[PATCH] build: Create deterministic tar archives
Thu Aug 10 10:19:11 UTC 2023
This helps to make the build reproducible.
 wscript | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/wscript b/wscript
index a8fca88dcb..4baf701c27 100755
--- a/wscript
+++ b/wscript
@@ -188,6 +188,15 @@ def process_start_files(self):
         self.link_task.dep_nodes.extend(self.bld.start_files)
+def deterministic_tar_info(info):
+    info.uid = 0
+    info.gid = 0
+    info.mtime = 0
+    info.uname = "root"
+    info.gname = "root"
+    return info
 class Item(object):
     def __init__(self, uid, data):
@@ -479,7 +488,7 @@ class Item(object):
                 dst = src
                 for r in remove:
                     dst = src.replace(srcpath + r, "").replace(bldpath + r, "")
-                tar.add(src, dst)
+                tar.add(src, dst, filter=deterministic_tar_info)
             tar.close()
             return 0
2.35.3
