[PATCH rtems-tools] tester/report: Apply test excludes to fatal-error
Kinsey Moore kinsey.moore at oarcorp.com
Wed Aug 16 21:36:24 UTC 2023
Before the fatal-error test result type was introduced, minimum.exe was
classified as an invalid test since it lacked a proper test header and
trailer. This applies the test exclusions to all test states to avoid
this happening again in the future.
 tester/rt/report.py | 15 +++++++--------
 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/tester/rt/report.py b/tester/rt/report.py
index a688dc8..5c369e6 100644
--- a/tester/rt/report.py
+++ b/tester/rt/report.py
@@ -192,7 +192,11 @@ class report(object):
                         if tools != self.config['tools']:
                             state = 'WRONG_TOOLS'
             if state is None or state == 'EXPECTED_PASS':
-                if start and end:
+                exe_name = path.basename(name).split('.')[0]
+                if exe_name in test_fail_excludes:
+                    status = 'passed'
+                    self.passed += 1
+                elif start and end:
                         status = 'passed'
                         self.passed += 1
@@ -210,13 +214,8 @@ class report(object):
                         status = 'failed'
                         self.failed += 1
                 else:
-                    exe_name = path.basename(name).split('.')[0]
-                    if exe_name in test_fail_excludes:
-                        status = 'passed'
-                        self.passed += 1
-                    else:
-                        status = 'invalid'
-                        self.invalids += 1
+                    status = 'invalid'
+                    self.invalids += 1
             else:
                 if state == 'EXPECTED_FAIL':
                     if start and end:
2.39.2
