[PATCH] build: Add target to build scripts
Fri Aug 11 05:51:13 UTC 2023
On 11.08.23 07:40, Chris Johns wrote:
> On 11/8/2023 3:33 pm, Sebastian Huber wrote:
>> On 11.08.23 02:21, Chris Johns wrote:
>>> On 10/8/2023 7:02 pm, Sebastian Huber wrote:
>>>> Document that the build scripts in the testsuites produce a test program.
>>> I am sorry but I do not understand this change and why we need it. Is the
>>> addition of the target line purely cosmetic?
>> This information can be used to associate test executables with build items and
>> vice versa.
> We just these tests?
These are the only tests which are produced by a build script. The other
tests already have a target attribute.
> I am struggling to see a need. If you have a need it may help to outline it.
This can be used to improve the quality of test documents which use the
build specification and a test report in JSON as input.
> Also I cannot see anything we have to make sure the path is valid.
Yes, currently the path in the target attribute and in the script have a
bit of redundancy. I don't think it is worth the cost to get rid of this
redundancy since we have it only in a couple of files.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
