[PATCH rtems-tools] tester/report: Apply test excludes to fatal-error
Thu Aug 17 02:47:48 UTC 2023
On 17/8/2023 7:36 am, Kinsey Moore wrote:
> Before the fatal-error test result type was introduced, minimum.exe was
> classified as an invalid test since it lacked a proper test header and
> trailer. This applies the test exclusions to all test states to avoid
> this happening again in the future.
I do not think this right. What state are you seeing?
While we cannot determine the pass state because there is no end message we can
determine if the test has timed out or is too long and they should be a fail.
