[RSB PATCH] rtems/tools: Shell execute fixes
chrisj at rtems.org chrisj at rtems.org
Tue Aug 29 02:14:04 UTC 2023
Updates #4951
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index 6eed755..b360f7e 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version 349bbd96543365e830e5ef5e851765e4b742a8a4
+ %define rtems_tools_version 3ea0c249346fda427bf0d3c169aa3e7c2a521df8
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-       qb5EC4gWfahYLPliYk+mNRsgzaDuouqiRq6GURb8v0Pk4J6Uo6IiKrB6dPvqVPO+wh9Omb1xCs+86W/+fj8sZg==
+       +wrMxGHJp5cd/hpgoGwTH65IvwZQsAWOb8JNmDZKdFqUbhUuUYq1zK1p5NJnvCUkHudxgDmghAe/5kaFE5DJ4w==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.37.1
