[RSB PATCH] rtems/tools: Shell execute fixes
Tue Aug 29 04:12:52 UTC 2023
Looks ok to push
On Mon, Aug 28, 2023, 9:14 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Updates #4951
>  rtems/config/tools/rtems-tools-6.cfg | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-6.cfg
> b/rtems/config/tools/rtems-tools-6.cfg
> index 6eed755..b360f7e 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
>   %define rtems_tools_source rtems-tools-%{rtems_tools_version}
>   %define rtems_tools_ext xz
>  %else
> - %define rtems_tools_version 349bbd96543365e830e5ef5e851765e4b742a8a4
> + %define rtems_tools_version 3ea0c249346fda427bf0d3c169aa3e7c2a521df8
>   %define rtems_tools_ext bz2
>  %endif
>  %source set rtems-tools
> https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
>  %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
>  qb5EC4gWfahYLPliYk+mNRsgzaDuouqiRq6GURb8v0Pk4J6Uo6IiKrB6dPvqVPO+wh9Omb1xCs+86W/+fj8sZg==
>  +wrMxGHJp5cd/hpgoGwTH65IvwZQsAWOb8JNmDZKdFqUbhUuUYq1zK1p5NJnvCUkHudxgDmghAe/5kaFE5DJ4w==
>  # Optionally enable/disable building the RTEMS Tools via the command line.
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230828/005fe4e8/attachment.htm>
