[PATCH 2/3] bsps/xnandpsu: Ensure correct cache maintenance
Kinsey Moore kinsey.moore at oarcorp.com
Wed Aug 30 22:08:39 UTC 2023
The changes here ensure correct cache maintenance around DMA operations.
One cache flush was missing and two cache invalidations occurred before
the corresponding read that would make them necessary.
 bsps/shared/dev/nand/xnandpsu.c | 21 +++++++++++++++++++++
 1 file changed, 21 insertions(+)
diff --git a/bsps/shared/dev/nand/xnandpsu.c b/bsps/shared/dev/nand/xnandpsu.c
index 89451d19f8..85e6ba8532 100644
--- a/bsps/shared/dev/nand/xnandpsu.c
+++ b/bsps/shared/dev/nand/xnandpsu.c
@@ -2002,6 +2002,14 @@ static s32 XNandPsu_ReadPage(XNandPsu *InstancePtr, u32 Target, u32 Page,
 	Status = XNandPsu_Data_ReadWrite(InstancePtr, Buf, PktCount, PktSize, 0, 1);
+#ifdef __rtems__
+	if (InstancePtr->DmaMode == XNANDPSU_MDMA) {
+		if (InstancePtr->Config.IsCacheCoherent == 0) {
+			Xil_DCacheInvalidateRange((INTPTR)(void *)Buf, (PktSize * PktCount));
+#endif
 	/* Check ECC Errors */
 	if (InstancePtr->EccMode == XNANDPSU_HWECC) {
 		/* Hamming Multi Bit Errors */
@@ -2115,6 +2123,14 @@ s32 XNandPsu_ReadSpareBytes(XNandPsu *InstancePtr, u32 Page, u8 *Buf)
+#ifdef __rtems__
+#endif
 	return Status;
@@ -2557,6 +2573,11 @@ static s32 XNandPsu_ChangeWriteColumn(XNandPsu *InstancePtr, u32 Target,
 		RegVal = XNANDPSU_INTR_STS_EN_TRANS_COMP_STS_EN_MASK |
 			 XNANDPSU_INTR_STS_EN_DMA_INT_STS_EN_MASK;
+#ifdef __rtems__
+			Xil_DCacheFlushRange((INTPTR)(void *)Buf, (PktSize * PktCount));
+#endif
 		XNandPsu_Update_DmaAddr(InstancePtr, Buf);
 	} else {
 		RegVal = XNANDPSU_INTR_STS_EN_BUFF_WR_RDY_STS_EN_MASK;
2.39.2
