bsps/xilinx-zynqmp : Add BSP for RPU
Philip Kirkpatrick p.kirkpatrick at reflexaerospace.com
Tue Aug 22 11:27:10 UTC 2023
Just a reminder that this patch is ready for review.
On Thu, Jun 29, 2023 at 6:36 PM Philip Kirkpatrick <
p.kirkpatrick at reflexaerospace.com> wrote:
> Took a while to get to but here is a new patch incorporating the feedback.
> Sorry to drop this and run but I'm on vacation for a week as soon as I
> send this.  So don't expect to see responses from me until July 10th or
> later.
> Once I'm back and this is through, expect to see some follow-on patches
> for enabling MPU, cache, and lwip support.  I have that working and tested
> but it needs some cleanup before I'll feel good about a patch.
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> new file mode 100644
> index 0000000000..469178fd86
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> @@ -0,0 +1,128 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2013, 2017 embedded brains GmbH
> + * Copyright (C) 2019 DornerWorks
> + * Written by Jeff Kubascik <jeff.kubascik at dornerworks.com>
> + *        and Josh Whitehead <josh.whitehead at dornerworks.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems/console.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/sysinit.h>
> +#include <bsp/irq.h>
> +#include <dev/serial/zynq-uart.h>
> +#include <bspopts.h>
> +static zynq_uart_context zynqmp_uart_instances[2] = {
> +    .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
> +    .regs = (volatile struct zynq_uart *) 0xff000000,
> +    .irq = ZYNQMP_IRQ_UART_0
> +    .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
> +    .regs = (volatile struct zynq_uart *) 0xff010000,
> +    .irq = ZYNQMP_IRQ_UART_1
> +rtems_status_code console_initialize(
> +  rtems_device_major_number major,
> +  rtems_device_minor_number minor,
> +  void *arg
> +  size_t i;
> +  for (i = 0; i < RTEMS_ARRAY_SIZE(zynqmp_uart_instances); ++i) {
> +    char uart[] = "/dev/ttySX";
> +    uart[sizeof(uart) - 2] = (char) ('0' + i);
> +    rtems_termios_device_install(
> +      &uart[0],
> +      &zynq_uart_handler,
> +      NULL,
> +      &zynqmp_uart_instances[i].base
> +    if (i == BSP_CONSOLE_MINOR) {
> +      link(&uart[0], CONSOLE_DEVICE_NAME);
> +  return RTEMS_SUCCESSFUL;
> +void zynqmp_debug_console_flush(void)
> +  zynq_uart_reset_tx_flush(&zynqmp_uart_instances[BSP_CONSOLE_MINOR]);
> +static void zynqmp_debug_console_out(char c)
> +  rtems_termios_device_context *base =
> +    &zynqmp_uart_instances[BSP_CONSOLE_MINOR].base;
> +  zynq_uart_write_polled(base, c);
> +static void zynqmp_debug_console_init(void)
> +  zynq_uart_initialize(base);
> +  BSP_output_char = zynqmp_debug_console_out;
> +static void zynqmp_debug_console_early_init(char c)
> +  zynqmp_debug_console_out(c);
> +static int zynqmp_debug_console_in(void)
> +  return zynq_uart_read_polled(base);
> +BSP_output_char_function_type BSP_output_char =
> zynqmp_debug_console_early_init;
> +BSP_polling_getchar_function_type BSP_poll_char = zynqmp_debug_console_in;
> +RTEMS_SYSINIT_ITEM(
> +  zynqmp_debug_console_init,
> +  RTEMS_SYSINIT_BSP_START,
> +  RTEMS_SYSINIT_ORDER_LAST_BUT_5
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> index 0000000000..9b71487999
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> @@ -0,0 +1,93 @@
> + * @file
> + * @ingroup RTEMSBSPsARMZynqMP
> + * @brief Global BSP definitions.
> + * Copyright (C) 2013, 2014 embedded brains GmbH
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef LIBBSP_ARM_XILINX_ZYNQMP_BSP_H
> +#define LIBBSP_ARM_XILINX_ZYNQMP_BSP_H
> + * @defgroup RTEMSBSPsARMZynqMP Xilinx Zynq UltraScale+ MPSoC
> + * @brief Xilinx Zynq UltraScale+ MPSoC Board Support Package.
> +#define BSP_FEATURE_IRQ_EXTENSION
> +#ifndef ASM
> +#include <rtems.h>
> +#include <bsp/default-initial-extension.h>
> +#include <bsp/start.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +#define BSP_ARM_GIC_CPUIF_BASE 0x00F9001000
> +#define BSP_ARM_GIC_DIST_BASE 0xF9000000
> +#define BSP_ARM_A9MPCORE_SCU_BASE 0
> +#define BSP_ARM_A9MPCORE_GT_BASE 0
> + * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
> + * Provide in the application to override the defaults in the BSP.
> +BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
> +void zynqmp_debug_console_flush(void);
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* LIBBSP_ARM_XILINX_ZYNQMP_BSP_H */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> b/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> index 0000000000..681ccfb48c
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> @@ -0,0 +1,81 @@
> + * @file
> + * @ingroup zynqmp_interrupt
> + * @brief Interrupt definitions.
> + * Copyright (C) 2013 embedded brains GmbH
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H
> +#define LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H
> +#ifndef ASM
> +#include <rtems/irq.h>
> +#include <rtems/irq-extension.h>
> +#include <dev/irq/arm-gic-irq.h>
> +#ifdef __cplusplus
> +extern "C" {
> +/* SPIs */
> +#define ZYNQMP_IRQ_UART_0 53
> +#define ZYNQMP_IRQ_UART_1 54
> +#define ZYNQMP_IRQ_TTC_0_0 68
> +#define ZYNQMP_IRQ_TTC_0_1 69
> +#define ZYNQMP_IRQ_TTC_0_2 70
> +#define ZYNQMP_IRQ_TTC_1_0 71
> +#define ZYNQMP_IRQ_TTC_1_1 72
> +#define ZYNQMP_IRQ_TTC_1_2 73
> +#define ZYNQMP_IRQ_TTC_2_0 74
> +#define ZYNQMP_IRQ_TTC_2_1 75
> +#define ZYNQMP_IRQ_TTC_2_2 76
> +#define ZYNQMP_IRQ_TTC_3_0 77
> +#define ZYNQMP_IRQ_TTC_3_1 78
> +#define ZYNQMP_IRQ_TTC_3_2 79
> +#define BSP_INTERRUPT_VECTOR_COUNT 188
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/tm27.h
> b/bsps/arm/xilinx-zynqmp-rpu/include/tm27.h
> index 0000000000..14214fe151
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/tm27.h
> @@ -0,0 +1,54 @@
> + * @file
> + * @ingroup zynqmp_tm27
> + * @brief Interrupt mechanisms for tm27 test.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _RTEMS_TMTEST27
> +#error "This is an RTEMS internal file you must not include directly."
> +#endif
> +#ifndef __tm27_h
> +#define __tm27_h
> + * @defgroup zynqmp_tm27 TM27 Test Support
> + * @brief Interrupt Mechanisms for tm27 test
> +#include <dev/irq/arm-gic-tm27.h>
> +#endif /* __tm27_h */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> index 0000000000..14f7d32436
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> @@ -0,0 +1,42 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <bsp.h>
> +void bsp_reset(void)
> +  zynqmp_debug_console_flush();
> +  while (true) {
> +    /* Wait */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> b/bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> index 0000000000..a3cc498d7e
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> @@ -0,0 +1,50 @@
> + * Copyright (C) 2013, 2015 embedded brains GmbH
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <bsp.h>
> +#include <bsp/bootcard.h>
> +#include <bsp/irq-generic.h>
> +#include <bsp/linker-symbols.h>
> +#include <libcpu/arm-cp15.h>
> +void bsp_start(void)
> +  bsp_interrupt_initialize();
> +  // TODO: enable cache
> +#if 0
> +  rtems_cache_coherent_add_area(
> +    bsp_section_nocacheheap_begin,
> +    (uintptr_t) bsp_section_nocacheheap_size
> +#endif
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> b/bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> index 0000000000..c0d35d31b7
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> @@ -0,0 +1,66 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <bsp.h>
> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> +     * On reset, V will be set.  This points the exceptions to the FSBL's
> vectors.  The FSBL
> +     * should clear this bit before booting RTEMS but in some debugging
> +     * configurations the bit may not be.  The other bits should already
> be clear
> +     * on reset.  Since the correct settings in these bits are critical,
> +     * make sure SCTLR[M, I, A, C, V] are cleared.  Afterwards,
> exceptions are
> +     * handled by RTEMS.
> +     * Note 1: The APU also does these steps in start.S in _start in the
> #if block:
> +     *         `#if (__ARM_ARCH >= 7 && __ARM_ARCH_PROFILE == 'A') ||
> __ARM_ARCH >= 8`
> +     * Note 2: Not all Arm R cores need this (like the TMS570).  So, this
> probably should
> +     *         be in this hook and not in start.S
> +     * Ref:
> https://developer.arm.com/documentation/ddi0460/c/System-Control/Register-descriptions/c1--System-Control-Register?lang=en
> +    __asm__ volatile(
> +      "mrc p15, 0, r0, c1, c0, 0 \n"
> +      "bic r1, r0, #0x3000 \n"     // Clear V[13] and I[12]
> +      "bic r1, r1, #0x7 \n"        // Clear C[2] A[1] and M[0]
> +      "mcr p15, 0, r1, c1, c0, 0 \n"
> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
> +  bsp_start_copy_sections();
> +  // TODO: Setup/enable cache HERE
> +  bsp_start_clear_bss();
> diff --git a/bsps/include/xil/xttcps_hw.h b/bsps/include/xil/xttcps_hw.h
> index 0000000000..0872e66c8f
> --- /dev/null
> +++ b/bsps/include/xil/xttcps_hw.h
> @@ -0,0 +1,223 @@
> +* Copyright (C) 2010 - 2021 Xilinx, Inc.  All rights reserved.
> +* SPDX-License-Identifier: MIT
> +* @file xttcps_hw.h
> +* @addtogroup ttcps_v3_14
> +* This file defines the hardware interface to one of the three timer
> counters
> +* in the Ps block.
> +* <pre>
> +* MODIFICATION HISTORY:
> +* Ver   Who    Date     Changes
> +* 1.00a drg/jz 01/21/10 First release
> +* 3.00  kvn    02/13/15 Modified code for MISRA-C:2012 compliance.
> +* 3.5   srm    10/06/17 Updated XTTCPS_COUNT_VALUE_MASK,
> +*                       XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK
> macros to
> +*                       mask 16 bit values for zynq and 32 bit values for
> +*                       zynq ultrascale+mpsoc "
> +* </pre>
> +#ifndef XTTCPS_HW_H /* prevent circular inclusions */
> +#define XTTCPS_HW_H /* by using protection macros */
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/***************************** Include Files
> +#ifndef __rtems__
> +#include "xil_types.h"
> +#include "xil_assert.h"
> +#include "xil_io.h"
> +#else
> +static inline u32 Xil_In32(UINTPTR Addr)
> + return *(volatile u32 *) Addr;
> +static inline void Xil_Out32(UINTPTR Addr, u32 Value)
> + volatile u32 *LocalAddr = (volatile u32 *)Addr;
> + *LocalAddr = Value;
> +#endif /* __rtems__ */
> +/************************** Constant Definitions
> + * Flag for a9 processor
> +#ifndef __rtems__
> + #if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
> + #define ARMA9
> + #endif
> +#endif
> +/** @name Register Map
> + * Register offsets from the base address of the device.
> +#define XTTCPS_CLK_CNTRL_OFFSET 0x00000000U  /**< Clock Control Register
> +#define XTTCPS_CNT_CNTRL_OFFSET 0x0000000CU  /**< Counter Control
> Register*/
> +#define XTTCPS_COUNT_VALUE_OFFSET 0x00000018U  /**< Current Counter Value
> +#define XTTCPS_INTERVAL_VAL_OFFSET 0x00000024U  /**< Interval Count Value
> +#define XTTCPS_MATCH_0_OFFSET 0x00000030U  /**< Match 1 value */
> +#define XTTCPS_MATCH_1_OFFSET 0x0000003CU  /**< Match 2 value */
> +#define XTTCPS_MATCH_2_OFFSET 0x00000048U  /**< Match 3 value */
> +#define XTTCPS_ISR_OFFSET 0x00000054U  /**< Interrupt Status Register */
> +#define XTTCPS_IER_OFFSET 0x00000060U  /**< Interrupt Enable Register */
> +/** @name Clock Control Register
> + * Clock Control Register definitions
> +#define XTTCPS_CLK_CNTRL_PS_EN_MASK 0x00000001U  /**< Prescale enable */
> +#define XTTCPS_CLK_CNTRL_PS_VAL_MASK 0x0000001EU  /**< Prescale value */
> +#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT 1U  /**< Prescale shift */
> +#define XTTCPS_CLK_CNTRL_PS_DISABLE 16U  /**< Prescale disable */
> +#define XTTCPS_CLK_CNTRL_SRC_MASK 0x00000020U  /**< Clock source */
> +#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK 0x00000040U  /**< External Clock
> edge */
> +/** @name Counter Control Register
> + * Counter Control Register definitions
> +#define XTTCPS_CNT_CNTRL_DIS_MASK 0x00000001U /**< Disable the counter */
> +#define XTTCPS_CNT_CNTRL_INT_MASK 0x00000002U /**< Interval mode */
> +#define XTTCPS_CNT_CNTRL_DECR_MASK 0x00000004U /**< Decrement mode */
> +#define XTTCPS_CNT_CNTRL_MATCH_MASK 0x00000008U /**< Match mode */
> +#define XTTCPS_CNT_CNTRL_RST_MASK 0x00000010U /**< Reset counter */
> +#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK 0x00000020U /**< Enable waveform */
> +#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK 0x00000040U /**< Waveform polarity
> +#define XTTCPS_CNT_CNTRL_RESET_VALUE 0x00000021U /**< Reset value */
> +/** @name Current Counter Value Register
> + * Current Counter Value Register definitions
> +#if defined(ARMA9)
> +#define XTTCPS_COUNT_VALUE_MASK 0x0000FFFFU /**< 16-bit counter value */
> +#else
> +#define XTTCPS_COUNT_VALUE_MASK 0xFFFFFFFFU /**< 32-bit counter value */
> +#endif
> +/** @name Interval Value Register
> + * Interval Value Register is the maximum value the counter will count up
> or
> + * down to.
> +#if defined(ARMA9)
> +#define XTTCPS_INTERVAL_VAL_MASK (u32)(0x0000FFFF) /**< 16-bit Interval
> value*/
> +#else
> +#define XTTCPS_INTERVAL_VAL_MASK (u32)(0xFFFFFFFF) /**< 32-bit Interval
> value*/
> +#endif
> +/** @name Match Registers
> + * Definitions for Match registers, each timer counter has three match
> + * registers.
> +#if defined(ARMA9)
> +#define XTTCPS_MATCH_MASK 0x0000FFFFU /**< 16-bit Match value */
> +#else
> +#define XTTCPS_MATCH_MASK 0xFFFFFFFFU /**< 32-bit Match value */
> +#endif
> +#define XTTCPS_NUM_MATCH_REG 3U /**< Num of Match reg */
> +/** @name Interrupt Registers
> + * Following register bit mask is for all interrupt registers.
> +#define XTTCPS_IXR_INTERVAL_MASK 0x00000001U  /**< Interval Interrupt */
> +#define XTTCPS_IXR_MATCH_0_MASK 0x00000002U  /**< Match 1 Interrupt */
> +#define XTTCPS_IXR_MATCH_1_MASK 0x00000004U  /**< Match 2 Interrupt */
> +#define XTTCPS_IXR_MATCH_2_MASK 0x00000008U  /**< Match 3 Interrupt */
> +#define XTTCPS_IXR_CNT_OVR_MASK 0x00000010U  /**< Counter Overflow */
> +#define XTTCPS_IXR_ALL_MASK 0x0000001FU  /**< All valid Interrupts */
> +/***************** Macros (Inline Functions) Definitions
> +* Read the given Timer Counter register.
> +* @param BaseAddress is the base address of the timer counter device.
> +* @param RegOffset is the register offset to be read
> +* @return The 32-bit value of the register
> +* @note C-style signature:
> +* u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
> +#define XTtcPs_ReadReg(BaseAddress, RegOffset) \
> +    (Xil_In32((BaseAddress) + (u32)(RegOffset)))
> +* Write the given Timer Counter register.
> +* @param RegOffset is the register offset to be written
> +* @param Data is the 32-bit value to write to the register
> +* @return None.
> +* void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
> +* u32 Data)
> +#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data) \
> +    (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
> +* Calculate a match register offset using the Match Register index.
> +* @param MatchIndex is the 0-2 value of the match register
> +* @return MATCH_N_OFFSET.
> +* u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
> +#define XTtcPs_Match_N_Offset(MatchIndex) \
> + ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
> +/************************** Function Prototypes
> +/************************** Variable Definitions
> +#ifdef __cplusplus
> +#endif
> +#endif /* end of protection macro */
> diff --git a/bsps/include/xil/zynqmp.h b/bsps/include/xil/zynqmp.h
> index 0000000000..34051c525a
> --- /dev/null
> +++ b/bsps/include/xil/zynqmp.h
> @@ -0,0 +1,99 @@
> + * @file
> + * @brief Peripheral memory map.
> + * Copyright (C) 2023 Reflex Aerospace GmbH
> + * Written by Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com>
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef LIBBSP_ARM_ZYNQMP
> +#define LIBBSP_ARM_ZYNQMP
> +/* Data derived from
> https://docs.xilinx.com/r/en-US/ug1085-zynq-ultrascale-trm/PS-I/O-Peripherals-Registers
> +/* LPD IO Peripherals */
> +#define ZYNQMP_UART0 (0xFF000000)
> +#define ZYNQMP_UART1 (0xFF010000)
> +#define ZYNQMP_I2C0 (0xFF020000)
> +#define ZYNQMP_I2C1 (0xFF030000)
> +#define ZYNQMP_SPI0 (0xFF040000)
> +#define ZYNQMP_SPI1 (0xFF050000)
> +#define ZYNQMP_CAN0 (0xFF060000)
> +#define ZYNQMP_CAN1 (0xFF070000)
> +#define ZYNQMP_GPIO (0xFF0A0000)
> +#define ZYNQMP_GEM0 (0xFF0B0000)
> +#define ZYNQMP_GEM1 (0xFF0C0000)
> +#define ZYNQMP_GEM2 (0xFF0D0000)
> +#define ZYNQMP_GEM3 (0xFF0E0000)
> +#define ZYNQMP_QSPI (0xFF0F0000)
> +#define ZYNQMP_NAND (0xFF100000)
> +#define ZYNQMP_SD0 (0xFF160000)
> +#define ZYNQMP_SD1 (0xFF170000)
> +#define ZYNQMP_IPI_MSG (0xFF990000)
> +#define ZYNQMP_USB0 (0xFF9D0000)
> +#define ZYNQMP_USB1 (0xFF9E0000)
> +#define ZYNQMP_AMS (0xFFA50000)
> +#define ZYNQMP_PSSYSMON (0xFFA50800)
> +#define ZYNQMP_PLSYSMON (0xFFA50C00)
> +#define ZYNQMP_CSU_SWDT (0xFFCB0000)
> +/* FPD IO Peripherals */
> +#define ZYNQMP_SATA (0xFD0C0000)
> +#define ZYNQMP_PCIE (0xFD0E0000)
> +#define ZYNQMP_PCIE_IN (0xFD0E0800)
> +#define ZYNQMP_PCIE_EG (0xFD0E0C00)
> +#define ZYNQMP_PCIE_DMA (0xFD0F0000)
> +#define ZYNQMP_SIOU (0xFD3D0000)
> +#define ZYNQMP_GTR (0xFD400000)
> +#define ZYNQMP_PCIE_ATTR (0xFD480000)
> +#define ZYNQMP_DP (0xFD4A0000)
> +#define ZYNQMP_GPU (0xFD4B0000)
> +#define ZYNQMP_DP_DMA (0xFD4C0000)
> +/* LPD System Registers */
> +#define ZYNQMP_IPI (0xFF300000)
> +#define ZYNQMP_TTC0 (0xFF110000)
> +#define ZYNQMP_TTC1 (0xFF120000)
> +#define ZYNQMP_TTC2 (0xFF130000)
> +#define ZYNQMP_TTC3 (0xFF140000)
> +#define ZYNQMP_LPD_SWDT (0xFF150000)
> +#define ZYNQMP_XPPU (0xFF980000)
> +#define ZYNQMP_XPPU_SINK (0xFF9C0000)
> +#define ZYNQMP_PL_LPD (0xFF9B0000)
> +#define ZYNQMP_OCM (0xFFA00000)
> +#define ZYNQMP_LPD_FPD (0xFFA10000)
> +#define ZYNQMP_RTC (0xFFA60000)
> +#define ZYNQMP_OCM_XMPU (0xFFA70000)
> +#define ZYNQMP_LPD_DMA (0xFFA80000)
> +#define ZYNQMP_CSU_DMA (0xFFC80000)
> +#define ZYNQMP_CSU (0xFFCA0000)
> +#define ZYNQMP_BBRAM (0xFFCD0000)
> +#endif /* LIBBSP_ARM_ZYNQMP */
> diff --git a/bsps/shared/dev/clock/xil-ttc.c
> b/bsps/shared/dev/clock/xil-ttc.c
> index 0000000000..c6aaaa9f91
> --- /dev/null
> +++ b/bsps/shared/dev/clock/xil-ttc.c
> @@ -0,0 +1,214 @@
> + * @file
> + * @brief Triple Timer Counter clock functions definitions.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <stdlib.h>
> +#include <rtems.h>
> +#include <bsp.h>
> +#include <zynqmp.h>
> +#include <xttcps_hw.h>
> +#include <rtems/timecounter.h>
> +static struct timecounter zynqmp_ttc_tc;
> +#define TTC_REFERENCE_CLOCK 100000000
> +/* This is defined in dev/clock/clockimpl.h */
> +void Clock_isr(rtems_irq_hdl_param arg);
> +static uint32_t irq_match_interval;
> +static uint32_t zynqmp_ttc_get_timecount(struct timecounter *tc)
> +  uint32_t time;
> +  time = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
> +  return time;
> + *  @brief Initialize the HW peripheral for clock driver
> + *  Clock driver is implemented by RTI module
> + * @retval Void
> +static void zynqmp_ttc_clock_driver_support_initialize_hardware(void)
> +  uint32_t microsec_per_tick;
> +  uint16_t clock_ratio;
> +  uint8_t  index;
> +  uint32_t frequency;
> +  uint32_t prescaler;
> +  uint32_t tmp_reg_val;
> +  microsec_per_tick = rtems_configuration_get_microseconds_per_tick();
> +  /* Check the TTC is OFF before reconfiguring */
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CNT_CNTRL_OFFSET,
> XTTCPS_CNT_CNTRL_DIS_MASK |
> +        XTTCPS_CNT_CNTRL_EN_WAVE_MASK);  // Don't enable waveform output
> (active low)
> +  /* Prescaler value is 2^(N + 1)
> +   * Divide down the clock as much as possible while still retaining a
> +   * frequency that is an integer multiple of 1MHz.  This maximizes time
> to
> +   * overflow while minimizing rounding errors in 1us periods
> +  clock_ratio = TTC_REFERENCE_CLOCK / 1000000;
> +  /* Search for the highest set bit.  This is effectively
> min(log2(ratio))*/
> +  for(index = sizeof(clock_ratio) * 8 - 1; index > 0; index--) {
> +    if((clock_ratio >> (index)) & 0x01) {
> +        break;
> +  if(index == 0 && (clock_ratio & 0x01 == 0)) {
> +    // No prescaler
> +    frequency = TTC_REFERENCE_CLOCK;
> +    XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CLK_CNTRL_OFFSET, 0);
> +  } else {
> +    prescaler = index - 1;
> +    frequency = TTC_REFERENCE_CLOCK / (1 << (prescaler + 1));
> +        prescaler << XTTCPS_CLK_CNTRL_PS_VAL_SHIFT |
> +        XTTCPS_CLK_CNTRL_PS_EN_MASK);
> +  /* Max out the counter interval */
> +  tmp_reg_val = XTTCPS_INTERVAL_VAL_MASK;
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_INTERVAL_VAL_OFFSET, tmp_reg_val);
> +  /* Setup match register to generate tick IRQ */
> +  irq_match_interval = (uint32_t) ((frequency * microsec_per_tick) /
> 1000000);
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, irq_match_interval);
> +  /* Clear interupts (clear on read) */
> +  XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
> +  /* Enable interupt for match register */
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_IER_OFFSET,
> XTTCPS_IXR_MATCH_0_MASK);
> +  /* Configure, reset, and enable counter */
> +        XTTCPS_CNT_CNTRL_EN_WAVE_MASK |  /* Don't enable waveform output
> (active low) */
> +        XTTCPS_CNT_CNTRL_RST_MASK |      /* Reset count and start counter
> +        XTTCPS_CNT_CNTRL_MATCH_MASK      /* Enable match mode */
> +        /* Increment mode */
> +        /* Overflow mode */
> +        /* Not disabled */
> +  /* set timecounter */
> +  zynqmp_ttc_tc.tc_get_timecount = zynqmp_ttc_get_timecount;
> +  zynqmp_ttc_tc.tc_counter_mask = XTTCPS_COUNT_VALUE_MASK;
> +  zynqmp_ttc_tc.tc_frequency = frequency;
> +  zynqmp_ttc_tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
> +  rtems_timecounter_install(&zynqmp_ttc_tc);
> + * @brief Clears interrupt source
> + * @retval Void
> +static uint32_t tick_miss = 0;
> +static void zynqmp_ttc_clock_driver_support_at_tick( void )
> +  uint32_t irq_flags;
> +  uint32_t cval;
> +  uint32_t now;
> +  uint32_t delta;
> +  /* Get and clear interupts (clear on read) */
> +  irq_flags = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
> +  if(irq_flags & XTTCPS_IXR_MATCH_0_MASK) {
> +    /* Update match */
> +    cval = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET);
> +    /* Check that the match for the next tick is in the future
> +     * If no, then set the match for one irq interval from now
> +     *   This will have the effect that your timebase will slip but
> +     *   won't hang waiting for the counter to wrap around.
> +     * If this happens durring normal opteration, there is a problem
> +     *   causing this interrupt to not be serviced quickly enough
> +     * If this happens during debugging, that is normal and expected
> +     *   becaue the TTC does NOT pause when the CPU is halted on a
> breakpoint
> +    now = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
> +    delta = now - cval;
> +    if(delta > irq_match_interval) {
> +     cval = now;
> +     tick_miss++;
> +    cval += irq_match_interval;
> +    XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, cval);
> +  /* Else, something is set up wrong, only match should be enabled */
> + * @brief registers RTI interrupt handler
> + * @param[in] Clock_isr new ISR handler
> + * @param[in] Old_ticker old ISR handler (unused and type broken)
> + * @retval Void
> +static void zynqmp_ttc_clock_driver_support_install_isr(
> +  rtems_isr_entry Clock_isr
> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
> +  sc = rtems_interrupt_handler_install(
> +    ZYNQMP_IRQ_TTC_0_0,
> +    "Clock",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    (rtems_interrupt_handler) Clock_isr,
> +    NULL
> +  if ( sc != RTEMS_SUCCESSFUL ) {
> +    rtems_fatal_error_occurred(0xdeadbeef);
> +#define Clock_driver_support_at_tick \
> +                        zynqmp_ttc_clock_driver_support_at_tick
> +#define Clock_driver_support_initialize_hardware \
> +#define Clock_driver_support_install_isr(Clock_isr) \
> +              zynqmp_ttc_clock_driver_support_install_isr( Clock_isr )
> +#include "../../../shared/dev/clock/clockimpl.h"
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> index 0000000000..829e9c9297
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-string: null
> +- split: null
> +- env-append: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2023 Reflex Aerospace GmbH (
> https://www.reflexaerospace.com/)
> +default:
> +- enabled-by: true
> +  value:
> +  - -march=armv7-r
> +  - -mthumb
> +  - -mfpu=vfpv3-d16
> +  - -mfloat-abi=hard
> +description: |
> +  ABI flags
> +enabled-by: true
> +links: []
> +name: ABI_FLAGS
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
> index 0000000000..ec2d6ed158
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
> @@ -0,0 +1,92 @@
> +arch: arm
> +bsp: xilinx_zynqmp_mercuryxu5_rpu
> +build-type: bsp
> +cflags: []
> +copyrights:
> +cppflags: []
> +enabled-by: true
> +family: xilinx-zynqmp-rpu
> +includes:
> +- bsps/include/xil/
> +install:
> +- destination: ${BSP_INCLUDEDIR}
> +  source:
> +  - bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> +  - bsps/include/xil/xil_types.h
> +  - bsps/include/xil/xil_assert.h
> +  - bsps/include/xil/xil_io.h
> +  - bsps/include/xil/xttcps_hw.h
> +  - bsps/include/xil/zynqmp.h
> +- destination: ${BSP_INCLUDEDIR}/bsp
> +  source:
> +  - bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> +links:
> +- role: build-dependency
> +  uid: ../grp
> +  uid: ../start
> +  uid: abi
> +  uid: optclkfastidle
> +  uid: optclkuart
> +  uid: optconirq
> +  uid: ../../optconminor
> +  uid: optint0len
> +  uid: optint0ori
> +  uid: optint1len
> +  uid: optint1ori
> +  uid: optramlen
> +  uid: optramori
> +  uid: optresetvec
> +  uid: ../../obj
> +  uid: ../../objirq
> +  uid: ../../objdevserialzynq
> +  uid: ../../objdevspizynq
> +  uid: ../../objdevspixil
> +  uid: ../../objmem
> +  uid: ../../opto0
> +  uid: linkcmds
> +  uid: ../../bspopts
> +source:
> +- bsps/shared/cache/nocache.c
> +- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
> +- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> +- bsps/arm/shared/start/bsp-start-memcpy.S
> +- bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> +- bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> +- bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> +- bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> +- bsps/shared/dev/clock/xil-ttc.c
> +- bsps/shared/dev/btimer/btimer-cpucounter.c
> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
> +- bsps/shared/dev/irq/arm-gicv2.c
> +- bsps/shared/dev/irq/arm-gicv2-zynqmp.c
> +- bsps/shared/dev/serial/console-termios.c
> +- bsps/shared/irq/irq-default-handler.c
> +- bsps/shared/start/bspfatal-default.c
> +- bsps/shared/start/gettargethash-default.c
> +- bsps/shared/start/sbrk.c
> +- bsps/shared/start/stackalloc.c
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> index 0000000000..f5e6ff7822
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> @@ -0,0 +1,41 @@
> +build-type: config-file
> +content: |
> +  MEMORY {
> +    RAM_INT_0 : ORIGIN = ${ZYNQMP_RPU_RAM_INT_0_ORIGIN:#010x}, LENGTH =
> ${ZYNQMP_RPU_RAM_INT_0_LENGTH:#010x}
> +    RAM_INT_1 : ORIGIN = ${ZYNQMP_RPU_RAM_INT_1_ORIGIN:#010x}, LENGTH =
> ${ZYNQMP_RPU_RAM_INT_1_LENGTH:#010x}
> +    RAM       : ORIGIN = ${ZYNQMP_RPU_RAM_ORIGIN:#010x}, LENGTH =
> ${ZYNQMP_RPU_RAM_LENGTH:#010x} - ${ZYNQMP_RPU_RAM_ORIGIN:#010x}
> +  REGION_ALIAS ("REGION_START",          RAM_INT_0);
> +  REGION_ALIAS ("REGION_VECTOR",         RAM_INT_0);
> +  REGION_ALIAS ("REGION_TEXT",           RAM);
> +  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
> +  REGION_ALIAS ("REGION_RODATA",         RAM);
> +  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
> +  REGION_ALIAS ("REGION_DATA",           RAM);
> +  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
> +  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
> +  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
> +  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
> +  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
> +  REGION_ALIAS ("REGION_BSS",            RAM);
> +  REGION_ALIAS ("REGION_WORK",           RAM);
> +  REGION_ALIAS ("REGION_STACK",          RAM);
> +  REGION_ALIAS ("REGION_NOCACHE",        RAM);
> +  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
> +  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size
> : 1024;
> +  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
> bsp_section_rwbarrier_align : 1M;
> +  bsp_vector_table_in_start_section = 1;
> +  INCLUDE linkcmds.armv4
> +copyrights:
> +enabled-by: true
> +install-path: ${BSP_LIBDIR}
> +links: []
> +target: linkcmds
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
> index 0000000000..e303a8bf9f
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
> @@ -0,0 +1,21 @@
> +actions:
> +- get-boolean: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +default:
> +- enabled-by:
> +  - arm/lm3s6965_qemu
> +  - arm/realview_pbx_a9_qemu
> +  - arm/xilinx_zynq_a9_qemu
> +  value: true
> +- enabled-by: true
> +  value: false
> +description: |
> +  This sets a mode where the time runs as fast as possible when a clock
> ISR occurs while the IDLE thread is executing.  This can significantly
> reduce simulation times.
> +enabled-by: true
> +links: []
> +name: CLOCK_DRIVER_USE_FAST_IDLE
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
> index 0000000000..77c8f30fff
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
> @@ -0,0 +1,17 @@
> +actions:
> +- get-integer: null
> +- define: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 100000000
> +description: |
> +  Zynq UART clock frequency in Hz
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: ZYNQ_CLOCK_UART
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
> index 0000000000..ea13fa4561
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
> @@ -0,0 +1,16 @@
> +actions:
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: true
> +description: |
> +  use interrupt driven mode for console devices (used by default)
> +enabled-by: true
> +links: []
> +name: ZYNQ_CONSOLE_USE_INTERRUPTS
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
> index 0000000000..13b436ad2e
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- assert-uint32: null
> +- env-assign: null
> +- format-and-define: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00010000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_0_LENGTH
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
> index 0000000000..b33306b28e
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00000000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_0_ORIGIN
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
> index 0000000000..093aff6eb4
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00010000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_1_LENGTH
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
> index 0000000000..5574289975
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00020000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_1_ORIGIN
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> index 0000000000..9298808b2a
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> @@ -0,0 +1,17 @@
> +actions:
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: true
> +description: |
> +  Sets the target processing unit to the RPU (R5F) cores.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: ZYNQMP_PROC_UNIT_RPU
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
> index 0000000000..966ae09b19
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
> @@ -0,0 +1,21 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: arm/xilinx_zynqmp_ultra96
> +  value: 0x80000000
> +- enabled-by: true
> +  value: 0x10000000
> +description: |
> +  override a BSP's default RAM length
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_LENGTH
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
> index 0000000000..ceb8401c37
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
> @@ -0,0 +1,19 @@
> +actions:
> +- assert-aligned: 1048576
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00100000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_ORIGIN
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
> index 0000000000..bac5c79627
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
> @@ -0,0 +1,16 @@
> +actions:
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: false
> +description: |
> +  reset vector address for BSP start
> +enabled-by: true
> +links: []
> +name: BSP_START_RESET_VECTOR
> +type: build
> On Mon, Jun 19, 2023 at 1:16 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 17/6/2023 5:14 am, Gedare Bloom wrote:
>> > On Fri, Jun 16, 2023 at 2:17 AM Philip Kirkpatrick
>> > <p.kirkpatrick at reflexaerospace.com> wrote:
>> >> On Fri, Jun 16, 2023 at 7:14 AM Chris Johns <chrisj at rtems.org> wrote:
>> >>> On 15/6/2023 6:16 pm, Philip Kirkpatrick wrote:
>> >>>> Thanks for all the good feedback.
>> >>>> RE Joel:
>> >>>> I'll fix my sloppy formatting that you caught and submit a revised
>> patch.  If
>> >>>> I'm realistic about my schedule, I probably won't be able to get to
>> it until
>> >>>> next week.
>> >>>> For xttcps_hw.h, there already is one #ifndef __rtems__ around the
>> #includes,
>> >>>> but on review there is another spot where I got lazy and used a #if
>> 0.  I'll
>> >>>> correct that too.  Other than that, the file is unmodified.
>> >>>> On the discussion about a shared space, I'll leave that decision up
>> to you.
>> >>>> Tell me what you want and I can adjust as needed, or it could be
>> done in a
>> >>>> follow-on patch.
>> >>> Should the RPU BSP be located under bsps/arm/xilinx-rpu?
>> >> I went back and forth on that decision and decided to keep them
>> combined since the APU and RPU share a moderate amount of code.  However, I
>> can definitely see an argument that they are different enough to split.  If
>> you want it the other way, I can make that change when I address the other
>> items.
>> Thanks, I think this is worth while.
>> > I think we should split it out. Shared code should likely be
>> > refactored to arm/shared depending what that is.
>> Agreed. I am fine with the code moving, leaving the arm/xilinx-zynqmp BSP
>> as is
>> because it may be removed (see below).
>> > I'm not sure that carrying forward a 32-bit arm/xilinx-zynqmp makes
>> > sense now that we have a functional aarch64 port. Splitting the RPU
>> > out will make it easier to make that decision.
>> I agree. I think it is confusing. I also think it should happen before 6.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230822/28e24169/attachment-0001.htm>
