[PATCH rtems v3 1/1] Add the Regulator Interface and test
Thu Aug 10 22:14:44 UTC 2023
I should have asked if you want another round of patches or just go ahead
and merge. This set of changes was pretty minor.
--joel
On Thu, Aug 10, 2023 at 5:13 PM Joel Sherrill <joel at rtems.org> wrote:
> I think I have addressed all of your comments and Chris'.
> The conversion to rtems-central might be nice but it isn't going to happen
> soon.
> --joel
> On Thu, Aug 10, 2023 at 12:10 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 09.08.23 17:42, Joel Sherrill wrote:
>> > Updates #4924.
>> > The Regulator is an application support class which is used to
>> > deal with the scenario where there is a bursty input source
>> > which needs to be metered out to a destination sink. The maximum
>> > size of bursts needs to be known and the delivery method must
>> > be configured to deliver messages at a rate that allows the
>> > traffic to not overflow.
>> >   cpukit/include/rtems/regulator.h              |  499 +++++++
>> >   cpukit/include/rtems/regulatorimpl.h          |  135 ++
>> >   cpukit/libmisc/regulator/regulator.c          |  683 +++++++++
>> >   spec/build/cpukit/librtemscpu.yml             |    2 +
>> >   spec/build/cpukit/objregulator.yml            |   18 +
>> >   spec/build/testsuites/libtests/grp.yml        |    2 +
>> >   .../build/testsuites/libtests/regulator01.yml |   21 +
>> >   testsuites/libtests/regulator01/regulator01.c | 1310 +++++++++++++++++
>> >   .../libtests/regulator01/regulator01.doc      |   67 +
>> >   .../libtests/regulator01/rtems_config.c       |   59 +
>> >   10 files changed, 2796 insertions(+)
>> >   create mode 100644 cpukit/include/rtems/regulator.h
>> >   create mode 100644 cpukit/include/rtems/regulatorimpl.h
>> >   create mode 100644 cpukit/libmisc/regulator/regulator.c
>> >   create mode 100644 spec/build/cpukit/objregulator.yml
>> >   create mode 100644 spec/build/testsuites/libtests/regulator01.yml
>> >   create mode 100644 testsuites/libtests/regulator01/regulator01.c
>> >   create mode 100644 testsuites/libtests/regulator01/regulator01.doc
>> >   create mode 100644 testsuites/libtests/regulator01/rtems_config.c
>> > diff --git a/cpukit/include/rtems/regulator.h
>> b/cpukit/include/rtems/regulator.h
>> > new file mode 100644
>> > index 0000000000..362a99f6bc
>> > --- /dev/null
>> > +++ b/cpukit/include/rtems/regulator.h
>> > @@ -0,0 +1,499 @@
>> > +/* SPDX-License-Identifier: BSD-2-Clause */
>> In the header file template we have SPDX, Doxygen @file, copyright.
>> > + * @defgroup RegulatorAPI Regulator API
>> > + * @brief Regulator APIs
>> > + * The Regulator provides a set of APIs to manage input sources which
>> > + * produces bursts of message traffic.
>> > + * @mainpage
>> Do you really want to add this to the main page?
>> > + * @addtogroup RegulatorAPI
>> > + * @file
>> > + * @brief This header file defines the Regulator API.
>> This should be @file followed by @ingroup RegulatorAPI.
>> > + * @ingroup RegulatorAPI
>> > + * @brief Regulator Instance
>> > + * This is used by the application as the handle to a Regulator
>> instance.
>> > +typedef void *rtems_regulator_instance;
>> I think this should be rtems_regulator_control. You can also use a
>> forward declaration
>> struct rtems_regulator_control;
>> typedef struct rtems_regulator_control rtems_regulator_control;
>> to provide a type safe API and ease debugging.
>> If you use the interface specification in rtems-central for this new
>> API, you can keep the Doxygen and Classic API documentation in
>> synchronization. You could use it also to write validation tests.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax:   +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230810/ade1d3b1/attachment.htm>
