bsps/xilinx-zynqmp : Add BSP for RPU
Tue Aug 22 14:33:30 UTC 2023
By separating this from the zynqmp bsp, there should be some
modification of the naming conventions to specify rpu--unless they
will share the code files identically. I guess that decision must be
made. These files should not be duplicated in the tree simultaneously,
as they introduce name clashes that (even if compilable) can be
confusing to follow through the source code.
a few more comments below
On Thu, Jun 29, 2023 at 10:37 AM Philip Kirkpatrick
<p.kirkpatrick at reflexaerospace.com> wrote:
> Took a while to get to but here is a new patch incorporating the feedback.
> Sorry to drop this and run but I'm on vacation for a week as soon as I send this.  So don't expect to see responses from me until July 10th or later.
> Once I'm back and this is through, expect to see some follow-on patches for enabling MPU, cache, and lwip support.  I have that working and tested but it needs some cleanup before I'll feel good about a patch.
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> new file mode 100644
> index 0000000000..469178fd86
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> @@ -0,0 +1,128 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2013, 2017 embedded brains GmbH
> + * Copyright (C) 2019 DornerWorks
> + * Written by Jeff Kubascik <jeff.kubascik at dornerworks.com>
> + *        and Josh Whitehead <josh.whitehead at dornerworks.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems/console.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/sysinit.h>
> +#include <bsp/irq.h>
> +#include <dev/serial/zynq-uart.h>
> +#include <bspopts.h>
> +static zynq_uart_context zynqmp_uart_instances[2] = {
> +    .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
> +    .regs = (volatile struct zynq_uart *) 0xff000000,
> +    .irq = ZYNQMP_IRQ_UART_0
> +    .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
> +    .regs = (volatile struct zynq_uart *) 0xff010000,
> +    .irq = ZYNQMP_IRQ_UART_1
> +rtems_status_code console_initialize(
> +  rtems_device_major_number major,
> +  rtems_device_minor_number minor,
> +  void *arg
> +  size_t i;
> +  for (i = 0; i < RTEMS_ARRAY_SIZE(zynqmp_uart_instances); ++i) {
> +    char uart[] = "/dev/ttySX";
> +    uart[sizeof(uart) - 2] = (char) ('0' + i);
> +    rtems_termios_device_install(
> +      &uart[0],
> +      &zynq_uart_handler,
> +      NULL,
> +      &zynqmp_uart_instances[i].base
> +    if (i == BSP_CONSOLE_MINOR) {
> +      link(&uart[0], CONSOLE_DEVICE_NAME);
> +  return RTEMS_SUCCESSFUL;
> +void zynqmp_debug_console_flush(void)
> +  zynq_uart_reset_tx_flush(&zynqmp_uart_instances[BSP_CONSOLE_MINOR]);
> +static void zynqmp_debug_console_out(char c)
> +  rtems_termios_device_context *base =
> +    &zynqmp_uart_instances[BSP_CONSOLE_MINOR].base;
> +  zynq_uart_write_polled(base, c);
> +static void zynqmp_debug_console_init(void)
> +  zynq_uart_initialize(base);
> +  BSP_output_char = zynqmp_debug_console_out;
> +static void zynqmp_debug_console_early_init(char c)
> +  zynqmp_debug_console_out(c);
> +static int zynqmp_debug_console_in(void)
> +  return zynq_uart_read_polled(base);
> +BSP_output_char_function_type BSP_output_char = zynqmp_debug_console_early_init;
> +BSP_polling_getchar_function_type BSP_poll_char = zynqmp_debug_console_in;
> +RTEMS_SYSINIT_ITEM(
> +  zynqmp_debug_console_init,
> +  RTEMS_SYSINIT_BSP_START,
> +  RTEMS_SYSINIT_ORDER_LAST_BUT_5
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> index 0000000000..9b71487999
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> @@ -0,0 +1,93 @@
> + * @file
> + * @ingroup RTEMSBSPsARMZynqMP
> + * @brief Global BSP definitions.
> + * Copyright (C) 2013, 2014 embedded brains GmbH
> + * modification, are permitted provideanything that d that the following conditions
> + * are met:
> +#ifndef LIBBSP_ARM_XILINX_ZYNQMP_BSP_H
> +#define LIBBSP_ARM_XILINX_ZYNQMP_BSP_H
> + * @defgroup RTEMSBSPsARMZynqMP Xilinx Zynq UltraScale+ MPSoC
> + * @brief Xilinx Zynq UltraScale+ MPSoC Board Support Package.
> +#define BSP_FEATURE_IRQ_EXTENSION
> +#ifndef ASM
> +#include <rtems.h>
> +#include <bsp/default-initial-extension.h>
> +#include <bsp/start.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +#define BSP_ARM_GIC_CPUIF_BASE 0x00F9001000
> +#define BSP_ARM_GIC_DIST_BASE 0xF9000000
> +#define BSP_ARM_A9MPCORE_SCU_BASE 0
> +#define BSP_ARM_A9MPCORE_GT_BASE 0
> + * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
> + * Provide in the application to override the defaults in the BSP.
> +BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
> +void zynqmp_debug_console_flush(void);
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* LIBBSP_ARM_XILINX_ZYNQMP_BSP_H */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> index 0000000000..681ccfb48c
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> @@ -0,0 +1,81 @@
> + * @file
> + * @ingroup zynqmp_interrupt
> + * @brief Interrupt definitions.
> + * Copyright (C) 2013 embedded brains GmbH
> + * are met:
> +#ifndef LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H
> +#define LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H
> +#ifndef ASM
> +#include <rtems/irq.h>
> +#include <rtems/irq-extension.h>
> +#include <dev/irq/arm-gic-irq.h>
> +#ifdef __cplusplus
> +extern "C" {
> +/* SPIs */
> +#define ZYNQMP_IRQ_UART_0 53
> +#define ZYNQMP_IRQ_UART_1 54
> +#define ZYNQMP_IRQ_TTC_0_0 68
> +#define ZYNQMP_IRQ_TTC_0_1 69
> +#define ZYNQMP_IRQ_TTC_0_2 70
> +#define ZYNQMP_IRQ_TTC_1_0 71
> +#define ZYNQMP_IRQ_TTC_1_1 72
> +#define ZYNQMP_IRQ_TTC_1_2 73
> +#define ZYNQMP_IRQ_TTC_2_0 74
> +#define ZYNQMP_IRQ_TTC_2_1 75
> +#define ZYNQMP_IRQ_TTC_2_2 76
> +#define ZYNQMP_IRQ_TTC_3_0 77
> +#define ZYNQMP_IRQ_TTC_3_1 78
> +#define ZYNQMP_IRQ_TTC_3_2 79
> +#define BSP_INTERRUPT_VECTOR_COUNT 188
> +#ifdef __cplusplus
> +#endif /* ASM */
> +#endif /* LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/tm27.h b/bsps/arm/xilinx-zynqmp-rpu/include/tm27.h
> index 0000000000..14214fe151
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/tm27.h
> @@ -0,0 +1,54 @@
> + * @file
> + * @ingroup zynqmp_tm27
> + * @brief Interrupt mechanisms for tm27 test.
> + * are met:
> +#ifndef _RTEMS_TMTEST27
> +#error "This is an RTEMS internal file you must not include directly."
> +#endif
> +#ifndef __tm27_h
> +#define __tm27_h
> + * @defgroup zynqmp_tm27 TM27 Test Support
> + * @brief Interrupt Mechanisms for tm27 test
> +#include <dev/irq/arm-gic-tm27.h>
> +#endif /* __tm27_h */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> index 0000000000..14f7d32436
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> @@ -0,0 +1,42 @@
> + * are met:
> +#include <bsp.h>
> +void bsp_reset(void)
> +  zynqmp_debug_console_flush();
> +  while (true) {
> +    /* Wait */
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c b/bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> index 0000000000..a3cc498d7e
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> @@ -0,0 +1,50 @@
> + * Copyright (C) 2013, 2015 embedded brains GmbH
> + * are met:
> +#include <bsp.h>
> +#include <bsp/bootcard.h>
> +#include <bsp/irq-generic.h>
> +#include <bsp/linker-symbols.h>
> +#include <libcpu/arm-cp15.h>
> +void bsp_start(void)
> +  bsp_interrupt_initialize();
> +  // TODO: enable cache
> +#if 0
> +  rtems_cache_coherent_add_area(
> +    bsp_section_nocacheheap_begin,
> +    (uintptr_t) bsp_section_nocacheheap_size
> +#endif
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c b/bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> index 0000000000..c0d35d31b7
> --- /dev/null
> +++ b/bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> @@ -0,0 +1,66 @@
> + * are met:
> +#include <bsp.h>
> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> +     * On reset, V will be set.  This points the exceptions to the FSBL's vectors.  The FSBL
> +     * should clear this bit before booting RTEMS but in some debugging
> +     * configurations the bit may not be.  The other bits should already be clear
> +     * on reset.  Since the correct settings in these bits are critical,
> +     * make sure SCTLR[M, I, A, C, V] are cleared.  Afterwards, exceptions are
> +     * handled by RTEMS.
> +     * Note 1: The APU also does these steps in start.S in _start in the #if block:
> +     *         `#if (__ARM_ARCH >= 7 && __ARM_ARCH_PROFILE == 'A') || __ARM_ARCH >= 8`
> +     * Note 2: Not all Arm R cores need this (like the TMS570).  So, this probably should
> +     *         be in this hook and not in start.S
> +     * Ref: https://developer.arm.com/documentation/ddi0460/c/System-Control/Register-descriptions/c1--System-Control-Register?lang=en
> +    __asm__ volatile(
> +      "mrc p15, 0, r0, c1, c0, 0 \n"
> +      "bic r1, r0, #0x3000 \n"     // Clear V[13] and I[12]
> +      "bic r1, r1, #0x7 \n"        // Clear C[2] A[1] and M[0]
Replace // with /*
> +      "mcr p15, 0, r1, c1, c0, 0 \n"
> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
> +  bsp_start_copy_sections();
> +  // TODO: Setup/enable cache HERE
> +  bsp_start_clear_bss();
> diff --git a/bsps/include/xil/xttcps_hw.h b/bsps/include/xil/xttcps_hw.h
> index 0000000000..0872e66c8f
> --- /dev/null
> +++ b/bsps/include/xil/xttcps_hw.h
> @@ -0,0 +1,223 @@
> +* Copyright (C) 2010 - 2021 Xilinx, Inc.  All rights reserved.
> +* SPDX-License-Identifier: MIT
> +* @file xttcps_hw.h
> +* @addtogroup ttcps_v3_14
> +* This file defines the hardware interface to one of the three timer counters
> +* in the Ps block.
> +* <pre>
> +* MODIFICATION HISTORY:
> +* Ver   Who    Date     Changes
> +* 1.00a drg/jz 01/21/10 First release
> +* 3.00  kvn    02/13/15 Modified code for MISRA-C:2012 compliance.
> +* 3.5   srm    10/06/17 Updated XTTCPS_COUNT_VALUE_MASK,
> +*                       XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK macros to
> +*                       mask 16 bit values for zynq and 32 bit values for
> +*                       zynq ultrascale+mpsoc "
> +* </pre>
> +#ifndef XTTCPS_HW_H /* prevent circular inclusions */
> +#define XTTCPS_HW_H /* by using protection macros */
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +/***************************** Include Files *********************************/
> +#ifndef __rtems__
Thanks for using this style. Can you import the clean file from the
upstream first, and then patch it with the RTEMS parts (and put in the
build)? This helps separate imported 3rd party code. In the commit for
import, reference the URL where the upstream is located.
> +#include "xil_types.h"
> +#include "xil_assert.h"
> +#include "xil_io.h"
> +#else
> +static inline u32 Xil_In32(UINTPTR Addr)
> + return *(volatile u32 *) Addr;
> +static inline void Xil_Out32(UINTPTR Addr, u32 Value)
> + volatile u32 *LocalAddr = (volatile u32 *)Addr;
> + *LocalAddr = Value;
> +#endif /* __rtems__ */
> +/************************** Constant Definitions *****************************/
> + * Flag for a9 processor
> +#ifndef __rtems__
> + #if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
> + #define ARMA9
> + #endif
> +#endif
> +/** @name Register Map
> + * Register offsets from the base address of the device.
> +#define XTTCPS_CLK_CNTRL_OFFSET 0x00000000U  /**< Clock Control Register */
> +#define XTTCPS_CNT_CNTRL_OFFSET 0x0000000CU  /**< Counter Control Register*/
> +#define XTTCPS_COUNT_VALUE_OFFSET 0x00000018U  /**< Current Counter Value */
> +#define XTTCPS_INTERVAL_VAL_OFFSET 0x00000024U  /**< Interval Count Value */
> +#define XTTCPS_MATCH_0_OFFSET 0x00000030U  /**< Match 1 value */
> +#define XTTCPS_MATCH_1_OFFSET 0x0000003CU  /**< Match 2 value */
> +#define XTTCPS_MATCH_2_OFFSET 0x00000048U  /**< Match 3 value */
> +#define XTTCPS_ISR_OFFSET 0x00000054U  /**< Interrupt Status Register */
> +#define XTTCPS_IER_OFFSET 0x00000060U  /**< Interrupt Enable Register */
> +/** @name Clock Control Register
> + * Clock Control Register definitions
> +#define XTTCPS_CLK_CNTRL_PS_EN_MASK 0x00000001U  /**< Prescale enable */
> +#define XTTCPS_CLK_CNTRL_PS_VAL_MASK 0x0000001EU  /**< Prescale value */
> +#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT 1U  /**< Prescale shift */
> +#define XTTCPS_CLK_CNTRL_PS_DISABLE 16U  /**< Prescale disable */
> +#define XTTCPS_CLK_CNTRL_SRC_MASK 0x00000020U  /**< Clock source */
> +#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK 0x00000040U  /**< External Clock edge */
> +/** @name Counter Control Register
> + * Counter Control Register definitions
> +#define XTTCPS_CNT_CNTRL_DIS_MASK 0x00000001U /**< Disable the counter */
> +#define XTTCPS_CNT_CNTRL_INT_MASK 0x00000002U /**< Interval mode */
> +#define XTTCPS_CNT_CNTRL_DECR_MASK 0x00000004U /**< Decrement mode */
> +#define XTTCPS_CNT_CNTRL_MATCH_MASK 0x00000008U /**< Match mode */
> +#define XTTCPS_CNT_CNTRL_RST_MASK 0x00000010U /**< Reset counter */
> +#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK 0x00000020U /**< Enable waveform */
> +#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK 0x00000040U /**< Waveform polarity */
> +#define XTTCPS_CNT_CNTRL_RESET_VALUE 0x00000021U /**< Reset value */
> +/** @name Current Counter Value Register
> + * Current Counter Value Register definitions
> +#if defined(ARMA9)
> +#define XTTCPS_COUNT_VALUE_MASK 0x0000FFFFU /**< 16-bit counter value */
> +#else
> +#define XTTCPS_COUNT_VALUE_MASK 0xFFFFFFFFU /**< 32-bit counter value */
> +#endif
> +/** @name Interval Value Register
> + * Interval Value Register is the maximum value the counter will count up or
> + * down to.
> +#if defined(ARMA9)
> +#define XTTCPS_INTERVAL_VAL_MASK (u32)(0x0000FFFF) /**< 16-bit Interval value*/
> +#else
> +#define XTTCPS_INTERVAL_VAL_MASK (u32)(0xFFFFFFFF) /**< 32-bit Interval value*/
> +#endif
> +/** @name Match Registers
> + * Definitions for Match registers, each timer counter has three match
> + * registers.
> +#if defined(ARMA9)
> +#define XTTCPS_MATCH_MASK 0x0000FFFFU /**< 16-bit Match value */
> +#else
> +#define XTTCPS_MATCH_MASK 0xFFFFFFFFU /**< 32-bit Match value */
> +#endif
> +#define XTTCPS_NUM_MATCH_REG 3U /**< Num of Match reg */
> +/** @name Interrupt Registers
> + * Following register bit mask is for all interrupt registers.
> +#define XTTCPS_IXR_INTERVAL_MASK 0x00000001U  /**< Interval Interrupt */
> +#define XTTCPS_IXR_MATCH_0_MASK 0x00000002U  /**< Match 1 Interrupt */
> +#define XTTCPS_IXR_MATCH_1_MASK 0x00000004U  /**< Match 2 Interrupt */
> +#define XTTCPS_IXR_MATCH_2_MASK 0x00000008U  /**< Match 3 Interrupt */
> +#define XTTCPS_IXR_CNT_OVR_MASK 0x00000010U  /**< Counter Overflow */
> +#define XTTCPS_IXR_ALL_MASK 0x0000001FU  /**< All valid Interrupts */
> +/***************** Macros (Inline Functions) Definitions *********************/
> +* Read the given Timer Counter register.
> +* @param BaseAddress is the base address of the timer counter device.
> +* @param RegOffset is the register offset to be read
> +* @return The 32-bit value of the register
> +* @note C-style signature:
> +* u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
> +#define XTtcPs_ReadReg(BaseAddress, RegOffset) \
> +    (Xil_In32((BaseAddress) + (u32)(RegOffset)))
> +* Write the given Timer Counter register.
> +* @param RegOffset is the register offset to be written
> +* @param Data is the 32-bit value to write to the register
> +* @return None.
> +* void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
> +* u32 Data)
> +#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data) \
> +    (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
> +* Calculate a match register offset using the Match Register index.
> +* @param MatchIndex is the 0-2 value of the match register
> +* @return MATCH_N_OFFSET.
> +* u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
> +#define XTtcPs_Match_N_Offset(MatchIndex) \
> + ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
> +/************************** Function Prototypes ******************************/
> +/************************** Variable Definitions *****************************/
> +#ifdef __cplusplus
> +#endif
> +#endif /* end of protection macro */
> diff --git a/bsps/include/xil/zynqmp.h b/bsps/include/xil/zynqmp.h
> index 0000000000..34051c525a
> --- /dev/null
> +++ b/bsps/include/xil/zynqmp.h
> @@ -0,0 +1,99 @@
> + * @file
> + * @brief Peripheral memory map.
> + * Copyright (C) 2023 Reflex Aerospace GmbH
> + * Written by Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com>
> + * are met:
> +#ifndef LIBBSP_ARM_ZYNQMP
> +#define LIBBSP_ARM_ZYNQMP
> +/* Data derived from https://docs.xilinx.com/r/en-US/ug1085-zynq-ultrascale-trm/PS-I/O-Peripherals-Registers */
> +/* LPD IO Peripherals */
> +#define ZYNQMP_UART0 (0xFF000000)
> +#define ZYNQMP_UART1 (0xFF010000)
> +#define ZYNQMP_I2C0 (0xFF020000)
> +#define ZYNQMP_I2C1 (0xFF030000)
> +#define ZYNQMP_SPI0 (0xFF040000)
> +#define ZYNQMP_SPI1 (0xFF050000)
> +#define ZYNQMP_CAN0 (0xFF060000)
> +#define ZYNQMP_CAN1 (0xFF070000)
> +#define ZYNQMP_GPIO (0xFF0A0000)
> +#define ZYNQMP_GEM0 (0xFF0B0000)
> +#define ZYNQMP_GEM1 (0xFF0C0000)
> +#define ZYNQMP_GEM2 (0xFF0D0000)
> +#define ZYNQMP_GEM3 (0xFF0E0000)
> +#define ZYNQMP_QSPI (0xFF0F0000)
> +#define ZYNQMP_NAND (0xFF100000)
> +#define ZYNQMP_SD0 (0xFF160000)
> +#define ZYNQMP_SD1 (0xFF170000)
> +#define ZYNQMP_IPI_MSG (0xFF990000)
> +#define ZYNQMP_USB0 (0xFF9D0000)
> +#define ZYNQMP_USB1 (0xFF9E0000)
> +#define ZYNQMP_AMS (0xFFA50000)
> +#define ZYNQMP_PSSYSMON (0xFFA50800)
> +#define ZYNQMP_PLSYSMON (0xFFA50C00)
> +#define ZYNQMP_CSU_SWDT (0xFFCB0000)
> +/* FPD IO Peripherals */
> +#define ZYNQMP_SATA (0xFD0C0000)
> +#define ZYNQMP_PCIE (0xFD0E0000)
> +#define ZYNQMP_PCIE_IN (0xFD0E0800)
> +#define ZYNQMP_PCIE_EG (0xFD0E0C00)
> +#define ZYNQMP_PCIE_DMA (0xFD0F0000)
> +#define ZYNQMP_SIOU (0xFD3D0000)
> +#define ZYNQMP_GTR (0xFD400000)
> +#define ZYNQMP_PCIE_ATTR (0xFD480000)
> +#define ZYNQMP_DP (0xFD4A0000)
> +#define ZYNQMP_GPU (0xFD4B0000)
> +#define ZYNQMP_DP_DMA (0xFD4C0000)
> +/* LPD System Registers */
> +#define ZYNQMP_IPI (0xFF300000)
> +#define ZYNQMP_TTC0 (0xFF110000)
> +#define ZYNQMP_TTC1 (0xFF120000)
> +#define ZYNQMP_TTC2 (0xFF130000)
> +#define ZYNQMP_TTC3 (0xFF140000)
> +#define ZYNQMP_LPD_SWDT (0xFF150000)
> +#define ZYNQMP_XPPU (0xFF980000)
> +#define ZYNQMP_XPPU_SINK (0xFF9C0000)
> +#define ZYNQMP_PL_LPD (0xFF9B0000)
> +#define ZYNQMP_OCM (0xFFA00000)
> +#define ZYNQMP_LPD_FPD (0xFFA10000)
> +#define ZYNQMP_RTC (0xFFA60000)
> +#define ZYNQMP_OCM_XMPU (0xFFA70000)
> +#define ZYNQMP_LPD_DMA (0xFFA80000)
> +#define ZYNQMP_CSU_DMA (0xFFC80000)
> +#define ZYNQMP_CSU (0xFFCA0000)
> +#define ZYNQMP_BBRAM (0xFFCD0000)
> +#endif /* LIBBSP_ARM_ZYNQMP */
> diff --git a/bsps/shared/dev/clock/xil-ttc.c b/bsps/shared/dev/clock/xil-ttc.c
> index 0000000000..c6aaaa9f91
> --- /dev/null
> +++ b/bsps/shared/dev/clock/xil-ttc.c
> @@ -0,0 +1,214 @@
> + * @file
> + * @brief Triple Timer Counter clock functions definitions.
> + * are met:
> +#include <stdlib.h>
> +#include <rtems.h>
> +#include <bsp.h>
> +#include <zynqmp.h>
> +#include <xttcps_hw.h>
> +#include <rtems/timecounter.h>
> +static struct timecounter zynqmp_ttc_tc;
Avoid global variables (of any kind) unless there's a good reason. It
makes it harder to reason about correctness in the presence of
concurrency. This variable appears to only be used in one function
context. It could be a static variable in the function scope.
> +#define TTC_REFERENCE_CLOCK 100000000
> +/* This is defined in dev/clock/clockimpl.h */
> +void Clock_isr(rtems_irq_hdl_param arg);
> +static uint32_t irq_match_interval;
Alternatively, if you have several static global variables, you may
encapsulate them within a "context" struct. See arm-generic-timer.c in
this same directory for one such example. This centralizes the shared
data definition and makes it easier to recognize potential concurrency
problems.
> +static uint32_t zynqmp_ttc_get_timecount(struct timecounter *tc)
> +  uint32_t time;
> +  time = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
> +  return time;
> + *  @brief Initialize the HW peripheral for clock driver
> + *  Clock driver is implemented by RTI module
> + * @retval Void
> +static void zynqmp_ttc_clock_driver_support_initialize_hardware(void)
> +  uint32_t microsec_per_tick;
> +  uint16_t clock_ratio;
> +  uint8_t  index;
> +  uint32_t frequency;
> +  uint32_t prescaler;
> +  uint32_t tmp_reg_val;
> +  microsec_per_tick = rtems_configuration_get_microseconds_per_tick();
> +  /* Check the TTC is OFF before reconfiguring */
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CNT_CNTRL_OFFSET, XTTCPS_CNT_CNTRL_DIS_MASK |
> +        XTTCPS_CNT_CNTRL_EN_WAVE_MASK);  // Don't enable waveform output (active low)
> +  /* Prescaler value is 2^(N + 1)
> +   * Divide down the clock as much as possible while still retaining a
> +   * frequency that is an integer multiple of 1MHz.  This maximizes time to
> +   * overflow while minimizing rounding errors in 1us periods
> +  clock_ratio = TTC_REFERENCE_CLOCK / 1000000;
> +  /* Search for the highest set bit.  This is effectively min(log2(ratio))*/
> +  for(index = sizeof(clock_ratio) * 8 - 1; index > 0; index--) {
> +    if((clock_ratio >> (index)) & 0x01) {
> +        break;
> +  if(index == 0 && (clock_ratio & 0x01 == 0)) {
> +    // No prescaler
> +    frequency = TTC_REFERENCE_CLOCK;
> +    XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_CLK_CNTRL_OFFSET, 0);
> +  } else {
> +    prescaler = index - 1;
> +    frequency = TTC_REFERENCE_CLOCK / (1 << (prescaler + 1));
> +        prescaler << XTTCPS_CLK_CNTRL_PS_VAL_SHIFT |
> +        XTTCPS_CLK_CNTRL_PS_EN_MASK);
> +  /* Max out the counter interval */
> +  tmp_reg_val = XTTCPS_INTERVAL_VAL_MASK;
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_INTERVAL_VAL_OFFSET, tmp_reg_val);
> +  /* Setup match register to generate tick IRQ */
> +  irq_match_interval = (uint32_t) ((frequency * microsec_per_tick) / 1000000);
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, irq_match_interval);
> +  /* Clear interupts (clear on read) */
> +  XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
> +  /* Enable interupt for match register */
> +  XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_IER_OFFSET, XTTCPS_IXR_MATCH_0_MASK);
> +  /* Configure, reset, and enable counter */
> +        XTTCPS_CNT_CNTRL_EN_WAVE_MASK |  /* Don't enable waveform output (active low) */
> +        XTTCPS_CNT_CNTRL_RST_MASK |      /* Reset count and start counter */
> +        XTTCPS_CNT_CNTRL_MATCH_MASK      /* Enable match mode */
> +        /* Increment mode */
> +        /* Overflow mode */
> +        /* Not disabled */
> +  /* set timecounter */
> +  zynqmp_ttc_tc.tc_get_timecount = zynqmp_ttc_get_timecount;
> +  zynqmp_ttc_tc.tc_counter_mask = XTTCPS_COUNT_VALUE_MASK;
> +  zynqmp_ttc_tc.tc_frequency = frequency;
> +  zynqmp_ttc_tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
> +  rtems_timecounter_install(&zynqmp_ttc_tc);
> + * @brief Clears interrupt source
> + * @retval Void
> +static uint32_t tick_miss = 0;
ditto.
> +static void zynqmp_ttc_clock_driver_support_at_tick( void )
> +  uint32_t irq_flags;
> +  uint32_t cval;
> +  uint32_t now;
> +  uint32_t delta;
> +  /* Get and clear interupts (clear on read) */
> +  irq_flags = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_ISR_OFFSET);
> +  if(irq_flags & XTTCPS_IXR_MATCH_0_MASK) {
> +    /* Update match */
> +    cval = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET);
> +    /* Check that the match for the next tick is in the future
> +     * If no, then set the match for one irq interval from now
> +     *   This will have the effect that your timebase will slip but
> +     *   won't hang waiting for the counter to wrap around.
> +     * If this happens durring normal opteration, there is a problem
during, operation
> +     *   causing this interrupt to not be serviced quickly enough
> +     * If this happens during debugging, that is normal and expected
> +     *   becaue the TTC does NOT pause when the CPU is halted on a breakpoint
because
> +    now = XTtcPs_ReadReg(ZYNQMP_TTC0, XTTCPS_COUNT_VALUE_OFFSET);
> +    delta = now - cval;
> +    if(delta > irq_match_interval) {
> +     cval = now;
> +     tick_miss++;
> +    cval += irq_match_interval;
> +    XTtcPs_WriteReg(ZYNQMP_TTC0, XTTCPS_MATCH_0_OFFSET, cval);
> +  /* Else, something is set up wrong, only match should be enabled */
> + * @brief registers RTI interrupt handler
> + * @param[in] Clock_isr new ISR handler
> + * @param[in] Old_ticker old ISR handler (unused and type broken)
> + * @retval Void
> +static void zynqmp_ttc_clock_driver_support_install_isr(
> +  rtems_isr_entry Clock_isr
> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
> +  sc = rtems_interrupt_handler_install(
> +    ZYNQMP_IRQ_TTC_0_0,
> +    "Clock",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    (rtems_interrupt_handler) Clock_isr,
> +    NULL
> +  if ( sc != RTEMS_SUCCESSFUL ) {
> +    rtems_fatal_error_occurred(0xdeadbeef);
> +#define Clock_driver_support_at_tick \
> +                        zynqmp_ttc_clock_driver_support_at_tick
> +#define Clock_driver_support_initialize_hardware \
> +                        zynqmp_ttc_clock_driver_support_initialize_hardware
> +#define Clock_driver_support_install_isr(Clock_isr) \
> +              zynqmp_ttc_clock_driver_support_install_isr( Clock_isr )
> +#include "../../../shared/dev/clock/clockimpl.h"
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> index 0000000000..829e9c9297
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-string: null
> +- split: null
> +- env-append: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2023 Reflex Aerospace GmbH (https://www.reflexaerospace.com/)
> +default:
> +- enabled-by: true
> +  value:
> +  - -march=armv7-r
> +  - -mthumb
> +  - -mfpu=vfpv3-d16
> +  - -mfloat-abi=hard
> +description: |
> +  ABI flags
> +enabled-by: true
> +links: []
> +name: ABI_FLAGS
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
> index 0000000000..ec2d6ed158
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercureyxu5.yml
> @@ -0,0 +1,92 @@
> +arch: arm
> +bsp: xilinx_zynqmp_mercuryxu5_rpu
> +build-type: bsp
> +cflags: []
> +copyrights:
> +cppflags: []
> +enabled-by: true
> +family: xilinx-zynqmp-rpu
> +includes:
> +- bsps/include/xil/
> +install:
> +- destination: ${BSP_INCLUDEDIR}
> +  source:
> +  - bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> +  - bsps/include/xil/xil_types.h
> +  - bsps/include/xil/xil_assert.h
> +  - bsps/include/xil/xil_io.h
> +  - bsps/include/xil/xttcps_hw.h
> +  - bsps/include/xil/zynqmp.h
> +- destination: ${BSP_INCLUDEDIR}/bsp
> +  source:
> +  - bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
> +links:
> +- role: build-dependency
> +  uid: ../grp
> +  uid: ../start
> +  uid: abi
> +  uid: optclkfastidle
> +  uid: optclkuart
> +  uid: optconirq
> +  uid: ../../optconminor
> +  uid: optint0len
> +  uid: optint0ori
> +  uid: optint1len
> +  uid: optint1ori
> +  uid: optramlen
> +  uid: optramori
> +  uid: optresetvec
> +  uid: ../../obj
> +  uid: ../../objirq
> +  uid: ../../objdevserialzynq
> +  uid: ../../objdevspizynq
> +  uid: ../../objdevspixil
> +  uid: ../../objmem
> +  uid: ../../opto0
> +  uid: linkcmds
> +  uid: ../../bspopts
> +source:
> +- bsps/shared/cache/nocache.c
> +- bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
> +- bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> +- bsps/arm/shared/start/bsp-start-memcpy.S
> +- bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> +- bsps/arm/xilinx-zynqmp-rpu/start/bspreset.c
> +- bsps/arm/xilinx-zynqmp-rpu/start/bspstart.c
> +- bsps/arm/xilinx-zynqmp-rpu/start/bspstarthooks.c
> +- bsps/shared/dev/clock/xil-ttc.c
> +- bsps/shared/dev/btimer/btimer-cpucounter.c
> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
> +- bsps/shared/dev/irq/arm-gicv2.c
> +- bsps/shared/dev/irq/arm-gicv2-zynqmp.c
> +- bsps/shared/dev/serial/console-termios.c
> +- bsps/shared/irq/irq-default-handler.c
> +- bsps/shared/start/bspfatal-default.c
> +- bsps/shared/start/gettargethash-default.c
> +- bsps/shared/start/sbrk.c
> +- bsps/shared/start/stackalloc.c
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> index 0000000000..f5e6ff7822
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
> @@ -0,0 +1,41 @@
> +build-type: config-file
> +content: |
> +  MEMORY {
> +    RAM_INT_0 : ORIGIN = ${ZYNQMP_RPU_RAM_INT_0_ORIGIN:#010x}, LENGTH = ${ZYNQMP_RPU_RAM_INT_0_LENGTH:#010x}
> +    RAM_INT_1 : ORIGIN = ${ZYNQMP_RPU_RAM_INT_1_ORIGIN:#010x}, LENGTH = ${ZYNQMP_RPU_RAM_INT_1_LENGTH:#010x}
> +    RAM       : ORIGIN = ${ZYNQMP_RPU_RAM_ORIGIN:#010x}, LENGTH = ${ZYNQMP_RPU_RAM_LENGTH:#010x} - ${ZYNQMP_RPU_RAM_ORIGIN:#010x}
> +  REGION_ALIAS ("REGION_START",          RAM_INT_0);
> +  REGION_ALIAS ("REGION_VECTOR",         RAM_INT_0);
> +  REGION_ALIAS ("REGION_TEXT",           RAM);
> +  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
> +  REGION_ALIAS ("REGION_RODATA",         RAM);
> +  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
> +  REGION_ALIAS ("REGION_DATA",           RAM);
> +  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
> +  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
> +  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
> +  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
> +  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
> +  REGION_ALIAS ("REGION_BSS",            RAM);
> +  REGION_ALIAS ("REGION_WORK",           RAM);
> +  REGION_ALIAS ("REGION_STACK",          RAM);
> +  REGION_ALIAS ("REGION_NOCACHE",        RAM);
> +  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
> +  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
> +  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
> +  bsp_vector_table_in_start_section = 1;
> +  INCLUDE linkcmds.armv4
> +copyrights:
> +enabled-by: true
> +install-path: ${BSP_LIBDIR}
> +links: []
> +target: linkcmds
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
> index 0000000000..e303a8bf9f
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkfastidle.yml
> @@ -0,0 +1,21 @@
> +actions:
> +- get-boolean: null
> +- define-condition: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +default:
> +- enabled-by:
> +  - arm/lm3s6965_qemu
> +  - arm/realview_pbx_a9_qemu
> +  - arm/xilinx_zynq_a9_qemu
> +  value: true
> +- enabled-by: true
> +  value: false
> +description: |
> +  This sets a mode where the time runs as fast as possible when a clock ISR occurs while the IDLE thread is executing.  This can significantly reduce simulation times.
> +enabled-by: true
> +links: []
> +name: CLOCK_DRIVER_USE_FAST_IDLE
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
> index 0000000000..77c8f30fff
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optclkuart.yml
> @@ -0,0 +1,17 @@
> +actions:
> +- get-integer: null
> +- define: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 100000000
> +description: |
> +  Zynq UART clock frequency in Hz
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: ZYNQ_CLOCK_UART
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
> index 0000000000..ea13fa4561
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optconirq.yml
> @@ -0,0 +1,16 @@
> +actions:
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: true
> +description: |
> +  use interrupt driven mode for console devices (used by default)
> +enabled-by: true
> +links: []
> +name: ZYNQ_CONSOLE_USE_INTERRUPTS
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
> index 0000000000..13b436ad2e
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0len.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- assert-uint32: null
> +- env-assign: null
> +- format-and-define: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00010000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_0_LENGTH
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
> index 0000000000..b33306b28e
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint0ori.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00000000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_0_ORIGIN
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
> index 0000000000..093aff6eb4
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1len.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00010000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_1_LENGTH
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
> index 0000000000..5574289975
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optint1ori.yml
> @@ -0,0 +1,18 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00020000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_INT_1_ORIGIN
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> index 0000000000..9298808b2a
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
> @@ -0,0 +1,17 @@
> +actions:
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: true
> +description: |
> +  Sets the target processing unit to the RPU (R5F) cores.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: ZYNQMP_PROC_UNIT_RPU
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
> index 0000000000..966ae09b19
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramlen.yml
> @@ -0,0 +1,21 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: arm/xilinx_zynqmp_ultra96
> +  value: 0x80000000
> +- enabled-by: true
> +  value: 0x10000000
> +description: |
> +  override a BSP's default RAM length
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_LENGTH
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
> index 0000000000..ceb8401c37
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optramori.yml
> @@ -0,0 +1,19 @@
> +actions:
> +- assert-aligned: 1048576
> +- env-assign: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: 0x00100000
> +description: ''
> +enabled-by: true
> +format: '{:#010x}'
> +links: []
> +name: ZYNQMP_RPU_RAM_ORIGIN
> +type: build
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
> index 0000000000..bac5c79627
> --- /dev/null
> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optresetvec.yml
> @@ -0,0 +1,16 @@
> +actions:
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: false
> +description: |
> +  reset vector address for BSP start
> +enabled-by: true
> +links: []
> +name: BSP_START_RESET_VECTOR
> +type: build
> On Mon, Jun 19, 2023 at 1:16 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 17/6/2023 5:14 am, Gedare Bloom wrote:
>> > On Fri, Jun 16, 2023 at 2:17 AM Philip Kirkpatrick
>> >> On Fri, Jun 16, 2023 at 7:14 AM Chris Johns <chrisj at rtems.org> wrote:
>> >>> On 15/6/2023 6:16 pm, Philip Kirkpatrick wrote:
>> >>>> Thanks for all the good feedback.
>> >>>> RE Joel:
>> >>>> I'll fix my sloppy formatting that you caught and submit a revised patch.  If
>> >>>> I'm realistic about my schedule, I probably won't be able to get to it until
>> >>>> next week.
>> >>>> For xttcps_hw.h, there already is one #ifndef __rtems__ around the #includes,
>> >>>> but on review there is another spot where I got lazy and used a #if 0.  I'll
>> >>>> correct that too.  Other than that, the file is unmodified.
>> >>>> On the discussion about a shared space, I'll leave that decision up to you.
>> >>>> Tell me what you want and I can adjust as needed, or it could be done in a
>> >>>> follow-on patch.
>> >>> Should the RPU BSP be located under bsps/arm/xilinx-rpu?
>> >> I went back and forth on that decision and decided to keep them combined since the APU and RPU share a moderate amount of code.  However, I can definitely see an argument that they are different enough to split.  If you want it the other way, I can make that change when I address the other items.
>> Thanks, I think this is worth while.
>> > I think we should split it out. Shared code should likely be
>> > refactored to arm/shared depending what that is.
>> Agreed. I am fine with the code moving, leaving the arm/xilinx-zynqmp BSP as is
>> because it may be removed (see below).
>> > I'm not sure that carrying forward a 32-bit arm/xilinx-zynqmp makes
>> > sense now that we have a functional aarch64 port. Splitting the RPU
>> > out will make it easier to make that decision.
>> I agree. I think it is confusing. I also think it should happen before 6.
>> Chris
