[PATCH rtems v3 1/1] Add the Regulator Interface and test
Thu Aug 10 05:10:37 UTC 2023
On 09.08.23 17:42, Joel Sherrill wrote:
> Updates #4924.
> The Regulator is an application support class which is used to
> deal with the scenario where there is a bursty input source
> which needs to be metered out to a destination sink. The maximum
> size of bursts needs to be known and the delivery method must
> be configured to deliver messages at a rate that allows the
> traffic to not overflow.
>   cpukit/include/rtems/regulator.h              |  499 +++++++
>   cpukit/include/rtems/regulatorimpl.h          |  135 ++
>   cpukit/libmisc/regulator/regulator.c          |  683 +++++++++
>   spec/build/cpukit/librtemscpu.yml             |    2 +
>   spec/build/cpukit/objregulator.yml            |   18 +
>   spec/build/testsuites/libtests/grp.yml        |    2 +
>   .../build/testsuites/libtests/regulator01.yml |   21 +
>   testsuites/libtests/regulator01/regulator01.c | 1310 +++++++++++++++++
>   .../libtests/regulator01/regulator01.doc      |   67 +
>   .../libtests/regulator01/rtems_config.c       |   59 +
>   10 files changed, 2796 insertions(+)
>   create mode 100644 cpukit/include/rtems/regulator.h
>   create mode 100644 cpukit/include/rtems/regulatorimpl.h
>   create mode 100644 cpukit/libmisc/regulator/regulator.c
>   create mode 100644 spec/build/cpukit/objregulator.yml
>   create mode 100644 spec/build/testsuites/libtests/regulator01.yml
>   create mode 100644 testsuites/libtests/regulator01/regulator01.c
>   create mode 100644 testsuites/libtests/regulator01/regulator01.doc
>   create mode 100644 testsuites/libtests/regulator01/rtems_config.c
> diff --git a/cpukit/include/rtems/regulator.h b/cpukit/include/rtems/regulator.h
> new file mode 100644
> index 0000000000..362a99f6bc
> --- /dev/null
> +++ b/cpukit/include/rtems/regulator.h
> @@ -0,0 +1,499 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
In the header file template we have SPDX, Doxygen @file, copyright.
> + * @defgroup RegulatorAPI Regulator API
> + * @brief Regulator APIs
> + * The Regulator provides a set of APIs to manage input sources which
> + * produces bursts of message traffic.
> + * @mainpage
Do you really want to add this to the main page?
> + * @addtogroup RegulatorAPI
> + * @file
> + * @brief This header file defines the Regulator API.
This should be @file followed by @ingroup RegulatorAPI.
> + * @ingroup RegulatorAPI
> + * @brief Regulator Instance
> + * This is used by the application as the handle to a Regulator instance.
> +typedef void *rtems_regulator_instance;
I think this should be rtems_regulator_control. You can also use a
forward declaration
struct rtems_regulator_control;
typedef struct rtems_regulator_control rtems_regulator_control;
to provide a type safe API and ease debugging.
If you use the interface specification in rtems-central for this new
API, you can keep the Doxygen and Classic API documentation in
synchronization. You could use it also to write validation tests.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
