[PATCH rtems-tools v4] tester/rtemstoolkit: add renode implementation
Muhammad Sulthan Mazaya msulthanmazaya at gmail.com
Sat Aug 19 07:38:30 UTC 2023
Oh sorry I miss that, yes I have a stale directory of renode_scripts in my
rtems repo locally
On Fri, Aug 18, 2023 at 10:23 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Aug 6, 2023 at 11:05 PM Muhammad Sulthan Mazaya
> <msulthanmazaya at gmail.com> wrote:
> > Add gpl to the prom binary file name + include the leon3 prom assembly
> > source with licensing commented
> >  .../testing/bsps/kendrytek210-renode.ini      |  38 ++++
> >  tester/rtems/testing/bsps/leon3-renode.ini    |  37 ++++
> >  tester/rtems/testing/renode.cfg               |  64 ++++++
> >  tester/rtems/testing/renode/kendrytek210.resc |  86 ++++++++
> >  tester/rtems/testing/renode/leon3-prom-gpl.S  | 205 ++++++++++++++++++
> >  .../rtems/testing/renode/leon3-prom-gpl.bin   | Bin 0 -> 529 bytes
> >  tester/rtems/testing/renode/leon3.resc        |  82 +++++++
> >  7 files changed, 512 insertions(+)
> >  create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
> >  create mode 100644 tester/rtems/testing/bsps/leon3-renode.ini
> >  create mode 100644 tester/rtems/testing/renode.cfg
> >  create mode 100644 tester/rtems/testing/renode/kendrytek210.resc
> >  create mode 100644 tester/rtems/testing/renode/leon3-prom-gpl.S
> >  create mode 100755 tester/rtems/testing/renode/leon3-prom-gpl.bin
> >  create mode 100644 tester/rtems/testing/renode/leon3.resc
> > diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini
> b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> > new file mode 100644
> > index 0000000..8f7f673
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> > @@ -0,0 +1,38 @@
> > +# RTEMS Tools Project (http://www.rtems.org/)
> > +# Copyright (C) 2023, 2023 Muhammad Sulthan Mazaya (
> msulthanmazaya at gmail.com)
> > +# All rights reserved.
> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> are met:
> > +# 1. Redistributions of source code must retain the above copyright
> notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> > +# this list of conditions and the following disclaimer in the
> documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > +# The Kendrytek210 Renode BSP
> > +[kendrytek210-renode]
> > +bsp             = kendrytek210-renode
> > +arch            = riscv
> > +tester          = %{_rtscripts}/renode.cfg
> > +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
> This file / directory doesn't exist. I think you mean renode/
> If this works for you, I'm guessing you have a stale directory of
> renode_scripts in your rtems-tools repo locally.
> > diff --git a/tester/rtems/testing/bsps/leon3-renode.ini
> b/tester/rtems/testing/bsps/leon3-renode.ini
> > index 0000000..d5f7c17
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/leon3-renode.ini
> > @@ -0,0 +1,37 @@
> are met:
> > +# # 1. Redistributions of source code must retain the above copyright
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +# The Leon3 Renode BSP
> > +[leon3-renode]
> > +bsp             = leon3-renode
> > +arch            = sparc
> > +bsp_resc_script = %{_rtscripts}/renode_scripts/leon3.resc
> > diff --git a/tester/rtems/testing/renode.cfg
> b/tester/rtems/testing/renode.cfg
> > index 0000000..c7fee25
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode.cfg
> > @@ -0,0 +1,64 @@
> are met:
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +# Renode
> > +# Use a renode command to run the executable in the renode simulator.
> > +%include %{_configdir}/base.cfg
> > +%include %{_configdir}/checks.cfg
> > +# Console.
> > +%define console_telnet
> > +%include %{_configdir}/console.cfg
> > +# RTEMS version
> > +%include %{_rtdir}/rtems/version.cfg
> > +# Renode executable
> > +%define renode_cmd renode --hide-monitor
> > +%define binary_opts -e $bin?=@%{test_executable}
> > +%define start_opts -e "s @%{bsp_resc_script}"
> > +%define add_path -e "path add @%{_rttesting}/renode"
> > +%define trim_command sed 's/.*\[output\] //'
> > +# Executable
> > +%execute %{renode_cmd} %{binary_opts} %{add_path} %{start_opts} |
> %{trim_command}
> > diff --git a/tester/rtems/testing/renode/kendrytek210.resc
> b/tester/rtems/testing/renode/kendrytek210.resc
> > index 0000000..e214aec
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode/kendrytek210.resc
> > @@ -0,0 +1,86 @@
> are met:
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +using sysbus
> > +using monitor
> > +mach create "K210"
> > +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
> > +path add @/
> > +showAnalyzer "uartAnalyzer" uart
> Antmicro.Renode.Analyzers.LoggingUartAnalyzer
> > +uartAnalyzer TimestampFormat None
> > +set report_repeating_line """
> > +from Antmicro.Renode.Logging import ConsoleBackend
> > +ConsoleBackend.Instance.ReportRepeatingLines = True
> > +set add_hook """
> > +def match(line):
> > +    ok_to_kill_lines = [
> > +        '*** TEST STATE: USER_INPUT',
> > +        '*** TEST STATE: BENCHMARK',
> > +        '*** END OF TEST ',
> > +        '*** FATAL ***'
> > +    return any(l in line for l in ok_to_kill_lines)
> > +def hook(line):
> > +    monitor.Parse("q")
> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"],
> match, hook)
> > +python $add_hook
> > +python $report_repeating_line
> > +sysbus Tag <0x50440000 0x10000> "SYSCTL"
> > +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
> > +sysbus Tag <0x5044000C 0x4> "pll1"
> > +sysbus Tag <0x50440008 0x4> "pll0"
> > +sysbus Tag <0x50440020 0x4> "clk_sel0"
> > +sysbus Tag <0x50440028 0x4> "clk_en_cent"
> > +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
> > +# enable uart tx
> > +uart WriteDoubleWord 0x8 0x1
> > +machine StartGdbServer 3333
> > +macro reset
> > +    sysbus LoadELF $bin
> > +# runMacro $reset
> > diff --git a/tester/rtems/testing/renode/leon3-prom-gpl.S
> b/tester/rtems/testing/renode/leon3-prom-gpl.S
> > index 0000000..91dc3bc
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode/leon3-prom-gpl.S
> > @@ -0,0 +1,205 @@
> > + * From
> https://github.com/TUT-ASI/leon3-grlib-gpl-mirror/blob/master/software/leon3/prom.S
> > + * GPL license, version unknown
> > +/* Template boot-code for LEON3 test benches */
> > +#include "prom.h"
> > +#ifndef STACKSIZE
> > +#define STACKSIZE 0x00020000
> > +#endif
> > +       .seg    "text"
> > +       .proc   0
> > +       .align  4
> > +       .global start
> > +start:
> > +       flush
> > +       set 0x10e0, %g1         ! init IU
> > +       mov %g1, %psr
> > +       mov %g0, %wim
> > +       mov %g0, %tbr
> > +       mov %g0, %y
> > +       mov %g0, %asr16
> > +       nop
> > +       set  0x81000f, %g1
> > +       sta %g1, [%g0] 2
> > +       mov %g0, %g2
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +       or %g2, %g2, %g0
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +#ifdef DSUADDR
> > +       set     DSUADDR, %g2
> > +       st      %g0, [%g2]
> > +       st      %g0, [%g2+0x08]
> > +       st      %g0, [%g2+0x20]
> > +       st      %g0, [%g2+0x24]
> > +       st      %g0, [%g2+0x40]
> > +       st      %g0, [%g2+0x44]
> > +       st      %g0, [%g2+0x50]
> > +       st      %g0, [%g2+0x54]
> > +       st      %g0, [%g2+0x58]
> > +       st      %g0, [%g2+0x5C]
> > +#endif
> > +2:
> > +       mov %asr17, %g3
> > +       and %g3, 0x1f, %g3
> > +       mov %g0, %g4
> > +       mov %g0, %g5
> > +       mov %g0, %g6
> > +       mov %g0, %g7
> > +1:
> > +       mov %g0, %l0
> > +       mov %g0, %l1
> > +       mov %g0, %l2
> > +       mov %g0, %l3
> > +       mov %g0, %l4
> > +       mov %g0, %l5
> > +       mov %g0, %l6
> > +       mov %g0, %l7
> > +       mov %g0, %o0
> > +       mov %g0, %o1
> > +       mov %g0, %o2
> > +       mov %g0, %o3
> > +       mov %g0, %o4
> > +       mov %g0, %o5
> > +       mov %g0, %o6
> > +       mov %g0, %o7
> > +       subcc %g3, 1, %g3
> > +       bge 1b
> > +       save
> > +       mov     2, %g1
> > +       mov     %g1, %wim
> > +       set 0x10e0, %g1         ! enable traps
> > +       mov %g1, %psr
> > +       nop; nop; nop;
> > +       mov %psr, %g1
> > +       srl %g1, 12, %g1
> > +       andcc %g1, 1, %g0
> > +       be 1f
> > +       nop
> > +       set _fsrxx, %g3
> > +       ld [%g3], %fsr
> > +       ldd [%g3], %f0
> > +       ldd [%g3], %f2
> > +       ldd [%g3], %f4
> > +       ldd [%g3], %f6
> > +       ldd [%g3], %f8
> > +       ldd [%g3], %f10
> > +       ldd [%g3], %f12
> > +       ldd [%g3], %f14
> > +       ldd [%g3], %f16
> > +       ldd [%g3], %f18
> > +       ldd [%g3], %f20
> > +       ldd [%g3], %f22
> > +       ldd [%g3], %f24
> > +       ldd [%g3], %f26
> > +       ldd [%g3], %f28
> > +       ldd [%g3], %f30
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +       faddd %f0, %f2, %f4
> > +       nop
> > +       nop
> > +       nop
> > +       nop
> > +       ba  1f
> > +       nop
> > +.align 8
> > +_fsrxx:
> > +       .word 0
> > +       .word 0
> > +1:
> > +       mov %asr17, %g3
> > +       srl %g3, 28, %g3
> > +       andcc %g3, 0x0f, %g3
> > +       bne 1f
> > +        nop
> > +#ifdef L2MCTRLIO
> > +       set L2MCTRLIO, %g1
> > +       set MCFG1, %g2
> > +       st  %g2, [%g1]
> > +       set MCFG2, %g2
> > +       st  %g2, [%g1+4]
> > +       set MCFG3, %g2
> > +       st  %g2, [%g1+8]
> > +#endif
> > +!      set IRQCTRL, %g1
> > +!      set 0x0ffff, %g2
> > +!      st  %g2, [%g1+0x10]
> > +#ifdef UARTADDR
> > +        set UARTADDR, %g1
> > +        st  %g0, [%g1+0xC]
> > +        set 3, %g2
> > +        st %g2,  [%g1+0x8]
> > +#endif
> > +#ifdef DDR2CTRLIO
> > +       set DDR2CTRLIO, %g1
> > +       set DDR2CFG4, %g2
> > +       st  %g2, [%g1+12]
> > +#endif
> > +#ifdef ASDCFG
> > +#ifndef SDCTRLPNP
> > +#define SDCTRLPNP 0xFFFFF860
> > +#endif
> > +       set SDCTRLPNP, %g1
> > +       ld  [%g1], %g2
> > +       srl %g2, 12, %g2
> > +       set 0x01009, %g1
> > +       subcc %g1, %g2, %g0
> > +       bne 1f
> > +       set ASDCFG, %g1
> > +       set DSDCFG, %g2
> > +       st  %g2, [%g1]
> > +#endif
> > +       ! %g3 = cpu index
> > +1:     set STACKSIZE, %g2
> > +        mov %g0, %g1
> > +2:     subcc %g3, 0, %g0
> > +       be 3f
> > +       nop
> > +       add %g1, %g2, %g1
> > +       ba 2b
> > +       sub %g3, 1, %g3
> > +3:     set RAMSTART+ RAMSIZE-32, %fp
> > +       sub %fp, %g1, %fp
> > +       sub %fp, 96, %sp
> > +       set RAMSTART, %g1
> > +       jmp %g1
> > +       nop
> > +.align 32
> > diff --git a/tester/rtems/testing/renode/leon3-prom-gpl.bin
> b/tester/rtems/testing/renode/leon3-prom-gpl.bin
> > new file mode 100755
> > index
> 0000000000000000000000000000000000000000..a42628906b6915c589f6be96fe5de82a940c6529
> > GIT binary patch
> > literal 529
> > zcmYk&F-yZh6bJBsQma+O9uC$)FhikhM;GxB2R}yq7LJ!#(<mZEM2ZwSt%!*D2?}kc
> > z4h|h01RaFy;NT$Q;2>1uKedqte%#A at 3Gco0o*blrF<-dG3t at Q`z^jr1PRRmTcO>iC
> > zTMbzff4Mk6N(p6;z9(^cO(Mvc#gPB)(jM)TrZYOH3%aB$x~3bd&;cFN5mo7!YIH(@
> > zHr8A-`tS_k3&-Z%*61Ed|M=Wmr=mNpLf5ht@^Nm00 at 2%SXIf~_w{S=I)TIY{q-T1e
> > z9=*~Vz0)Us(Kr3jXs;yR(V5jGPEMhaPGYtnJn{XMi)JARO?FmcCa(Kp$?ZU5yQrs!
> > zJ54GrZPv$AD}B~Ckj{rrNz}U?M<NX<pLe3P0rwm9 at F8u{jQW9NtmRx3HF9;+C at 8B|
> > S&~A#~dM!DadpO4bG4%^DAaPm%
> > literal 0
> > HcmV?d00001
> > diff --git a/tester/rtems/testing/renode/leon3.resc
> b/tester/rtems/testing/renode/leon3.resc
> > index 0000000..3196775
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode/leon3.resc
> > @@ -0,0 +1,82 @@
> are met:
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +using sysbus
> > +using monitor
> > +mach create "leon3"
> > +machine LoadPlatformDescription @platforms/boards/leon3.repl
> > +path add @/
> > +set add_hook """
> > +def my_match(line):
> > +        '*** FATAL ***'
> > +def my_hook(line):
> > +    print line
> my_match, my_hook)
> > +python $add_hook
> > +macro reset
> > +    # The leon3-prom-gpl.bin is built using Antmicro's script from their
> > +    # example of how to use renode to test rtems leon3 using renode-test
> https://github.com/antmicro/renode-rtems-leon3/blob/main/build-prom.sh
> > +    # The source of the assembly file itself is from Gaisler
> > +    sysbus LoadBinary @leon3-prom-gpl.bin 0x0
> > +    cpu PC 0
> > +runMacro $reset
> > 2.34.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230819/c02a9334/attachment-0001.htm>
