[PATCH rtems-tools v4] tester/rtemstoolkit: add renode implementation
Fri Aug 18 14:59:17 UTC 2023
On Sun, Aug 6, 2023 at 11:05 PM Muhammad Sulthan Mazaya
<msulthanmazaya at gmail.com> wrote:
> Add gpl to the prom binary file name + include the leon3 prom assembly
> source with licensing commented
>  .../testing/bsps/kendrytek210-renode.ini      |  38 ++++
>  tester/rtems/testing/bsps/leon3-renode.ini    |  37 ++++
>  tester/rtems/testing/renode.cfg               |  64 ++++++
>  tester/rtems/testing/renode/kendrytek210.resc |  86 ++++++++
>  tester/rtems/testing/renode/leon3-prom-gpl.S  | 205 ++++++++++++++++++
>  .../rtems/testing/renode/leon3-prom-gpl.bin   | Bin 0 -> 529 bytes
>  tester/rtems/testing/renode/leon3.resc        |  82 +++++++
>  7 files changed, 512 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
>  create mode 100644 tester/rtems/testing/bsps/leon3-renode.ini
>  create mode 100644 tester/rtems/testing/renode.cfg
>  create mode 100644 tester/rtems/testing/renode/kendrytek210.resc
>  create mode 100644 tester/rtems/testing/renode/leon3-prom-gpl.S
>  create mode 100755 tester/rtems/testing/renode/leon3-prom-gpl.bin
>  create mode 100644 tester/rtems/testing/renode/leon3.resc
> diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> new file mode 100644
> index 0000000..8f7f673
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> @@ -0,0 +1,38 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright (C) 2023, 2023 Muhammad Sulthan Mazaya (msulthanmazaya at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The Kendrytek210 Renode BSP
> +[kendrytek210-renode]
> +bsp             = kendrytek210-renode
> +arch            = riscv
> +tester          = %{_rtscripts}/renode.cfg
> +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
This file / directory doesn't exist. I think you mean renode/
If this works for you, I'm guessing you have a stale directory of
renode_scripts in your rtems-tools repo locally.
> diff --git a/tester/rtems/testing/bsps/leon3-renode.ini b/tester/rtems/testing/bsps/leon3-renode.ini
> index 0000000..d5f7c17
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/leon3-renode.ini
> @@ -0,0 +1,37 @@
> +# # 1. Redistributions of source code must retain the above copyright notice,
> +# The Leon3 Renode BSP
> +[leon3-renode]
> +bsp             = leon3-renode
> +arch            = sparc
> +bsp_resc_script = %{_rtscripts}/renode_scripts/leon3.resc
> diff --git a/tester/rtems/testing/renode.cfg b/tester/rtems/testing/renode.cfg
> index 0000000..c7fee25
> --- /dev/null
> +++ b/tester/rtems/testing/renode.cfg
> @@ -0,0 +1,64 @@
> +# Renode
> +# Use a renode command to run the executable in the renode simulator.
> +%include %{_configdir}/base.cfg
> +%include %{_configdir}/checks.cfg
> +# Console.
> +%define console_telnet
> +%include %{_configdir}/console.cfg
> +# RTEMS version
> +%include %{_rtdir}/rtems/version.cfg
> +# Renode executable
> +%define renode_cmd renode --hide-monitor
> +%define binary_opts -e $bin?=@%{test_executable}
> +%define start_opts -e "s @%{bsp_resc_script}"
> +%define add_path -e "path add @%{_rttesting}/renode"
> +%define trim_command sed 's/.*\[output\] //'
> +# Executable
> +%execute %{renode_cmd} %{binary_opts} %{add_path} %{start_opts} | %{trim_command}
> diff --git a/tester/rtems/testing/renode/kendrytek210.resc b/tester/rtems/testing/renode/kendrytek210.resc
> index 0000000..e214aec
> --- /dev/null
> +++ b/tester/rtems/testing/renode/kendrytek210.resc
> @@ -0,0 +1,86 @@
> +using sysbus
> +using monitor
> +mach create "K210"
> +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
> +path add @/
> +showAnalyzer "uartAnalyzer" uart Antmicro.Renode.Analyzers.LoggingUartAnalyzer
> +uartAnalyzer TimestampFormat None
> +set report_repeating_line """
> +from Antmicro.Renode.Logging import ConsoleBackend
> +ConsoleBackend.Instance.ReportRepeatingLines = True
> +set add_hook """
> +def match(line):
> +    ok_to_kill_lines = [
> +        '*** TEST STATE: USER_INPUT',
> +        '*** TEST STATE: BENCHMARK',
> +        '*** END OF TEST ',
> +        '*** FATAL ***'
> +    return any(l in line for l in ok_to_kill_lines)
> +def hook(line):
> +    monitor.Parse("q")
> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"], match, hook)
> +python $add_hook
> +python $report_repeating_line
> +sysbus Tag <0x50440000 0x10000> "SYSCTL"
> +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
> +sysbus Tag <0x5044000C 0x4> "pll1"
> +sysbus Tag <0x50440008 0x4> "pll0"
> +sysbus Tag <0x50440020 0x4> "clk_sel0"
> +sysbus Tag <0x50440028 0x4> "clk_en_cent"
> +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
> +# enable uart tx
> +uart WriteDoubleWord 0x8 0x1
> +machine StartGdbServer 3333
> +macro reset
> +    sysbus LoadELF $bin
> +# runMacro $reset
> diff --git a/tester/rtems/testing/renode/leon3-prom-gpl.S b/tester/rtems/testing/renode/leon3-prom-gpl.S
> index 0000000..91dc3bc
> --- /dev/null
> +++ b/tester/rtems/testing/renode/leon3-prom-gpl.S
> @@ -0,0 +1,205 @@
> + * From https://github.com/TUT-ASI/leon3-grlib-gpl-mirror/blob/master/software/leon3/prom.S
> + * GPL license, version unknown
> +/* Template boot-code for LEON3 test benches */
> +#include "prom.h"
> +#ifndef STACKSIZE
> +#define STACKSIZE 0x00020000
> +#endif
> +       .seg    "text"
> +       .proc   0
> +       .align  4
> +       .global start
> +start:
> +       flush
> +       set 0x10e0, %g1         ! init IU
> +       mov %g1, %psr
> +       mov %g0, %wim
> +       mov %g0, %tbr
> +       mov %g0, %y
> +       mov %g0, %asr16
> +       nop
> +       set  0x81000f, %g1
> +       sta %g1, [%g0] 2
> +       mov %g0, %g2
> +       nop
> +       nop
> +       nop
> +       nop
> +       nop
> +       or %g2, %g2, %g0
> +       nop
> +       nop
> +       nop
> +       nop
> +       nop
> +#ifdef DSUADDR
> +       set     DSUADDR, %g2
> +       st      %g0, [%g2]
> +       st      %g0, [%g2+0x08]
> +       st      %g0, [%g2+0x20]
> +       st      %g0, [%g2+0x24]
> +       st      %g0, [%g2+0x40]
> +       st      %g0, [%g2+0x44]
> +       st      %g0, [%g2+0x50]
> +       st      %g0, [%g2+0x54]
> +       st      %g0, [%g2+0x58]
> +       st      %g0, [%g2+0x5C]
> +#endif
> +2:
> +       mov %asr17, %g3
> +       and %g3, 0x1f, %g3
> +       mov %g0, %g4
> +       mov %g0, %g5
> +       mov %g0, %g6
> +       mov %g0, %g7
> +1:
> +       mov %g0, %l0
> +       mov %g0, %l1
> +       mov %g0, %l2
> +       mov %g0, %l3
> +       mov %g0, %l4
> +       mov %g0, %l5
> +       mov %g0, %l6
> +       mov %g0, %l7
> +       mov %g0, %o0
> +       mov %g0, %o1
> +       mov %g0, %o2
> +       mov %g0, %o3
> +       mov %g0, %o4
> +       mov %g0, %o5
> +       mov %g0, %o6
> +       mov %g0, %o7
> +       subcc %g3, 1, %g3
> +       bge 1b
> +       save
> +       mov     2, %g1
> +       mov     %g1, %wim
> +       set 0x10e0, %g1         ! enable traps
> +       mov %g1, %psr
> +       nop; nop; nop;
> +       mov %psr, %g1
> +       srl %g1, 12, %g1
> +       andcc %g1, 1, %g0
> +       be 1f
> +       nop
> +       set _fsrxx, %g3
> +       ld [%g3], %fsr
> +       ldd [%g3], %f0
> +       ldd [%g3], %f2
> +       ldd [%g3], %f4
> +       ldd [%g3], %f6
> +       ldd [%g3], %f8
> +       ldd [%g3], %f10
> +       ldd [%g3], %f12
> +       ldd [%g3], %f14
> +       ldd [%g3], %f16
> +       ldd [%g3], %f18
> +       ldd [%g3], %f20
> +       ldd [%g3], %f22
> +       ldd [%g3], %f24
> +       ldd [%g3], %f26
> +       ldd [%g3], %f28
> +       ldd [%g3], %f30
> +       nop
> +       nop
> +       nop
> +       nop
> +       nop
> +       faddd %f0, %f2, %f4
> +       nop
> +       nop
> +       nop
> +       nop
> +       ba  1f
> +       nop
> +.align 8
> +_fsrxx:
> +       .word 0
> +       .word 0
> +1:
> +       mov %asr17, %g3
> +       srl %g3, 28, %g3
> +       andcc %g3, 0x0f, %g3
> +       bne 1f
> +        nop
> +#ifdef L2MCTRLIO
> +       set L2MCTRLIO, %g1
> +       set MCFG1, %g2
> +       st  %g2, [%g1]
> +       set MCFG2, %g2
> +       st  %g2, [%g1+4]
> +       set MCFG3, %g2
> +       st  %g2, [%g1+8]
> +#endif
> +!      set IRQCTRL, %g1
> +!      set 0x0ffff, %g2
> +!      st  %g2, [%g1+0x10]
> +#ifdef UARTADDR
> +        set UARTADDR, %g1
> +        st  %g0, [%g1+0xC]
> +        set 3, %g2
> +        st %g2,  [%g1+0x8]
> +#endif
> +#ifdef DDR2CTRLIO
> +       set DDR2CTRLIO, %g1
> +       set DDR2CFG4, %g2
> +       st  %g2, [%g1+12]
> +#endif
> +#ifdef ASDCFG
> +#ifndef SDCTRLPNP
> +#define SDCTRLPNP 0xFFFFF860
> +#endif
> +       set SDCTRLPNP, %g1
> +       ld  [%g1], %g2
> +       srl %g2, 12, %g2
> +       set 0x01009, %g1
> +       subcc %g1, %g2, %g0
> +       bne 1f
> +       set ASDCFG, %g1
> +       set DSDCFG, %g2
> +       st  %g2, [%g1]
> +#endif
> +       ! %g3 = cpu index
> +1:     set STACKSIZE, %g2
> +        mov %g0, %g1
> +2:     subcc %g3, 0, %g0
> +       be 3f
> +       nop
> +       add %g1, %g2, %g1
> +       ba 2b
> +       sub %g3, 1, %g3
> +3:     set RAMSTART+ RAMSIZE-32, %fp
> +       sub %fp, %g1, %fp
> +       sub %fp, 96, %sp
> +       set RAMSTART, %g1
> +       jmp %g1
> +       nop
> +.align 32
> diff --git a/tester/rtems/testing/renode/leon3-prom-gpl.bin b/tester/rtems/testing/renode/leon3-prom-gpl.bin
> new file mode 100755
> index 0000000000000000000000000000000000000000..a42628906b6915c589f6be96fe5de82a940c6529
> GIT binary patch
> literal 529
> zcmYk&F-yZh6bJBsQma+O9uC$)FhikhM;GxB2R}yq7LJ!#(<mZEM2ZwSt%!*D2?}kc
> z4h|h01RaFy;NT$Q;2>1uKedqte%#A at 3Gco0o*blrF<-dG3t at Q`z^jr1PRRmTcO>iC
> zTMbzff4Mk6N(p6;z9(^cO(Mvc#gPB)(jM)TrZYOH3%aB$x~3bd&;cFN5mo7!YIH(@
> zHr8A-`tS_k3&-Z%*61Ed|M=Wmr=mNpLf5ht@^Nm00 at 2%SXIf~_w{S=I)TIY{q-T1e
> z9=*~Vz0)Us(Kr3jXs;yR(V5jGPEMhaPGYtnJn{XMi)JARO?FmcCa(Kp$?ZU5yQrs!
> zJ54GrZPv$AD}B~Ckj{rrNz}U?M<NX<pLe3P0rwm9 at F8u{jQW9NtmRx3HF9;+C at 8B|
> S&~A#~dM!DadpO4bG4%^DAaPm%
> literal 0
> HcmV?d00001
> diff --git a/tester/rtems/testing/renode/leon3.resc b/tester/rtems/testing/renode/leon3.resc
> index 0000000..3196775
> --- /dev/null
> +++ b/tester/rtems/testing/renode/leon3.resc
> @@ -0,0 +1,82 @@
> +using sysbus
> +using monitor
> +mach create "leon3"
> +machine LoadPlatformDescription @platforms/boards/leon3.repl
> +path add @/
> +set add_hook """
> +def my_match(line):
> +        '*** FATAL ***'
> +def my_hook(line):
> +    print line
> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"], my_match, my_hook)
> +python $add_hook
> +macro reset
> +    # The leon3-prom-gpl.bin is built using Antmicro's script from their
> +    # example of how to use renode to test rtems leon3 using renode-test
> +    # https://github.com/antmicro/renode-rtems-leon3/blob/main/build-prom.sh
> +    # The source of the assembly file itself is from Gaisler
> +    # https://github.com/TUT-ASI/leon3-grlib-gpl-mirror/blob/master/software/leon3/prom.S
> +    sysbus LoadBinary @leon3-prom-gpl.bin 0x0
> +    cpu PC 0
> +runMacro $reset
> 2.34.1
> devel mailing list
> devel at rtems.org
