[PATCH rtems v3 1/1] Add the Regulator Interface and test
Thu Aug 10 22:13:28 UTC 2023
I think I have addressed all of your comments and Chris'.
The conversion to rtems-central might be nice but it isn't going to happen
soon.
--joel
On Thu, Aug 10, 2023 at 12:10 AM Sebastian Huber <
> On 09.08.23 17:42, Joel Sherrill wrote:
> > Updates #4924.
> > The Regulator is an application support class which is used to
> > deal with the scenario where there is a bursty input source
> > which needs to be metered out to a destination sink. The maximum
> > size of bursts needs to be known and the delivery method must
> > be configured to deliver messages at a rate that allows the
> > traffic to not overflow.
> >   cpukit/include/rtems/regulator.h              |  499 +++++++
> >   cpukit/include/rtems/regulatorimpl.h          |  135 ++
> >   cpukit/libmisc/regulator/regulator.c          |  683 +++++++++
> >   spec/build/cpukit/librtemscpu.yml             |    2 +
> >   spec/build/cpukit/objregulator.yml            |   18 +
> >   spec/build/testsuites/libtests/grp.yml        |    2 +
> >   .../build/testsuites/libtests/regulator01.yml |   21 +
> >   testsuites/libtests/regulator01/regulator01.c | 1310 +++++++++++++++++
> >   .../libtests/regulator01/regulator01.doc      |   67 +
> >   .../libtests/regulator01/rtems_config.c       |   59 +
> >   10 files changed, 2796 insertions(+)
> >   create mode 100644 cpukit/include/rtems/regulator.h
> >   create mode 100644 cpukit/include/rtems/regulatorimpl.h
> >   create mode 100644 cpukit/libmisc/regulator/regulator.c
> >   create mode 100644 spec/build/cpukit/objregulator.yml
> >   create mode 100644 spec/build/testsuites/libtests/regulator01.yml
> >   create mode 100644 testsuites/libtests/regulator01/regulator01.c
> >   create mode 100644 testsuites/libtests/regulator01/regulator01.doc
> >   create mode 100644 testsuites/libtests/regulator01/rtems_config.c
> > diff --git a/cpukit/include/rtems/regulator.h
> b/cpukit/include/rtems/regulator.h
> > new file mode 100644
> > index 0000000000..362a99f6bc
> > --- /dev/null
> > +++ b/cpukit/include/rtems/regulator.h
> > @@ -0,0 +1,499 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> In the header file template we have SPDX, Doxygen @file, copyright.
> > + * @defgroup RegulatorAPI Regulator API
> > + * @brief Regulator APIs
> > + * The Regulator provides a set of APIs to manage input sources which
> > + * produces bursts of message traffic.
> > + * @mainpage
> Do you really want to add this to the main page?
> > + * @addtogroup RegulatorAPI
> > + * @file
> > + * @brief This header file defines the Regulator API.
> This should be @file followed by @ingroup RegulatorAPI.
> > + * @ingroup RegulatorAPI
> > + * @brief Regulator Instance
> > + * This is used by the application as the handle to a Regulator
> instance.
> > +typedef void *rtems_regulator_instance;
> I think this should be rtems_regulator_control. You can also use a
> forward declaration
> struct rtems_regulator_control;
> typedef struct rtems_regulator_control rtems_regulator_control;
> to provide a type safe API and ease debugging.
> If you use the interface specification in rtems-central for this new
> API, you can keep the Doxygen and Classic API documentation in
> synchronization. You could use it also to write validation tests.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230810/ab29e471/attachment-0001.htm>
