[PATCH 1/3] cpukit/jffs2: Avoid delayed work lock inversion
Kinsey Moore kinsey.moore at oarcorp.com
Wed Aug 30 22:08:38 UTC 2023
This moves delayed work to a temporary chain to prevent a locking
inversion between the delayed work lock and the alloc_sem lock. Delayed
work is now processed after the delayed work lock is released. Locking
order is any JFFS2 locks before the delayed work lock.
 cpukit/libfs/src/jffs2/src/fs-rtems.c | 14 +++++++++++++-
 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 59d03effe6..1a677c9772 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -1282,6 +1282,8 @@ static void process_delayed_work(void)
 	rtems_chain_node*    node;
 	mutex_lock(&delayed_work_mutex);
+	rtems_chain_control process_work_chain;
+	rtems_chain_initialize_empty(&process_work_chain);
 	if (rtems_chain_is_empty(&delayed_work_chain)) {
 		mutex_unlock(&delayed_work_mutex);
@@ -1294,12 +1296,22 @@ static void process_delayed_work(void)
 		rtems_chain_node* next_node = rtems_chain_next(node);
 		if (rtems_clock_get_uptime_nanoseconds() >= work->execution_time) {
 			rtems_chain_extract(node);
-			work->callback(&work->work);
+			rtems_chain_append(&process_work_chain, node);
 		node = next_node;
+	node = rtems_chain_first(&process_work_chain);
+	while (!rtems_chain_is_tail(&process_work_chain, node)) {
+		work = (struct delayed_work*) node;
+		rtems_chain_node* next_node = rtems_chain_next(node);
+		rtems_chain_extract(node);
+		work->callback(&work->work);
+		node = next_node;
 /* Task for processing delayed work */
 static rtems_task delayed_work_task(
   rtems_task_argument unused
2.39.2
