[PATCH 1/2] spec/testsuite/dl: Fix optimization flags
chrisj at rtems.org chrisj at rtems.org
Sat Aug 26 23:30:35 UTC 2023
Updates #4944
 spec/build/testsuites/grp.yml           | 1 +
 spec/build/testsuites/libtests/dl01.yml | 3 ++-
 spec/build/testsuites/libtests/dl02.yml | 3 ++-
 spec/build/testsuites/libtests/dl03.yml | 3 ++-
 spec/build/testsuites/libtests/dl04.yml | 3 ++-
 spec/build/testsuites/libtests/dl05.yml | 3 ++-
 spec/build/testsuites/libtests/dl06.yml | 3 ++-
 spec/build/testsuites/libtests/dl07.yml | 3 ++-
 spec/build/testsuites/libtests/dl08.yml | 3 ++-
 spec/build/testsuites/libtests/dl09.yml | 3 ++-
 spec/build/testsuites/libtests/dl10.yml | 3 ++-
 spec/build/testsuites/libtests/dl11.yml | 3 ++-
 12 files changed, 23 insertions(+), 11 deletions(-)
diff --git a/spec/build/testsuites/grp.yml b/spec/build/testsuites/grp.yml
index c50693420c..85b50e01e8 100644
--- a/spec/build/testsuites/grp.yml
+++ b/spec/build/testsuites/grp.yml
@@ -12,6 +12,7 @@ includes:
 - ${BSP_INCLUDES}
 install: []
 ldflags:
+- ${TEST_OPTIMIZATION_FLAGS}
 - ${COVERAGE_LINKER_FLAGS}
 links:
 - role: build-dependency
diff --git a/spec/build/testsuites/libtests/dl01.yml b/spec/build/testsuites/libtests/dl01.yml
index 3cc04a6611..ae3d125a65 100644
--- a/spec/build/testsuites/libtests/dl01.yml
+++ b/spec/build/testsuites/libtests/dl01.yml
@@ -1,6 +1,7 @@
 SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
 build-type: script
-cflags: []
+cflags:
 copyrights:
 - Copyright (C) 2020 embedded brains GmbH & Co. KG
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl02.yml b/spec/build/testsuites/libtests/dl02.yml
index 9fd81dc7c8..59ddf27a96 100644
--- a/spec/build/testsuites/libtests/dl02.yml
+++ b/spec/build/testsuites/libtests/dl02.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl03.yml b/spec/build/testsuites/libtests/dl03.yml
index 363e3a925f..edeceeef3b 100644
--- a/spec/build/testsuites/libtests/dl03.yml
+++ b/spec/build/testsuites/libtests/dl03.yml
@@ -1,6 +1,7 @@
 build-type: test-program
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl04.yml b/spec/build/testsuites/libtests/dl04.yml
index 7dd41e3338..c31dab7e69 100644
--- a/spec/build/testsuites/libtests/dl04.yml
+++ b/spec/build/testsuites/libtests/dl04.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl05.yml b/spec/build/testsuites/libtests/dl05.yml
index 80f72131d0..db64528dd1 100644
--- a/spec/build/testsuites/libtests/dl05.yml
+++ b/spec/build/testsuites/libtests/dl05.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl06.yml b/spec/build/testsuites/libtests/dl06.yml
index 0fc5af1478..11243412b1 100644
--- a/spec/build/testsuites/libtests/dl06.yml
+++ b/spec/build/testsuites/libtests/dl06.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl07.yml b/spec/build/testsuites/libtests/dl07.yml
index 82dd3ccdde..31b8e28942 100644
--- a/spec/build/testsuites/libtests/dl07.yml
+++ b/spec/build/testsuites/libtests/dl07.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl08.yml b/spec/build/testsuites/libtests/dl08.yml
index d3982f2357..0467ca3c4c 100644
--- a/spec/build/testsuites/libtests/dl08.yml
+++ b/spec/build/testsuites/libtests/dl08.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl09.yml b/spec/build/testsuites/libtests/dl09.yml
index 11066d2c0d..bada446d16 100644
--- a/spec/build/testsuites/libtests/dl09.yml
+++ b/spec/build/testsuites/libtests/dl09.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl10.yml b/spec/build/testsuites/libtests/dl10.yml
index 880abeff9b..df88b806f2 100644
--- a/spec/build/testsuites/libtests/dl10.yml
+++ b/spec/build/testsuites/libtests/dl10.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 cppflags: []
diff --git a/spec/build/testsuites/libtests/dl11.yml b/spec/build/testsuites/libtests/dl11.yml
index 6eaaeaeecc..788502ed65 100644
--- a/spec/build/testsuites/libtests/dl11.yml
+++ b/spec/build/testsuites/libtests/dl11.yml
@@ -1,6 +1,7 @@
 build-type: script
-cflags: []
+cflags:
 copyrights:
 - Copyright (C) 2023 On-Line Applications Research (OAR)
 cppflags: []
2.37.1
