger_reset(void)
> +  malloc_trigger_enabled = 0;
> +  malloc_trigger_count = 0;
> + * @brief Calloc Wrapper to Trigger Allocation Errors
> +  if (malloc_trigger_enabled) {
> +    malloc_call_count++;
> +    if (malloc_call_count == malloc_trigger_count) {
> +      return NULL;
> +  return __real_malloc(size);
> + * @brief Constant to simpify code
> +#define FIVE_SECONDS (5 * rtems_clock_get_ticks_per_second())
> + * @brief Empty Deliver Method for Testing
> +static bool test_regulator_deliverer(
> +  void     *context,
> +  void     *message,
> +  size_t    length
> +  (void) context;
> +  (void) message;
> +  (void) length;
> +  return true;
> + * @brief Maximum length of a test message that is delivered
> +#define MAXIMUM_MESSAGE_LENGTH 32
> + * @brief Maximum number of test messages to buffer
> +#define MAXIMUM_MESSAGES_TO_BUFFER 10
> + * @brief Structure for capturing messages as delivered
> +typedef struct {
> +  rtems_interval processed;
> +  char           message[MAXIMUM_MESSAGE_LENGTH];
> +} message_log_t;
> + * @brief Set of Delivered messages
> +message_log_t delivered_messages[MAXIMUM_MESSAGES_TO_BUFFER];
> + * @brief Count of Delivered messages
> +int delivered_message_count;
> + * @brief Reset Delivered Message Set
> + * This is used at the beginning of a test case which is going to
> + * check that message contents and delivery times were as expected.
> +static void delivered_messages_reset(void)
> +  delivered_message_count = 0;
> +  memset(delivered_messages, 0xc5, sizeof(delivered_messages));
> + * @brief Context for Logger Delivery Function
> +typedef struct {
> +  /** Regulator instance being operated on */
> +  rtems_regulator_instance   *regulator;
> +} deliverer_logger_context_t;
> + * @brief Context Instance for Logger Delivery Function
> +static deliverer_logger_context_t deliverer_logger_context;
> + * This deliverer method implementation logs the messages along with
> + * their time of arrival. This is used by the test cases to verify
> + * proper delivery.
> +static bool test_regulator_deliverer_logger(
> +  void     *context,
> +  void     *message,
> +  size_t    length
> +  deliverer_logger_context_t *the_context;
> +  the_context = (deliverer_logger_context_t *)context;
> +  static bool caller_releases_buffer = true;
> +  size_t             len;
> +  rtems_interval     ticks;
> +  len = strnlen(message, MAXIMUM_MESSAGE_LENGTH) + 1;
> +  rtems_test_assert(len = length);
> +  ticks = rtems_clock_get_ticks_since_boot();
> +  delivered_messages[delivered_message_count].processed = ticks;
> +  strcpy(delivered_messages[delivered_message_count].message, message);
> +  delivered_message_count++;
> +   * Alternate releasing the buffer here and allowing the calling Delivery
> +   * Thread to do it. This increases coverage of that logic.
> +  if (caller_releases_buffer == true) {
> +    caller_releases_buffer = false;
> +    return true;
> +  sc = rtems_regulator_release_buffer(the_context->regulator, message);
> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +  return false;
> + * @brief Helper to create a Regulator instance
> + * This helper creates a regulator instance with some arbitrary attributes.
> + * This is used in multiple test cases to have a valie regulator instance to
> + * trigger error cases.
> +static rtems_regulator_instance *test_regulator_create_regulator_OK(void)
> +  rtems_regulator_attributes  attributes = {
> +    .deliverer = test_regulator_deliverer,
> +    .deliverer_context = NULL,
> +    .maximum_message_size = 16,
> +    .maximum_messages = 10,
> +    .delivery_thread_priority = 16,
> +    .delivery_thread_stack_size = 0,
> +    .delivery_thread_period = RTEMS_MILLISECONDS_TO_TICKS(1000),
> +    .maximum_to_dequeue_per_period = 3
> +  regulator = NULL;
> +  sc = rtems_regulator_create(&attributes, &regulator);
> +  rtems_test_assert(regulator != NULL);
> +  return regulator;
> + * @brief Verify rtems_regulator_create() maximum_to_dequeue_per_period
> + * attributes error
> + * This unit test verifies that rtems_regulator_create() returns an error when
> + * the maximum_to_dequeue_per_period attribute is zero.
> +static void test_regulator_create_max_dequeue_zero(void)
> +    .maximum_to_dequeue_per_period = 0
> +  regulator = NULL;
> +  rtems_test_assert(sc == RTEMS_INVALID_NUMBER);
> + * @brief Verify rtems_regulator_create() NULL attributes error
> + * the attributes argument is NULL.
> +static void test_regulator_create_null_attributes(void)
> +  sc = rtems_regulator_create(NULL, &regulator);
> +  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
> + * @brief Verify rtems_regulator_create NULL regulator error
> + * the regulator argument is NULL.
> +static void test_regulator_create_null_regulator(void)
> +  rtems_regulator_attributes  attributes;
> +  sc = rtems_regulator_create(&attributes, NULL);
> + * @brief Verify rtems_regulator_create deliverer is NULL
> + * the the attributes deliverer field is NULL.
> +static void test_regulator_create_deliverer_is_null(void)
> +  (void) memset(&attributes, 0, sizeof(rtems_regulator_attributes));
> +  attributes.deliverer                     = NULL;
> +  attributes.maximum_messages              = 0;
> +  attributes.maximum_message_size          = 16;
> +  attributes.maximum_to_dequeue_per_period = 1;
> + * @brief Verify rtems_regulator_create maximum_messages is 0 error
> + * the the attributes maximum_messages field is 0.
> +static void test_regulator_create_maximum_messages_is_zero(void)
> +  attributes.deliverer                     = test_regulator_deliverer;
> + * @brief Verify rtems_regulator_create maximum_message_size is 0 error
> + * the the attributes maximum_message_size field is 0.
> +static void test_regulator_create_maximum_message_size_is_zero(void)
> +  attributes.maximum_messages              = 10;
> +  attributes.maximum_message_size          = 0;
> +  rtems_test_assert(sc == RTEMS_INVALID_SIZE);
> + * @brief Verify rtems_regulator_create maximum_to_dequeue_per_period is 0 error
> + * the the attributes maximum_to_dequeue_per_period field is 0.
> +static void test_regulator_create_maximum_to_dequeue_per_period_is_zero(void)
> + * @brief Verify rtems_regulator_create returns error on failure to allocate regulator
> + * it is unable to allocate the mmemory for the regulator instance.
> +static void test_regulator_create_malloc_regulator_fails(void)
> +  attributes.delivery_thread_priority      = 32;
> +  attributes.delivery_thread_period        = RTEMS_MILLISECONDS_TO_TICKS(1000);
> +  malloc_trigger_enable(1);
> +  rtems_test_assert(sc == RTEMS_NO_MEMORY);
> +  malloc_trigger_reset();
> + * @brief Verify rtems_regulator_create returns error on failure to allocate buffers
> + * it is unable to allocate the mmemory for the regulator buffers.
> +static void test_regulator_create_malloc_buffers_fails(void)
> +  malloc_trigger_enable(2);
> + * @brief Verify rtems_regulator_create and delete work
> + * This unit test verifies that rtems_regulator_create() can successfully create
> + * the the attributes delivery_thread_priority field is 0.
> +static void test_regulator_create_delivery_thread_priority_is_zero(void)
> +  attributes.delivery_thread_priority      = 0;
> +  rtems_test_assert(sc == RTEMS_INVALID_PRIORITY);
> + * @brief Verify rtems_regulator_create rtems_partition_create error
> + * This unit test verifies that rtems_regulator_create() correctly returns an
> + * error when the call to rtems_partition_create() fails.
> +static void test_regulator_create_partition_create_fails(void)
> +  rtems_id                    partition_id;
> +  unsigned long               partition_area[16];
> +    rtems_build_name('T', 'P', 'T', 'P'),
> +    partition_area,
> +    16 * sizeof(unsigned long),
> +    2 * sizeof(unsigned long),
> +    &partition_id
> +  attributes.delivery_thread_priority      = 8;
> +  rtems_test_assert(sc == RTEMS_TOO_MANY);
> +  sc = rtems_partition_delete(partition_id);
> + * @brief Verify rtems_regulator_create rtems_message_queue_create error
> + * error when the call to rtems_message_queue_create() fails.
> +static void test_regulator_create_message_queue_create_fails(void)
> +  sc = rtems_message_queue_create(
> +    rtems_build_name('T', 'Q', 'T', 'Q'),
> +    4,
> +    sizeof(unsigned long),
> +    &queue_id
> +  sc = rtems_message_queue_delete(queue_id);
> + * @brief Verify rtems_regulator_create rtems_task_create error
> + * error when the call to rtems_task_create() fails.
> +static void test_regulator_create_task_create_fails(void)
> +  rtems_id                    task_id;
> +    rtems_build_name('T', 'T', 'T', 'T'),
> +    80,
> +    0,
> +    &task_id
> +  sc = rtems_task_delete(task_id);
> + * @brief Verify Regulator Output Thread Handles Error on Period Create
> + * This unit test verifies that regulator output thread correctly exits
> + * when the call to rtems_rate_monotonic_create() fails.
> + * This error condition/path cannot be directly detected via a return code,
> + * It is verified via a debugger or code coverage reports.
> +static void test_regulator_create_rate_monotonic_create_fails(void)
> +  rtems_id                    period_id;
> +    rtems_build_name('T', 'S', 'T', 'P'),
> +    &period_id
> +   * Let the output thread execute and encounter the create error.
> +  sleep(1);
> +   * Now deallocate the resources allocated earlier
> +  sc = rtems_regulator_delete(regulator, FIVE_SECONDS);
> +  sc = rtems_rate_monotonic_delete(period_id);
> + * @brief Verify rtems_regulator_delete NULL regulator error
> + * This unit test verifies that rtems_regulator_delete() returns an error when
> +static void test_regulator_delete_null_regulator(void)
> +  sc = rtems_regulator_delete(NULL, FIVE_SECONDS);
> + * @brief Verify rtems_regulator_delete uninitialized regulator error
> + * the regulator argument is uninitialized.
> +static void test_regulator_delete_uninitialized_regulator(void)
> +  rtems_regulator_instance  regulator;
> +  (void) memset(&regulator, 0, sizeof(regulator));
> +  sc = rtems_regulator_delete(&regulator, 0);
> +  rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
> + * @brief Verify rtems_regulator_delete successful case
> + * This unit test verifies that rtems_regulator_delete() can be successfully
> + * deleted.
> +static void test_regulator_delete_OK(void)
> +  regulator = test_regulator_create_regulator_OK();
> + * @brief Verify rtems_regulator_obtain_buffer NULL regulator error
> + * This unit test verifies that rtems_regulator_obtain_buffer() returns an error when
> +static void test_regulator_obtain_buffer_null_regulator(void)
> +  void               *buffer;
> +  sc = rtems_regulator_obtain_buffer(NULL, &buffer);
> + * @brief Verify rtems_regulator_obtain_buffer uninitialized regulator error
> +static void test_regulator_obtain_buffer_uninitialized_regulator(void)
> +  void                     *buffer;
> +  sc = rtems_regulator_obtain_buffer(&regulator, &buffer);
> + * @brief Verify rtems_regulator_obtain_buffer successful case
> + * This unit test verifies that rtems_regulator_obtain_buffer() can be successfully
> + * obtained from an initialized regulator.
> +static void test_regulator_obtain_buffer_OK(void)
> +  void                     *buffer;
> +  sc = rtems_regulator_obtain_buffer(regulator, &buffer);
> +  rtems_test_assert(buffer != NULL);
> +   * Not really testing this here but cannot delete underlying partition
> +   * if there are buffers outstanding.
> +  sc = rtems_regulator_release_buffer(regulator, buffer);
> + * @brief Verify rtems_regulator_release_buffer NULL regulator error
> + * This unit test verifies that rtems_regulator_release_buffer() returns an error when
> +static void test_regulator_release_buffer_null_regulator(void)
> +  void               *buffer;
> +  sc = rtems_regulator_release_buffer(NULL, &buffer);
> + * @brief Verify rtems_regulator_release_buffer uninitialized regulator error
> + * error when the regulator argument is uninitialized.
> +static void test_regulator_release_buffer_uninitialized_regulator(void)
> +  void                     *buffer;
> +  sc = rtems_regulator_release_buffer(&regulator, &buffer);
> + * @brief Verify rtems_regulator_release_buffer successful case
> + * This unit test verifies that rtems_regulator_release_buffer() can be successfully
> + * invoked with a buffer previously allocated by rtems_regulator_obtain_buffer().
> +static void test_regulator_release_buffer_OK(void)
> +  void                     *buffer;
> + * @brief Verify rtems_regulator_send NULL regulator error
> + * This unit test verifies that rtems_regulator_send() returns an error when
> +static void test_regulator_send_null_regulator(void)
> +  void               *buffer;
> +  size_t              length;
> +  buffer = &length;
> +  length = sizeof(size_t);
> +  sc = rtems_regulator_send(NULL, buffer, length);
> + * @brief Verify rtems_regulator_send NULL message error
> + * the message argument is NULL.
> +static void test_regulator_send_null_message(void)
> +  size_t                    length;
> +  sc = rtems_regulator_send(&regulator, NULL, length);
> + * @brief Verify rtems_regulator_send zero length message error
> + * error when the message length is 0.
> +static void test_regulator_send_length_is_zero(void)
> +  void                     *buffer;
> +  size_t                    length;
> +  buffer = &length;
> +  length = 0;
> +  sc = rtems_regulator_send(&regulator, buffer, length);
> + * @brief Verify rtems_regulator_send uninitialized regulator error
> +static void test_regulator_send_uninitialized_regulator(void)
> +  void                     *buffer;
> +  size_t                    length;
> +  buffer = &length;
> + * @brief Verify Cannot Delete with Message Outstanding
> + * This unit test verifies that when the regulator is successfully
> + * initialized, that it cannot be deleted with an undelivered message.
> + * It also verifies some basic statistics are working.
> +static void test_regulator_cannot_delete_with_outstanding(void)
> +  void                     *buffer;
> +  size_t                    length;
> +  int                       match;
> +    .deliverer = test_regulator_deliverer_logger,
> +    .deliverer_context = &deliverer_logger_context,
> +    .delivery_thread_period = RTEMS_MILLISECONDS_TO_TICKS(250),
> +  rtems_regulator_statistics stats;
> +  deliverer_logger_context.regulator = regulator;
> +  delivered_messages_reset();
> +  // Ensure statistics show no buffers obtained or processed
> +  sc = rtems_regulator_get_statistics(regulator, &stats);
> +  rtems_test_assert(stats.obtained == 0);
> +  rtems_test_assert(stats.released == 0);
> +  rtems_test_assert(stats.delivered == 0);
> +  rtems_test_assert(stats.period_statistics.count == 0);
> +  rtems_test_assert(stats.period_statistics.missed_count == 0);
> +  // Obtain a buffer which should change the statistics
> +  // Ensure statistics show one buffer obtained
> +  rtems_test_assert(stats.obtained == 1);
> +  // Format and send the message -- statistics do not change
> +  length = snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d", 1024) + 1;
> +  strcpy(buffer, message);
> +  sc = rtems_regulator_send(regulator, buffer, length);
> +  // This is the actual failing case -- cannot delete w/outstanding
> +  rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
> +  // Now let the deliveries happen
> +  sleep(1);
> +  // Ensure statistics show all buffers released
> +  rtems_test_assert(stats.released == 1);
> +  rtems_test_assert(stats.delivered == 1);
> +  rtems_test_assert(stats.period_statistics.count != 0);
> +  rtems_test_assert(delivered_message_count == 1);
> +  match = strncmp(
> +    delivered_messages[0].message,
> +    message,
> +    MAXIMUM_MESSAGE_LENGTH
> +  rtems_test_assert(match == 0);
> +  deliverer_logger_context.regulator = NULL;
> + * @brief Verify rtems_regulator_send and output thread delivers message
> + * successfully initialized and used as expected, a message sent via
> + * rtems_regulator_send() is delivered as expected.
> +static void test_regulator_send_one_message_OK(void)
> +  void                     *buffer;
> +  size_t                    length;
> +  int                       match;
> +  sleep(1);
> +  match = strncmp(
> +    message,
> + * @brief Verify rtems_regulator_send and output thread delivers messages
> + * This unit test verifies that when the regulator is successfully initialized
> + * and used as expected, and multiple messages are sent via rtems_regulator_send()
> + * that they are delivered as expected.
> +#include <stdio.h>
> +static void test_regulator_send_multiple_messages_OK(void)
> +  void                     *buffer;
> +  size_t                    length;
> +  int                       match;
> +  int                       i;
> +  time_t                    base_time;
> +  time_t                    tmp_time;
> +  rtems_interval            base_ticks;
> +  rtems_interval            ticks_per_second;
> +    .maximum_message_size = MAXIMUM_MESSAGE_LENGTH,
> +    .maximum_to_dequeue_per_period = 2
> +   * Ensure the messages are sent on a second boundary to ensure the
> +   * output thread will process them as expected.
> +  tmp_time = time(NULL);
> +  do {
> +    base_time = time(NULL);
> +  } while (tmp_time == base_time);
> +   * Send five messages as a burst which will need to be smoothly sent at
> +   * the configured rate.
> +  for (i=1 ; i <= 5 ; i++) {
> +    length = snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d", i);
> +   * Let the output thread executed and deliver the messages.
> +  sleep(5);
> +   * Ensure the five messages were delivered as follows:
> +   *   - deliver all 5
> +   *   - contents are "message N" where N is 1 to 5
> +   *   - message 1 and 2 delivered during the first second
> +   *   - message 3 and 4 delivered during the second second
> +   *   - message 5 delivered during the third second
> +   *   - no further messages delivered
> +  rtems_test_assert(delivered_message_count == 5);
> +  for (i=0 ; i < 5 ; i++) {
> +    (void) snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d", i+1);
> +// printf("%d %s\n", i, delivered_messages[i].message);
> +    match = strncmp(
> +      delivered_messages[i].message,
> +      message,
> +   * Verify that messages were delivered in the proper groups. Check that
> +   * the delivery time matches expectations.
> +  rtems_test_assert(delivered_messages[0].processed == delivered_messages[1].processed);
> +  rtems_test_assert(delivered_messages[1].processed != delivered_messages[2].processed);
> +  rtems_test_assert(delivered_messages[2].processed == delivered_messages[3].processed);
> +  rtems_test_assert(delivered_messages[3].processed != delivered_messages[4].processed);
> +   * Verify that the message groups were properly spaced temporally. They
> +   * should be one second apart.
> +  ticks_per_second = rtems_clock_get_ticks_per_second();
> +  base_ticks = delivered_messages[1].processed;
> +  ticks      = delivered_messages[2].processed;
> +  rtems_test_assert(ticks_per_second == ticks - base_ticks);
> +  base_ticks = delivered_messages[3].processed;
> +  ticks      = delivered_messages[4].processed;
> +/* Necessary prototype */
> +rtems_task test_regulator(rtems_task_argument);
> + * @ingroup RegulatorTestshttps://devel.rtems.org/milestone/6.1
> + * @brief Test entry task which invokes test cases
> +rtems_task test_regulator(rtems_task_argument arg)
> +  (void) arg;
> +  TEST_BEGIN();
> +  test_regulator_create_max_dequeue_zero();
> +  test_regulator_create_null_attributes();
> +  test_regulator_create_null_regulator();
> +  test_regulator_create_deliverer_is_null();
> +  test_regulator_create_maximum_messages_is_zero();
> +  test_regulator_create_maximum_message_size_is_zero();
> +  test_regulator_create_maximum_to_dequeue_per_period_is_zero();
> +  test_regulator_create_malloc_regulator_fails();
> +  test_regulator_create_malloc_buffers_fails();
> +  test_regulator_create_delivery_thread_priority_is_zero();
> +  test_regulator_create_partition_create_fails();
> +  test_regulator_create_message_queue_create_fails();
> +  test_regulator_create_task_create_fails();
> +  test_regulator_create_rate_monotonic_create_fails();
> +  test_regulator_delete_null_regulator();
> +  test_regulator_delete_uninitialized_regulator();
> +  test_regulator_delete_OK();
> +  test_regulator_obtain_buffer_null_regulator();
> +  test_regulator_obtain_buffer_uninitialized_regulator();
> +  test_regulator_obtain_buffer_OK();
> +  test_regulator_release_buffer_null_regulator();
> +  test_regulator_release_buffer_uninitialized_regulator();
> +  test_regulator_release_buffer_OK();
> +  test_regulator_send_null_regulator();
> +  test_regulator_send_null_message();
> +  test_regulator_send_length_is_zero();
> +  test_regulator_send_uninitialized_regulator();
> +  test_regulator_send_one_message_OK();
> +  test_regulator_cannot_delete_with_outstanding();
> +  test_regulator_send_multiple_messages_OK();
> +  TEST_END();
> +  rtems_test_exit(0);
> diff --git a/testsuites/libtests/regulator01/regulator01.doc b/testsuites/libtests/regulator01/regulator01.doc
> index 0000000000..ff4e8005ec
> --- /dev/null
> +++ b/testsuites/libtests/regulator01/regulator01.doc
> @@ -0,0 +1,67 @@
> +# SPDX-License-Identifier: BSD-2-Clause
> +# Copyright (c) 2023 OAR Corporation
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +#    notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +#    notice, this list of conditions and the following disclaimer in the
> +#    documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +This file describes the directives and concepts tested by this test set.
> +test set name: regulator01
> +directives:
> +  + rtems_regulator_create
> +  + rtems_regulator_delete
> +  + rtems_regulator_obtain_buffer
> +  + rtems_regulator_release_buffer
> +  + rtems_regulator_send
> +concepts
> +  + Verify rtems_regulator_create() maximum_to_dequeue_per_period
> +  + Verify rtems_regulator_create() NULL attributes error
> +  + Verify rtems_regulator_create NULL regulator error
> +  + Verify rtems_regulator_create deliverer is NULL
> +  + Verify rtems_regulator_create maximum_messages is 0 error
> +  + Verify rtems_regulator_create maximum_message_size is 0 error
> +  + Verify rtems_regulator_create maximum_to_dequeue_per_period is 0 error
> +  + Verify rtems_regulator_create returns error on failure to allocate regulator
> +  + Verify rtems_regulator_create returns error on failure to allocate buffers
> +  + Verify rtems_regulator_create and delete work
> +  + Verify rtems_regulator_create rtems_partition_create error
> +  + Verify rtems_regulator_create rtems_message_queue_create error
> +  + Verify rtems_regulator_create rtems_task_create error
> +  + Verify Regulator Output Thread Handles Error on Period Create
> +  + Verify rtems_regulator_delete NULL regulator error
> +  + Verify rtems_regulator_delete uninitialized regulator error
> +  + Verify rtems_regulator_delete successful case
> +  + Verify rtems_regulator_obtain_buffer NULL regulator error
> +  + Verify rtems_regulator_obtain_buffer uninitialized regulator error
> +  + Verify rtems_regulator_obtain_buffer successful case
> +  + Verify rtems_regulator_release_buffer NULL regulator error
> +  + Verify rtems_regulator_release_buffer uninitialized regulator error
> +  + Verify rtems_regulator_release_buffer successful case
> +  + Verify rtems_regulator_send NULL regulator error
> +  + Verify rtems_regulator_send NULL message error
> +  + Verify rtems_regulator_send zero length message error
> +  + Verify rtems_regulator_send uninitialized regulator error
> +  + Verify rtems_regulator_send and output thread delivers message
> +  + Verify rtems_regulator_send and cannot delete with outstanding messages
> diff --git a/testsuites/libtests/regulator01/rtems_config.c b/testsuites/libtests/regulator01/rtems_config.c
> index 0000000000..ca96e1b1dd
> --- /dev/null
> +++ b/testsuites/libtests/regulator01/rtems_config.c
> @@ -0,0 +1,59 @@
> + * @file
> + * @brief RTEMS Configuration for regulator tests
> + *  COPYRIGHT (c) 2022.  *  On-Line Applications Research Corporation (OAR).
> + * are met:
> +#include <rtems.h>
> +#include <bsp.h> /* for device driver prototypes */
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_ENTRY_POINT test_regulator
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +/* Use hard limits to make it easier to trip object creation errors */
> +#define CONFIGURE_MAXIMUM_TASKS 2
> +#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
> +#define CONFIGURE_MAXIMUM_PARTITIONS 1
> +#define CONFIGURE_MAXIMUM_PERIODS 1
> +#define CONFIGURE_UNIFIED_WORK_AREAS
> +#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (8 * 1024)
> +#include <rtems/confdefs.h>
